Ich versuche seit ~2 Tagen MiniDLNA 1.1.5 zum laufen zu bekommen ... 0o
Den Server bekomme ich gestartet, diesen sehe ich auch auf meinen LG und Smartphone.
Nur zeigt das Zeil mir keine Datein an ( Bilder Musik Videos )
Naja erstmal meine Daten :
Raspi2
Raspbian Jessie
MiniDLNA 1.1.5
USB Festplatte 1Tera ( NTFS )
Verwendete Programme :
Win 7 - RemoteDesktop
Putty
Filezilla
Zuletzt habe ich es so instaliert :
[code=php]echo "deb-src http://archive.raspbian.org/raspbian jessie main contrib non-free" | sudo tee -a /etc/apt/sources.list[/php]
[code=php]sudo apt-get update[/php]
[code=php]sudo apt-get upgrade[/php]
[code=php]sudo apt-get build-dep minidlna -y[/php]
[code=php]wget http://sourceforge.net/projects/minid…na-1.1.5.tar.gz[/php]
[code=php]tar -xvf minidlna-1.1.5.tar.gz[/php]
[code=php]cd minidlna-1.1.5[/php]
[code=php]./configure && make && sudo make install[/php]
[code=php]sudo cp minidlna.conf /etc/[/php]
[code=php]sudo cp linux/minidlna.init.d.script /etc/init.d/minidlna[/php]
[code=php]sudo chmod +x /etc/init.d/minidlna[/php]
[code=php]sudo update-rc.d minidlna defaults[/php]
[code=php]sudo nano /etc/minidlna.conf[/php]
die config sieht jetzt so aus :
[code=php]# port for HTTP (descriptions, SOAP, media transfer) traffic
port=8200
# network interfaces to serve, comma delimited
#network_interface=eth0
# specify the user account name or uid to run as
#user=jmaggard
# set this to the directory you want scanned.
# * if you want multiple directories, you can have multiple media_dir= lines
# * if you want to restrict a media_dir to specific content types, you
# can prepend the types, followed by a comma, to the directory:
# + "A" for audio (eg. media_dir=A,/home/jmaggard/Music)
# + "V" for video (eg. media_dir=V,/home/jmaggard/Videos)
# + "P" for images (eg. media_dir=P,/home/jmaggard/Pictures)
# + "PV" for pictures and video (eg. media_dir=PV,/home/jmaggard/digital_camera)
#media_dir=/opt
media_dir=V,/media/pi/externe/Movies
media_dir=V,/media/pi/externe/TV
media_dir=A,/media/pi/externe/Music
media_dir=P,/media/pi/externe/Pictures
media_dir=PV,/media/pi/externe/Digital_camera
# set this to merge all media_dir base contents into the root container
# note: the default is no
#merge_media_dirs=no
# set this if you want to customize the name that shows up on your clients
friendly_name=RasPi2 Media Server
# set this if you would like to specify the directory where you want MiniDLNA to store its database and album art cache
#db_dir=/var/cache/minidlna
# set this if you would like to specify the directory where you want MiniDLNA to store its log file
#log_dir=/var/log
# set this to change the verbosity of the information that is logged
# each section can use a different level: off, fatal, error, warn, info, or debug
#log_level=general,artwork,database,inotify,scanner,metadata,http,ssdp,tivo=warn
# this should be a list of file names to check for when searching for album art
# note: names should be delimited with a forward slash ("/")
album_art_names=http://Cover.jpg/cover.jpg/AlbumArtSmall.jpg/albumartsmall.jpg/AlbumArt.jpg/albumart.jpg/Album.jpg/album.jpg/Folder.jpg/folder.jpg/Thumb.jpg/thumb.jpg
# set this to no to disable inotify monitoring to automatically discover new files
# note: the default is yes
inotify=yes
# set this to yes to enable support for streaming .jpg and .mp3 files to a TiVo supporting HMO
enable_tivo=no
# set this to strictly adhere to DLNA standards.
# * This will allow server-side downscaling of very large JPEG images,
# which may hurt JPEG serving performance on (at least) Sony DLNA products.
strict_dlna=no
# default presentation url is http address on port 80
#presentation_url=http://www.mylan/index.php
# notify interval in seconds. default is 895 seconds.
notify_interval=900
# serial and model number the daemon will report to clients
# in its XML description
serial=12345678
model_number=1
# specify the path to the MiniSSDPd socket
#minissdpdsocket=/var/run/minissdpd.sock
# use different container as root of the tree
# possible values:
# + "." - use standard container (this is the default)
# + "B" - "Browse Directory"
# + "M" - "Music"
# + "V" - "Video"
# + "P" - "Pictures"
# + Or, you can specify the ObjectID of your desired root container (eg. 1$F for Music/Playlists)
# if you specify "B" and client device is audio-only then "Music/Folders" will be used as root
#root_container=.
# always force SortCriteria to this value, regardless of the SortCriteria passed by the client
#force_sort_criteria=+upnp:class,+upnp:originalTrackNumber,+dc:title
# maximum number of simultaneous connections
# note: many clients open several simultaneous connections while streaming
#max_connections=50[/php]
Dan alles neugestartet :
[code=php]sudo service minidlna restart[/php]
[code=php]sudo service minidlna force-reload[/php]
[code=php]sudo reboot[/php]
Und wie gesagt der Sever Funktioniert, nur zeigt es mir keine Datein an.
Ich bedanke mich schonmal für die Hilfe ::)
