Hallo zusammen,
ich habe ein Problem mit Munin.
Raspbian (Wheezy) installation, Nginx, wobei Nginx hier erstmal noch nicht im Spiel ist.
Ich habe folgende Fehlermeldung im Log:
munin@pi2:/var/log/munin$ cat munin-html.log
2015/08/08 17:37:14 [PERL WARNING] Use of uninitialized value in list assignment at /usr/share/perl5/Munin/Master/Utils.pm line 112.
2015/08/08 17:42:15 [PERL WARNING] Use of uninitialized value in list assignment at /usr/share/perl5/Munin/Master/Utils.pm line 112.
2015/08/08 17:47:14 [PERL WARNING] Use of uninitialized value in list assignment at /usr/share/perl5/Munin/Master/Utils.pm line 112.
2015/08/08 17:52:14 [PERL WARNING] Use of uninitialized value in list assignment at /usr/share/perl5/Munin/Master/Utils.pm line 112.
2015/08/08 17:57:14 [PERL WARNING] Use of uninitialized value in list assignment at /usr/share/perl5/Munin/Master/Utils.pm line 112.
munin@pi2:/var/log/munin$ cat munin-update.log
2015/08/08 17:57:02 [INFO] Remaining workers: localdomain;localhost.localdomain
2015/08/08 17:57:10 [FATAL] Socket read from localhost.localdomain failed. Terminating process. at /usr/share/perl5/Munin/Master/UpdateWorker.pm line 254
2015/08/08 17:57:10 [ERROR] Munin::Master::UpdateWorker<localdomain;localhost.localdomain> died with '[FATAL] Socket read from localhost.localdomain failed. Terminating process. at /usr/share/perl5/Munin/Master/UpdateWorker.pm line 254
2015/08/08 17:57:12 [INFO] Remaining workers: localdomain;localhost.localdomain
2015/08/08 17:57:12 [INFO] Reaping Munin::Master::UpdateWorker<localdomain;localhost.localdomain>. Exit value/signal: 18/0
2015/08/08 17:57:12 [INFO] No old data available for failed worker localdomain;localhost.localdomain. This node will disappear from the html web page hierarchy
2015/08/08 17:57:12 [INFO]: Munin-update finished (130.04 sec)
Alles anzeigen
Das WWW Dir, welches ich erstmal auf /var/cache/munin/www gelassen habe bleibt auch leer.
Ich habe auch noch keine Anpassungen an der Config unter /etc/munin gemacht. Ebenfalls bringt es nichts, wenn ich munin-cron von Hand starte.
Auf dem RaPi 1 B+ hat es auf anhieb funktioniert, jetzt hier auf dem RaPi 2 B scheint es Probleme zu geben.
Ich habe auch schon auf Google gesucht, bin aber auf keine Lösung gekommen.
Hat jemand einen Tipp?
