Hat jemand zufällig eine Idee, warum meine externe USB HDD immer wegfliegt?
Auch mitten in der Benutzung.
So eben z.B. geschehen.
Jemand eine Idee wo ich ansetzen kann?
Die HDD ist eine 2 TB 3,5" HDD mit eigenem Netzteil.
May 7 21:22:45 pi kernel: [ 2761.877237] usb 1-1.2.3: USB disconnect, device number 6
May 7 21:22:46 pi kernel: [ 2762.139764] Buffer I/O error on device sda1, logical block 165936335
May 7 21:22:46 pi kernel: [ 2762.139820] Buffer I/O error on device sda1, logical block 165936336
May 7 21:22:46 pi kernel: [ 2762.139852] Buffer I/O error on device sda1, logical block 165936337
May 7 21:22:46 pi kernel: [ 2762.139882] Buffer I/O error on device sda1, logical block 165936338
May 7 21:22:46 pi kernel: [ 2762.139911] Buffer I/O error on device sda1, logical block 165936339
May 7 21:22:46 pi kernel: [ 2762.139938] Buffer I/O error on device sda1, logical block 165936340
May 7 21:22:46 pi kernel: [ 2762.139967] Buffer I/O error on device sda1, logical block 165936341
May 7 21:22:46 pi kernel: [ 2762.139995] Buffer I/O error on device sda1, logical block 165936342
May 7 21:22:46 pi kernel: [ 2762.140024] Buffer I/O error on device sda1, logical block 165936343
May 7 21:22:46 pi kernel: [ 2762.140060] Buffer I/O error on device sda1, logical block 165936344
May 7 21:22:46 pi ntfs-3g[1239]: ntfs_attr_pread_i: ntfs_pread failed: Eingabe-/Ausgabefehler
May 7 21:22:46 pi ntfs-3g[1239]: ntfs_attr_pread error reading 'dateiname' at offset 499630080: 131072 <> -1: Eingabe-/Ausgabefehler
May 7 21:22:46 pi kernel: [ 2762.306169] usb 1-1.2.3: new high-speed USB device number 7 using dwc_otg
May 7 21:22:46 pi kernel: [ 2762.386382] usb 1-1.2.3: device descriptor read/64, error -71
May 7 21:22:46 pi kernel: [ 2762.638493] usb 1-1.2.3: New USB device found, idVendor=174c, idProduct=5106
May 7 21:22:46 pi kernel: [ 2762.638525] usb 1-1.2.3: New USB device strings: Mfr=2, Product=3, SerialNumber=1
May 7 21:22:46 pi kernel: [ 2762.638541] usb 1-1.2.3: Product: AS2105
May 7 21:22:46 pi kernel: [ 2762.638554] usb 1-1.2.3: Manufacturer: ASMedia
May 7 21:22:46 pi kernel: [ 2762.638567] usb 1-1.2.3: SerialNumber: W241A158
May 7 21:22:46 pi kernel: [ 2762.652358] scsi1 : usb-storage 1-1.2.3:1.0
Display More
Das sind meine Geräte:
Bus 001 Device 002: ID 0424:9512 Standard Microsystems Corp.
Bus 001 Device 003: ID 0424:ec00 Standard Microsystems Corp.
Bus 001 Device 004: ID 1a40:0101 Terminus Technology Inc. 4-Port HUB
Bus 001 Device 005: ID 051d:0002 American Power Conversion Uninterruptible Power Supply
Bus 001 Device 006: ID 174c:5106 ASMedia Technology Inc. Transcend StoreJet 25M3
Im Detail:
Couldn't open device, some information will be missing
Device Descriptor:
bLength 18
bDescriptorType 1
bcdUSB 2.10
bDeviceClass 0 (Defined at Interface level)
bDeviceSubClass 0
bDeviceProtocol 0
bMaxPacketSize0 64
idVendor 0x174c ASMedia Technology Inc.
idProduct 0x5106 Transcend StoreJet 25M3
bcdDevice 0.01
iManufacturer 2
iProduct 3
iSerial 1
bNumConfigurations 1
Configuration Descriptor:
bLength 9
bDescriptorType 2
wTotalLength 32
bNumInterfaces 1
bConfigurationValue 1
iConfiguration 0
bmAttributes 0xc0
Self Powered
MaxPower 0mA
Interface Descriptor:
bLength 9
bDescriptorType 4
bInterfaceNumber 0
bAlternateSetting 0
bNumEndpoints 2
bInterfaceClass 8 Mass Storage
bInterfaceSubClass 6 SCSI
bInterfaceProtocol 80 Bulk-Only
iInterface 0
Endpoint Descriptor:
bLength 7
bDescriptorType 5
bEndpointAddress 0x81 EP 1 IN
bmAttributes 2
Transfer Type Bulk
Synch Type None
Usage Type Data
wMaxPacketSize 0x0200 1x 512 bytes
bInterval 0
bLength 7
bDescriptorType 5
bEndpointAddress 0x02 EP 2 OUT
bmAttributes 2
Transfer Type Bulk
Synch Type None
Usage Type Data
bInterval 0
Display More
smartctl hat keine Fehler gefunden. Die Platte ist fast neu und macht an Windows 7 keine Probleme.
