nachdem ich jetzt schon Tagelang am experimentieren bin brauch ich einfach Hilfe.
Mein Ambilight läuft zwar allerdings nur in Blautönen siehe Video, ich hoffe man erkennt es einigermaßen.
https://www.dropbox.com/s/r8532np1uzr78ga/ambilight.mp4?dl=0
Fernssteuerung per App funktioniert einwandfrei, die Farben sind auch richtig eingestellt wenn ich einzelne Farben in Putty aufrufe.
Ich habe den Mumbi STK1160 Grabber und diese Anleitung befolgt:
http://www.serhan.in/ambilight-mit-hyperion/
Bitte dringend um Hilfe, bin Dankbar für jeden Tipp!
hier noch meine Config:
// Automatically generated configuration file for 'Hyperion daemon'
// Generated by: HyperCon (The Hyperion deamon configuration file builder
/// Device configuration contains the following fields:
/// * 'name' : The user friendly name of the device (only used for display purposes)
/// * 'type' : The type of the device or leds (known types for now are 'ws2801', 'ldp8806',
/// 'lpd6803', 'sedu', 'adalight', 'lightpack', 'test' and 'none')
/// * 'output' : The output specification depends on selected device. This can for example be the
/// device specifier, device serial number, or the output file name
/// * 'rate' : The baudrate of the output to the device
/// * 'colorOrder' : The order of the color bytes ('rgb', 'rbg', 'bgr', etc.).
"device" :
"name" : "MyPi",
"type" : "lpd8806",
"output" : "/dev/spidev0.0",
"rate" : 250000,
"colorOrder" : "grb"
/// Color manipulation configuration used to tune the output colors to specific surroundings.
/// The configuration contains a list of color-transforms. Each transform contains the
/// following fields:
/// * 'id' : The unique identifier of the color transformation (eg 'device_1') /// * 'leds' : The indices (or index ranges) of the leds to which this color transform applies
/// (eg '0-5, 9, 11, 12-17'). The indices are zero based. /// * 'hsv' : The manipulation in the Hue-Saturation-Value color domain with the following
/// tuning parameters:
/// - 'saturationGain' The gain adjustement of the saturation
/// - 'valueGain' The gain adjustement of the value
/// * 'red'/'green'/'blue' : The manipulation in the Red-Green-Blue color domain with the
/// following tuning parameters for each channel:
/// - 'threshold' The minimum required input value for the channel to be on
/// (else zero)
/// - 'gamma' The gamma-curve correction factor
/// - 'blacklevel' The lowest possible value (when the channel is black)
/// - 'whitelevel' The highest possible value (when the channel is white)
/// Next to the list with color transforms there is also a smoothing option.
/// * 'smoothing' : Smoothing of the colors in the time-domain with the following tuning
/// parameters:
/// - 'type' The type of smoothing algorithm ('linear' or 'none')
/// - 'time_ms' The time constant for smoothing algorithm in milliseconds
/// - 'updateFrequency' The update frequency of the leds in Hz
"color" :
"transform" :
"id" : "default",
"leds" : "*",
"hsv" :
"saturationGain" : 1.0000,
"valueGain" : 1.0000
"red" :
"threshold" : 0.0000,
"gamma" : 1.0000,
"blacklevel" : 0.0000,
"whitelevel" : 1.0000
"green" :
"gamma" : 1.0000,
"blue" :
"gamma" : 1.0000,
"smoothing" :
"type" : "none",
"time_ms" : 200,
"updateFrequency" : 20.0000
/// The configuration for each individual led. This contains the specification of the area
/// averaged of an input image for each led to determine its color. Each item in the list
/// contains the following fields:
/// * index: The index of the led. This determines its location in the string of leds; zero
/// being the first led.
/// * hscan: The fractional part of the image along the horizontal used for the averaging
/// (minimum and maximum inclusive)
/// * vscan: The fractional part of the image along the vertical used for the averaging
"leds" :
"index" : 0,
"hscan" : { "minimum" : 0.0000, "maximum" : 0.0500 },
"vscan" : { "minimum" : 0.9667, "maximum" : 1.0000 }
"index" : 1,
"vscan" : { "minimum" : 0.9333, "maximum" : 0.9667 }
"index" : 2,
"vscan" : { "minimum" : 0.9000, "maximum" : 0.9333 }
"index" : 3,
"vscan" : { "minimum" : 0.8667, "maximum" : 0.9000 }
"index" : 4,
"vscan" : { "minimum" : 0.8333, "maximum" : 0.8667 }
"index" : 5,
"vscan" : { "minimum" : 0.8000, "maximum" : 0.8333 }
"index" : 6,
"vscan" : { "minimum" : 0.7667, "maximum" : 0.8000 }
"index" : 7,
"vscan" : { "minimum" : 0.7333, "maximum" : 0.7667 }
"index" : 8,
"vscan" : { "minimum" : 0.7000, "maximum" : 0.7333 }
"index" : 9,
"vscan" : { "minimum" : 0.6667, "maximum" : 0.7000 }
"index" : 10,
"vscan" : { "minimum" : 0.6333, "maximum" : 0.6667 }
"index" : 11,
"vscan" : { "minimum" : 0.6000, "maximum" : 0.6333 }
"index" : 12,
"vscan" : { "minimum" : 0.5667, "maximum" : 0.6000 }
"index" : 13,
"vscan" : { "minimum" : 0.5333, "maximum" : 0.5667 }
"index" : 14,
"vscan" : { "minimum" : 0.5000, "maximum" : 0.5333 }
"index" : 15,
"vscan" : { "minimum" : 0.4667, "maximum" : 0.5000 }
"index" : 16,
"vscan" : { "minimum" : 0.4333, "maximum" : 0.4667 }
"index" : 17,
"vscan" : { "minimum" : 0.4000, "maximum" : 0.4333 }
"index" : 18,
"vscan" : { "minimum" : 0.3667, "maximum" : 0.4000 }
"index" : 19,
"vscan" : { "minimum" : 0.3333, "maximum" : 0.3667 }
"index" : 20,
"vscan" : { "minimum" : 0.3000, "maximum" : 0.3333 }
"index" : 21,
"vscan" : { "minimum" : 0.2667, "maximum" : 0.3000 }
"index" : 22,
"vscan" : { "minimum" : 0.2333, "maximum" : 0.2667 }
"index" : 23,
"vscan" : { "minimum" : 0.2000, "maximum" : 0.2333 }
"index" : 24,
"vscan" : { "minimum" : 0.1667, "maximum" : 0.2000 }
"index" : 25,
"vscan" : { "minimum" : 0.1333, "maximum" : 0.1667 }
"index" : 26,
"vscan" : { "minimum" : 0.1000, "maximum" : 0.1333 }
"index" : 27,
"vscan" : { "minimum" : 0.0667, "maximum" : 0.1000 }
"index" : 28,
"vscan" : { "minimum" : 0.0333, "maximum" : 0.0667 }
"index" : 29,
"vscan" : { "minimum" : 0.0000, "maximum" : 0.0333 }
"index" : 30,
"hscan" : { "minimum" : 0.0000, "maximum" : 0.0192 },
"vscan" : { "minimum" : 0.0000, "maximum" : 0.0800 }
"index" : 31,
"hscan" : { "minimum" : 0.0192, "maximum" : 0.0385 },
"index" : 32,
"hscan" : { "minimum" : 0.0385, "maximum" : 0.0577 },
"index" : 33,
"hscan" : { "minimum" : 0.0577, "maximum" : 0.0769 },
"index" : 34,
"hscan" : { "minimum" : 0.0769, "maximum" : 0.0962 },
"index" : 35,
"hscan" : { "minimum" : 0.0962, "maximum" : 0.1154 },
"index" : 36,
"hscan" : { "minimum" : 0.1154, "maximum" : 0.1346 },
"index" : 37,
"hscan" : { "minimum" : 0.1346, "maximum" : 0.1538 },
"index" : 38,
"hscan" : { "minimum" : 0.1538, "maximum" : 0.1731 },
"index" : 39,
"hscan" : { "minimum" : 0.1731, "maximum" : 0.1923 },
"index" : 40,
"hscan" : { "minimum" : 0.1923, "maximum" : 0.2115 },
"index" : 41,
"hscan" : { "minimum" : 0.2115, "maximum" : 0.2308 },
"index" : 42,
"hscan" : { "minimum" : 0.2308, "maximum" : 0.2500 },
"index" : 43,
"hscan" : { "minimum" : 0.2500, "maximum" : 0.2692 },
"index" : 44,
"hscan" : { "minimum" : 0.2692, "maximum" : 0.2885 },
"index" : 45,
"hscan" : { "minimum" : 0.2885, "maximum" : 0.3077 },
"index" : 46,
"hscan" : { "minimum" : 0.3077, "maximum" : 0.3269 },
"index" : 47,
"hscan" : { "minimum" : 0.3269, "maximum" : 0.3462 },
"index" : 48,
"hscan" : { "minimum" : 0.3462, "maximum" : 0.3654 },
"index" : 49,
"hscan" : { "minimum" : 0.3654, "maximum" : 0.3846 },
"index" : 50,
"hscan" : { "minimum" : 0.3846, "maximum" : 0.4038 },
"index" : 51,
"hscan" : { "minimum" : 0.4038, "maximum" : 0.4231 },
"index" : 52,
"hscan" : { "minimum" : 0.4231, "maximum" : 0.4423 },
"index" : 53,
"hscan" : { "minimum" : 0.4423, "maximum" : 0.4615 },
"index" : 54,
"hscan" : { "minimum" : 0.4615, "maximum" : 0.4808 },
"index" : 55,
"hscan" : { "minimum" : 0.4808, "maximum" : 0.5000 },
"index" : 56,
"hscan" : { "minimum" : 0.5000, "maximum" : 0.5192 },
"index" : 57,
"hscan" : { "minimum" : 0.5192, "maximum" : 0.5385 },
"index" : 58,
"hscan" : { "minimum" : 0.5385, "maximum" : 0.5577 },
"index" : 59,
"hscan" : { "minimum" : 0.5577, "maximum" : 0.5769 },
"index" : 60,
"hscan" : { "minimum" : 0.5769, "maximum" : 0.5962 },
"index" : 61,
"hscan" : { "minimum" : 0.5962, "maximum" : 0.6154 },
"index" : 62,
"hscan" : { "minimum" : 0.6154, "maximum" : 0.6346 },
"index" : 63,
"hscan" : { "minimum" : 0.6346, "maximum" : 0.6538 },
"index" : 64,
"hscan" : { "minimum" : 0.6538, "maximum" : 0.6731 },
"index" : 65,
"hscan" : { "minimum" : 0.6731, "maximum" : 0.6923 },
"index" : 66,
"hscan" : { "minimum" : 0.6923, "maximum" : 0.7115 },
"index" : 67,
"hscan" : { "minimum" : 0.7115, "maximum" : 0.7308 },
"index" : 68,
"hscan" : { "minimum" : 0.7308, "maximum" : 0.7500 },
"index" : 69,
"hscan" : { "minimum" : 0.7500, "maximum" : 0.7692 },
"index" : 70,
"hscan" : { "minimum" : 0.7692, "maximum" : 0.7885 },
"index" : 71,
"hscan" : { "minimum" : 0.7885, "maximum" : 0.8077 },
"index" : 72,
"hscan" : { "minimum" : 0.8077, "maximum" : 0.8269 },
"index" : 73,
"hscan" : { "minimum" : 0.8269, "maximum" : 0.8462 },
"index" : 74,
"hscan" : { "minimum" : 0.8462, "maximum" : 0.8654 },
"index" : 75,
"hscan" : { "minimum" : 0.8654, "maximum" : 0.8846 },
"index" : 76,
"hscan" : { "minimum" : 0.8846, "maximum" : 0.9038 },
"index" : 77,
"hscan" : { "minimum" : 0.9038, "maximum" : 0.9231 },
"index" : 78,
"hscan" : { "minimum" : 0.9231, "maximum" : 0.9423 },
"index" : 79,
"hscan" : { "minimum" : 0.9423, "maximum" : 0.9615 },
"index" : 80,
"hscan" : { "minimum" : 0.9615, "maximum" : 0.9808 },
"index" : 81,
"hscan" : { "minimum" : 0.9808, "maximum" : 1.0000 },
"index" : 82,
"hscan" : { "minimum" : 0.9500, "maximum" : 1.0000 },
"index" : 83,
"index" : 84,
"index" : 85,
"index" : 86,
"index" : 87,
"index" : 88,
"index" : 89,
"index" : 90,
"index" : 91,
"index" : 92,
"index" : 93,
"index" : 94,
"index" : 95,
"index" : 96,
"index" : 97,
"index" : 98,
"index" : 99,
"index" : 100,
"index" : 101,
"index" : 102,
"index" : 103,
"index" : 104,
"index" : 105,
"index" : 106,
"index" : 107,
"index" : 108,
"index" : 109,
"index" : 110,
"index" : 111,
"index" : 112,
"vscan" : { "minimum" : 0.9200, "maximum" : 1.0000 }
"index" : 113,
"index" : 114,
"index" : 115,
"index" : 116,
"index" : 117,
"index" : 118,
"index" : 119,
"index" : 120,
"index" : 121,
"index" : 122,
"index" : 123,
"index" : 124,
"index" : 125,
"index" : 126,
"index" : 127,
"index" : 128,
"index" : 129,
"index" : 130,
"index" : 131,
"index" : 132,
"index" : 133,
"index" : 134,
"index" : 135,
"index" : 136,
"index" : 137,
"index" : 138,
"index" : 139,
"index" : 140,
"index" : 141,
"index" : 142,
"index" : 143,
"index" : 144,
"index" : 145,
"index" : 146,
"index" : 147,
"index" : 148,
"index" : 149,
"index" : 150,
"index" : 151,
"index" : 152,
"index" : 153,
"index" : 154,
"index" : 155,
"index" : 156,
"index" : 157,
"index" : 158,
"index" : 159,
"index" : 160,
"index" : 161,
"index" : 162,
"index" : 163,
/// The black border configuration, contains the following items:
/// * enable : true if the detector should be activated
/// * threshold : Value below which a pixel is regarded as black (value between 0.0 and 1.0)
"blackborderdetector" :
"enable" : true,
"threshold" : 0.06
/// The configuration of the effect engine, contains the following items:
/// * paths : An array with absolute location(s) of directories with effects
/// * bootsequence : The effect selected as 'boot sequence'
"effects" :
"paths" :
"/opt/hyperion/effects"
"bootsequence" :
"effect" : "Rainbow swirl fast",
"duration_ms" : 3000
/// The configuration for the frame-grabber, contains the following items:
/// * width : The width of the grabbed frames [pixels]
/// * height : The height of the grabbed frames [pixels]
/// * frequency_Hz : The frequency of the frame grab [Hz]
// "framegrabber" :
// "width" : 64,
// "height" : 64,
// "frequency_Hz" : 10.0
/// The configuration of the XBMC connection used to enable and disable the frame-grabber. Contains the following fields:
/// * xbmcAddress : The IP address of the XBMC-host
/// * xbmcTcpPort : The TCP-port of the XBMC-server
/// * grabVideo : Flag indicating that the frame-grabber is on(true) during video playback
/// * grabPictures : Flag indicating that the frame-grabber is on(true) during picture show
/// * grabAudio : Flag indicating that the frame-grabber is on(true) during audio playback
/// * grabMenu : Flag indicating that the frame-grabber is on(true) in the XBMC menu
/// * grabScreensaver : Flag indicating that the frame-grabber is on(true) when XBMC is on screensaver
/// * enable3DDetection : Flag indicating that the frame-grabber should switch to a 3D compatible modus if a 3D video is playing
// "xbmcVideoChecker" :
// "xbmcAddress" : "127.0.0.1",
// "xbmcTcpPort" : 9090,
// "grabVideo" : true,
// "grabPictures" : true,
// "grabAudio" : true,
// "grabMenu" : false,
// "grabScreensaver" : true,
// "enable3DDetection" : true
/// The configuration of the Json server which enables the json remote interface
/// * port : Port at which the json server is started
"jsonServer" :
"port" : 19444
/// The configuration of the Proto server which enables the protobuffer remote interface
/// * port : Port at which the protobuffer server is started
"protoServer" :
"port" : 19445
/// The configuration of the boblight server which enables the boblight remote interface
/// * port : Port at which the boblight server is started
// "boblightServer" :
// "port" : 19333
"grabber-v4l2" :
"device" : "/dev/video0",
"input" : 0,
"standard" : "PAL",
"width" : 720,
"height" : 576,
"frameDecimation" : 1,
"sizeDecimation" : 8,
"priority" : 1100,
"mode" : "2D",
"cropLeft" : 0,
"cropRight" : 5,
"cropTop" : 0,
"cropBottom" : 14,
"redSignalThreshold" : 0.1,
"greenSignalThreshold" : 0.1,
"blueSignalThreshold" : 0.1
"endOfJson" : "endOfJson"
[/php]
Alles anzeigen
