Hallo
würde gerne mal Pimatic probieren.
Habe es hiernach installiert
http://www.pimatic.org/guide/getting-started/installation/
Aber ich bekomme kein Webinterface zum laufen.
Hat einer erfahrung?
Gruss
Hallo
Gruss
Pimatic - Keine WebGUI? Schau mal ob du hier fündig wirst!
Das komplette Tutorial durch? Welche Fehlermeldungen erscheinen? was sagen die logs?
bei mir startet der Service nicht. Bitte um Hilfe.
Folgender Fehler:
sudo service pimatic start
Job for pimatic.service failed. See 'systemctl status pimatic.service' and 'journalctl -xn' for details.
systemctl:
pimatic.service loaded failed failed LSB: pimatic service
journalctl:
Logs begin at Mo 2016-06-06 20:59:08 CEST, end at Mo 2016-06-06 21:36:29 CEST
Jun 06 21:35:51 raspberrypi sudo[2698]: pi : TTY=pts/1 ; PWD=/home/pi ; USER=roo
Jun 06 21:35:51 raspberrypi sudo[2698]: pam_unix(sudo:session): session opened f
Jun 06 21:35:51 raspberrypi systemd[1]: Starting LSB: pimatic service...
-- Subject: Unit pimatic.service has begun with start-up
-- Defined-By: systemd
-- Support: http://lists.freedesktop.org/mailman/listinfo/systemd-devel
-- Unit pimatic.service has begun starting up.
Jun 06 21:35:51 raspberrypi pimatic[2719]: /etc/init.d/pimatic: 25: /etc/init.d/
Jun 06 21:35:51 raspberrypi systemd[1]: pimatic.service: control process exited,
Jun 06 21:35:51 raspberrypi systemd[1]: Failed to start LSB: pimatic service.
-- Subject: Unit pimatic.service has failed
-- Unit pimatic.service has failed.
-- The result is failed.
Jun 06 21:35:51 raspberrypi systemd[1]: Unit pimatic.service entered failed stat
Jun 06 21:35:51 raspberrypi sudo[2698]: pam_unix(sudo:session): session closed f
Jun 06 21:36:29 raspberrypi sudo[2725]: pi : TTY=pts/1 ; PWD=/home/pi ; USER=roo
Jun 06 21:36:29 raspberrypi sudo[2725]: pam_unix(sudo:session): session opened f
lines 1-23...skipping...
-- Logs begin at Mo 2016-06-06 20:59:08 CEST, end at Mo 2016-06-06 21:36:29 CEST. --
Jun 06 21:35:51 raspberrypi sudo[2698]: pi : TTY=pts/1 ; PWD=/home/pi ; USER=root ; COMMAND=/usr/sbin/service pimatic start
Jun 06 21:35:51 raspberrypi sudo[2698]: pam_unix(sudo:session): session opened for user root by (uid=0)
Jun 06 21:35:51 raspberrypi pimatic[2719]: /etc/init.d/pimatic: 25: /etc/init.d/pimatic: pimatic.js: not found
Jun 06 21:35:51 raspberrypi systemd[1]: pimatic.service: control process exited, code=exited status=127
Jun 06 21:35:51 raspberrypi systemd[1]: Unit pimatic.service entered failed state.
Jun 06 21:35:51 raspberrypi sudo[2698]: pam_unix(sudo:session): session closed for user root
Jun 06 21:36:29 raspberrypi sudo[2725]: pi : TTY=pts/1 ; PWD=/home/pi ; USER=root ; COMMAND=/bin/journalctl -xn
Jun 06 21:36:29 raspberrypi sudo[2725]: pam_unix(sudo:session): session opened for user root by (uid=0)
konnte den Fehler heute selbst beheben.
habe Pimatic noch mal installiert jedoch wieder kein erfolg.
Anscheinend wurde die sqlite nicht richtig installiert.
Lösung für mich war folgender Beitrag:
https://forum.pimatic.org/topic/1824/sol…talling-sqlite3
Kannst du genau sgen was du gemacht hast?
Hast du es nach anleitung installiert und dan einfach noch
sudo npm install sqlite3@3.1.3 --unsafe-perm
Nachinstalliert
Nachinstalliert
Hallo und Sorry für die späte Antwort.
Ja habe einfach SQLite nachinstalliert. dann hats geklappt.
MFG
