Hallo zusammen,
nachdem ich zuvor massive Hardwareprobleme mit der SD-Card hatte (SD-Card-Problem), startet jetzt der PI wenigstens wieder.
Jetzt macht nur die WLAN-Dongle-Einstellung ein Problem.
Also Sleepmode wurde schon ausgestellt... aber
irgendwie geht der DHCP nicht.
Hier der Auszug aus dem dmesg-Protokoll:
dmesg
[ 0.000000] Booting Linux on physical CPU 0xf00
[ 0.000000] Initializing cgroup subsys cpu
[ 0.000000] Initializing cgroup subsys cpuacct
[ 0.000000] Linux version 3.18.11-v7+ (dc4@dc4-XPS13-9333) (gcc version 4.8.3 20140303 (prerelease) (crosstool-NG linaro-1.13.1+bzr2650 - Linaro GCC 2014.03) ) #781 SMP PREEMPT Tue Apr 21 18:07:59 BST 2015
[ 0.000000] CPU: ARMv7 Processor [410fc075] revision 5 (ARMv7), cr=10c5387d
[ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
[ 0.000000] Machine model: Raspberry Pi 2 Model B
[ 0.000000] cma: Reserved 8 MiB at 0x3a800000
[ 0.000000] Memory policy: Data cache writealloc
[ 0.000000] On node 0 totalpages: 241664
[ 0.000000] free_area_init_node: node 0, pgdat 8080f480, node_mem_map ba093000
[ 0.000000] Normal zone: 1888 pages used for memmap
[ 0.000000] Normal zone: 0 pages reserved
[ 0.000000] Normal zone: 241664 pages, LIFO batch:31
[ 0.000000] [bcm2709_smp_init_cpus] enter (8620->f3003010)
[ 0.000000] [bcm2709_smp_init_cpus] ncores=4
[ 0.000000] PERCPU: Embedded 10 pages/cpu @ba061000 s11456 r8192 d21312 u40960
[ 0.000000] pcpu-alloc: s11456 r8192 d21312 u40960 alloc=10*4096
[ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 239776
[ 0.000000] Kernel command line: dma.dmachans=0x7f35 bcm2708_fb.fbwidth=1824 bcm2708_fb.fbheight=984 bcm2709.boardrev=0xa21041 bcm2709.serial=0xcdfa91a6 smsc95xx.macaddr=B8:27:EB:FA:91:A6 bcm2708_fb.fbswap=1 bcm2709.disk_led_gpio=47 bcm2709.disk_led_active_low=0 sdhci-bcm2708.emmc_clock_freq=250000000 vc_mem.mem_base=0x3dc00000 vc_mem.mem_size=0x3f000000 dwc_otg.lpm_enable=0 console=ttyAMA0,115200 console=tty1 root=/dev/mmcblk0p2 rootfstype=ext4 elevator=deadline rootwait
[ 0.000000] PID hash table entries: 4096 (order: 2, 16384 bytes)
[ 0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
[ 0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
[ 0.000000] Memory: 940832K/966656K available (5722K kernel code, 397K rwdata, 1748K rodata, 384K init, 763K bss, 25824K reserved)
[ 0.000000] Virtual kernel memory layout:
[ 0.000000] vector : 0xffff0000 - 0xffff1000 ( 4 kB)
[ 0.000000] fixmap : 0xffc00000 - 0xffe00000 (2048 kB)
[ 0.000000] vmalloc : 0xbb800000 - 0xff000000 (1080 MB)
[ 0.000000] lowmem : 0x80000000 - 0xbb000000 ( 944 MB)
[ 0.000000] modules : 0x7f000000 - 0x80000000 ( 16 MB)
[ 0.000000] .text : 0x80008000 - 0x80753a48 (7471 kB)
[ 0.000000] .init : 0x80754000 - 0x807b4000 ( 384 kB)
[ 0.000000] .data : 0x807b4000 - 0x808174bc ( 398 kB)
[ 0.000000] .bss : 0x808174bc - 0x808d6254 ( 764 kB)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[ 0.000000] Preemptible hierarchical RCU implementation.
[ 0.000000] NR_IRQS:608
[ 0.000000] Architected cp15 timer(s) running at 19.20MHz (virt).
[ 0.000014] sched_clock: 56 bits at 19MHz, resolution 52ns, wraps every 3579139424256ns
[ 0.000036] Switching to timer-based delay loop, resolution 52ns
[ 0.000333] Console: colour dummy device 80x30
[ 0.001756] console [tty1] enabled
[ 0.001805] Calibrating delay loop (skipped), value calculated using timer frequency.. 38.40 BogoMIPS (lpj=192000)
[ 0.001887] pid_max: default: 32768 minimum: 301
[ 0.002286] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.002345] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.003616] Initializing cgroup subsys memory
[ 0.003706] Initializing cgroup subsys devices
[ 0.003760] Initializing cgroup subsys freezer
[ 0.003810] Initializing cgroup subsys net_cls
[ 0.003873] Initializing cgroup subsys blkio
[ 0.003983] CPU: Testing write buffer coherency: ok
[ 0.004097] ftrace: allocating 19614 entries in 58 pages
[ 0.052556] CPU0: update cpu_capacity 1024
[ 0.052633] CPU0: thread -1, cpu 0, socket 15, mpidr 80000f00
[ 0.052674] [bcm2709_smp_prepare_cpus] enter
[ 0.052827] Setting up static identity map for 0x528478 - 0x5284ac
[ 0.112464] [bcm2709_boot_secondary] cpu:1 started (0) 16
[ 0.112777] CPU1: Booted secondary processor
[ 0.112786] [bcm2709_secondary_init] enter cpu:1
[ 0.112838] CPU1: update cpu_capacity 1024
[ 0.112847] CPU1: thread -1, cpu 1, socket 15, mpidr 80000f01
[ 0.132443] [bcm2709_boot_secondary] cpu:2 started (0) 18
[ 0.132695] CPU2: Booted secondary processor
[ 0.132702] [bcm2709_secondary_init] enter cpu:2
[ 0.132734] CPU2: update cpu_capacity 1024
[ 0.132743] CPU2: thread -1, cpu 2, socket 15, mpidr 80000f02
[ 0.152520] [bcm2709_boot_secondary] cpu:3 started (0) 17
[ 0.152759] CPU3: Booted secondary processor
[ 0.152766] [bcm2709_secondary_init] enter cpu:3
[ 0.152796] CPU3: update cpu_capacity 1024
[ 0.152804] CPU3: thread -1, cpu 3, socket 15, mpidr 80000f03
[ 0.152899] Brought up 4 CPUs
[ 0.153021] SMP: Total of 4 processors activated (153.60 BogoMIPS).
[ 0.153054] CPU: All CPU(s) started in SVC mode.
[ 0.154060] devtmpfs: initialized
[ 0.178885] VFP support v0.3: implementor 41 architecture 2 part 30 variant 7 rev 5
[ 0.180873] pinctrl core: initialized pinctrl subsystem
[ 0.183985] NET: Registered protocol family 16
[ 0.189608] DMA: preallocated 4096 KiB pool for atomic coherent allocations
[ 0.190782] bcm2709.uart_clock = 3000000
[ 0.193561] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[ 0.193615] hw-breakpoint: maximum watchpoint size is 8 bytes.
[ 0.193669] mailbox: Broadcom VideoCore Mailbox driver
[ 0.193801] bcm2708_vcio: mailbox at f300b880
[ 0.194158] bcm_power: Broadcom power driver
[ 0.194195] bcm_power_open() -> 0
[ 0.194221] bcm_power_request(0, 8)
[ 0.694900] bcm_mailbox_read -> 00000080, 0
[ 0.694932] bcm_power_request -> 0
[ 0.695075] Serial: AMBA PL011 UART driver
[ 0.695223] dev:f1: ttyAMA0 at MMIO 0x3f201000 (irq = 83, base_baud = 0) is a PL011 rev3
[ 1.203509] console [ttyAMA0] enabled
[ 1.275715] SCSI subsystem initialized
[ 1.279728] usbcore: registered new interface driver usbfs
[ 1.285395] usbcore: registered new interface driver hub
[ 1.290866] usbcore: registered new device driver usb
[ 1.297773] Switched to clocksource arch_sys_counter
[ 1.333426] FS-Cache: Loaded
[ 1.336655] CacheFiles: Loaded
[ 1.351196] NET: Registered protocol family 2
[ 1.356849] TCP established hash table entries: 8192 (order: 3, 32768 bytes)
[ 1.364105] TCP bind hash table entries: 8192 (order: 4, 65536 bytes)
[ 1.370807] TCP: Hash tables configured (established 8192 bind 8192)
[ 1.377280] TCP: reno registered
[ 1.380558] UDP hash table entries: 512 (order: 2, 16384 bytes)
[ 1.386544] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
[ 1.393278] NET: Registered protocol family 1
[ 1.398314] RPC: Registered named UNIX socket transport module.
[ 1.404256] RPC: Registered udp transport module.
[ 1.409030] RPC: Registered tcp transport module.
[ 1.413748] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 1.421177] hw perfevents: enabled with armv7_cortex_a7 PMU driver, 5 counters available
[ 1.429587] bcm2708_dma: DMA manager at f3007000
[ 1.434378] vc-mem: phys_addr:0x00000000 mem_base=0x3dc00000 mem_size:0x3f000000(1008 MiB)
[ 1.444192] futex hash table entries: 1024 (order: 4, 65536 bytes)
[ 1.450715] audit: initializing netlink subsys (disabled)
[ 1.456188] audit: type=2000 audit(1.239:1): initialized
[ 1.477746] VFS: Disk quotas dquot_6.5.2
[ 1.482105] Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[ 1.491665] FS-Cache: Netfs 'nfs' registered for caching
[ 1.498086] NFS: Registering the id_resolver key type
[ 1.503216] Key type id_resolver registered
[ 1.507411] Key type id_legacy registered
[ 1.512612] msgmni has been set to 1853
[ 1.518369] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 252)
[ 1.525974] io scheduler noop registered
[ 1.529956] io scheduler deadline registered (default)
[ 1.535422] io scheduler cfq registered
[ 1.541881] BCM2708FB: allocated DMA memory fac00000
[ 1.546897] BCM2708FB: allocated DMA channel 0 @ f3007000
[ 1.581791] Console: switching to colour frame buffer device 228x61
[ 1.606687] bcm2708-dmaengine bcm2708-dmaengine: Load BCM2835 DMA engine driver
[ 1.614468] uart-pl011 dev:f1: no DMA platform data
[ 1.620021] vc-cma: Videocore CMA driver
[ 1.624029] vc-cma: vc_cma_base = 0x00000000
[ 1.628893] vc-cma: vc_cma_size = 0x00000000 (0 MiB)
[ 1.634393] vc-cma: vc_cma_initial = 0x00000000 (0 MiB)
[ 1.651703] brd: module loaded
[ 1.660565] loop: module loaded
[ 1.664117] vchiq: vchiq_init_state: slot_zero = 0xba800000, is_master = 0
[ 1.672034] Loading iSCSI transport class v2.0-870.
[ 1.678080] usbcore: registered new interface driver smsc95xx
[ 1.684010] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
[ 1.890242] Core Release: 2.80a
[ 1.893462] Setting default values for core params
[ 1.898413] Finished setting default values for core params
[ 2.104485] Using Buffer DMA mode
[ 2.107894] Periodic Transfer Interrupt Enhancement - disabled
[ 2.113831] Multiprocessor Interrupt Enhancement - disabled
[ 2.119524] OTG VER PARAM: 0, OTG VER FLAG: 0
[ 2.123969] Dedicated Tx FIFOs mode
[ 2.127922] WARN::dwc_otg_hcd_init:1047: FIQ DMA bounce buffers: virt = 0xbac14000 dma = 0xfac14000 len=9024
[ 2.137979] FIQ FSM acceleration enabled for :
[ 2.137979] Non-periodic Split Transactions
[ 2.137979] Periodic Split Transactions
[ 2.137979] High-Speed Isochronous Endpoints
[ 2.154975] dwc_otg: Microframe scheduler enabled
[ 2.155041] WARN::hcd_init_fiq:412: FIQ on core 1 at 0x803d98b4
[ 2.165757] WARN::hcd_init_fiq:413: FIQ ASM at 0x803d9c10 length 36
[ 2.176745] WARN::hcd_init_fiq:438: MPHI regs_base at 0xbb80a000
[ 2.187477] dwc_otg bcm2708_usb: DWC OTG Controller
[ 2.197107] dwc_otg bcm2708_usb: new USB bus registered, assigned bus number 1
[ 2.209134] dwc_otg bcm2708_usb: irq 32, io mem 0x00000000
[ 2.219456] Init: Port Power? op_state=1
[ 2.228154] Init: Power Port (0)
[ 2.236353] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 2.247904] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.259896] usb usb1: Product: DWC OTG Controller
[ 2.269297] usb usb1: Manufacturer: Linux 3.18.11-v7+ dwc_otg_hcd
[ 2.280073] usb usb1: SerialNumber: bcm2708_usb
[ 2.290145] hub 1-0:1.0: USB hub found
[ 2.298607] hub 1-0:1.0: 1 port detected
[ 2.307534] dwc_otg: FIQ enabled
[ 2.307548] dwc_otg: NAK holdoff enabled
[ 2.307560] dwc_otg: FIQ split-transaction FSM enabled
[ 2.307599] Module dwc_common_port init
[ 2.308059] usbcore: registered new interface driver usb-storage
[ 2.319048] mousedev: PS/2 mouse device common for all mice
[ 2.329937] bcm2835-cpufreq: min=600000 max=900000
[ 2.339715] sdhci: Secure Digital Host Controller Interface driver
[ 2.350502] sdhci: Copyright(c) Pierre Ossman
[ 2.359680] DMA channels allocated for the MMC driver
[ 2.397816] Load BCM2835 MMC driver
[ 2.412820] sdhci-pltfm: SDHCI platform and OF driver helper
[ 2.423776] ledtrig-cpu: registered to indicate activity on CPUs
[ 2.434637] hidraw: raw HID events driver (C) Jiri Kosina
[ 2.445996] usbcore: registered new interface driver usbhid
[ 2.457269] usbhid: USB HID core driver
[ 2.467079] TCP: cubic registered
[ 2.475080] Initializing XFRM netlink socket
[ 2.484061] NET: Registered protocol family 17
[ 2.493321] Key type dns_resolver registered
[ 2.502623] Registering SWP/SWPB emulation handler
[ 2.507923] Indeed it is in host mode hprt0 = 00021501
[ 2.522678] registered taskstats version 1
[ 2.531593] vc-sm: Videocore shared memory driver
[ 2.540929] [vc_sm_connected_init]: start
[ 2.550291] [vc_sm_connected_init]: end - returning 0
[ 2.561338] Waiting for root device /dev/mmcblk0p2...
[ 2.575469] mmc0: host does not support reading read-only switch, assuming write-enable
[ 2.590965] mmc0: new high speed SDHC card at address 0007
[ 2.601938] mmcblk0: mmc0:0007 SD08G 7.42 GiB
[ 2.612963] mmcblk0: p1 p2
[ 2.687889] usb 1-1: new high-speed USB device number 2 using dwc_otg
[ 2.699354] Indeed it is in host mode hprt0 = 00001101
[ 2.700626] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
[ 2.700682] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
[ 2.702300] devtmpfs: mounted
[ 2.703064] Freeing unused kernel memory: 384K (80754000 - 807b4000)
[ 2.948230] usb 1-1: New USB device found, idVendor=0424, idProduct=9514
[ 2.959931] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 2.973030] hub 1-1:1.0: USB hub found
[ 2.981766] hub 1-1:1.0: 5 ports detected
[ 3.268018] usb 1-1.1: new high-speed USB device number 3 using dwc_otg
[ 3.378356] usb 1-1.1: New USB device found, idVendor=0424, idProduct=ec00
[ 3.391211] usb 1-1.1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 3.407402] smsc95xx v1.0.4
[ 3.472089] smsc95xx 1-1.1:1.0 eth0: register 'smsc95xx' at usb-bcm2708_usb-1.1, smsc95xx USB 2.0 Ethernet, b8:27:eb:fa:91:a6
[ 3.728077] usb 1-1.2: new low-speed USB device number 4 using dwc_otg
[ 3.888751] usb 1-1.2: New USB device found, idVendor=0518, idProduct=0001
[ 3.901493] usb 1-1.2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 3.914529] usb 1-1.2: Product: USB-compliant keyboard
[ 3.925255] usb 1-1.2: Manufacturer: Plus More Enterprise LTD.
[ 3.949718] input: Plus More Enterprise LTD. USB-compliant keyboard as /devices/platform/bcm2708_usb/usb1/1-1/1-1.2/1-1.2:1.0/0003:0518:0001.0001/input/input0
[ 3.970209] hid-generic 0003:0518:0001.0001: input,hidraw0: USB HID v1.10 Keyboard [Plus More Enterprise LTD. USB-compliant keyboard] on usb-bcm2708_usb-1.2/input0
[ 3.972854] udevd[175]: starting version 175
[ 4.015564] input: Plus More Enterprise LTD. USB-compliant keyboard as /devices/platform/bcm2708_usb/usb1/1-1/1-1.2/1-1.2:1.1/0003:0518:0001.0002/input/input1
[ 4.037021] hid-generic 0003:0518:0001.0002: input,hidraw1: USB HID v1.10 Mouse [Plus More Enterprise LTD. USB-compliant keyboard] on usb-bcm2708_usb-1.2/input1
[ 4.298105] usb 1-1.3: new low-speed USB device number 5 using dwc_otg
[ 4.444159] usb 1-1.3: New USB device found, idVendor=15ca, idProduct=00c3
[ 4.459777] usb 1-1.3: New USB device strings: Mfr=0, Product=2, SerialNumber=0
[ 4.479540] usb 1-1.3: Product: USB Optical Mouse
[ 4.506850] input: USB Optical Mouse as /devices/platform/bcm2708_usb/usb1/1-1/1-1.3/1-1.3:1.0/0003:15CA:00C3.0003/input/input2
[ 4.533502] hid-generic 0003:15CA:00C3.0003: input,hidraw2: USB HID v1.10 Mouse [USB Optical Mouse] on usb-bcm2708_usb-1.3/input0
[ 4.648066] usb 1-1.4: new full-speed USB device number 6 using dwc_otg
[ 4.794662] usb 1-1.4: New USB device found, idVendor=03eb, idProduct=204b
[ 4.813305] usb 1-1.4: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 4.828713] usb 1-1.4: Product: CUL868
[ 4.841055] usb 1-1.4: Manufacturer: busware.de
[ 4.938063] usb 1-1.5: new high-speed USB device number 7 using dwc_otg
[ 5.069406] usb 1-1.5: New USB device found, idVendor=0bda, idProduct=8176
[ 5.083195] usb 1-1.5: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 5.097293] usb 1-1.5: Product: 802.11n WLAN Adapter
[ 5.109036] usb 1-1.5: Manufacturer: Realtek
[ 5.120066] usb 1-1.5: SerialNumber: 00e04c000001
[ 5.131404] random: nonblocking pool is initialized
[ 5.234029] cdc_acm 1-1.4:1.0: ttyACM0: USB ACM device
[ 5.248505] usbcore: registered new interface driver cdc_acm
[ 5.261597] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
[ 5.440665] usbcore: registered new interface driver rtl8192cu
[ 6.922979] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
[ 7.193383] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
[ 12.571836] smsc95xx 1-1.1:1.0 eth0: hardware isn't capable of remote wakeup
[ 13.977083] smsc95xx 1-1.1:1.0 eth0: link up, 100Mbps, full-duplex, lpa 0x51E1
[ 76.280100] Adding 102396k swap on /var/swap. Priority:-1 extents:2 across:2134012k SSFS
Alles anzeigen
Ich finde dazu in der dmesg-Meldung leider nix. Evtl. kann mir jemand weiterhelfen.
Auf dem Bildschirm habe ich Meldungen vorbeihuschen gesehen, wo die wpa_supplicant bzw. die interfaces ein Problem machte.
Also direkt auch diese beiden Dateien für euch.
/etc/network/interfaces:
auto lo
iface lo inet loopback
iface eth0 inet dhcp
auto wlan0
allow-hotplug wlan0
iface wlan0 inet dhcp
wpa-conf /etc/wpa_supplicant/wpa_supplicant.conf
iface default inet dhcp
und die /etc/wpa_supplicant/wpa_supplicant.conf:
ctrl_interface=DIR=/var/run/wpa_supplicant GROUP=netdev
update_config=1
network={
ssid="MEINE SSID zuhause"
psk="MEIN PASSWORT vom WLAN mit der SSID zuhause"
proto=RSN
key_mgmt=WPA-PSK
pairwise=CCMP
auth_log=OPEN
Alles anzeigen
SSID und PSK habe ich mit der Fritzbox abgeglichen.
seht ihr irgendwo einen Fehler?
