Hallo
ein schlichtes
führt bei mir auf eine Eception bein installieren, aber das Modul ist installiert ... führt aber seinerseits beim
auf eine Fehlermeldung..... (dieselbe wie hier beim installieren:
pi@raspberrypi ~ $ sudo pip-3.2 install statistics
Downloading/unpacking statistics
Downloading statistics-1.0.3.5.tar.gz
Running setup.py egg_info for package statistics
Downloading/unpacking docutils>=0.3 (from statistics)
Running setup.py egg_info for package docutils
warning: no files found matching 'MANIFEST'
warning: no files found matching '*' under directory 'extras'
warning: no previously-included files matching '.cvsignore' found under directory '*'
warning: no previously-included files matching '*.pyc' found under directory '*'
warning: no previously-included files matching '*~' found under directory '*'
warning: no previously-included files matching '.DS_Store' found under directory '*'
Installing collected packages: statistics, docutils
Running setup.py install for statistics
File "/usr/local/lib/python3.2/dist-packages/statistics/__init__.py", line 94
u"""
Basic statistics module.
This module provides functions for calculating statistics of data, including
averages, variance, and standard deviation.
Calculating averages
Function Description
mean Arithmetic mean (average) of data.
median Median (middle value) of data.
median_low Low median of data.
median_high High median of data.
median_grouped Median, or 50th percentile, of grouped data.
mode Mode (most common value) of data.
Calculate the arithmetic mean ("the average") of data:
>>> mean([-1.0, 2.5, 3.25, 5.75])
2.625
Calculate the standard median of discrete data:
>>> median([2, 3, 4, 5])
3.5
Calculate the median, or 50th percentile, of data grouped into class intervals
centred on the data values provided. E.g. if your data points are rounded to
the nearest whole number:
>>> median_grouped([2, 2, 3, 3, 3, 4]) #doctest: +ELLIPSIS
2.8333333333...
This should be interpreted in this way: you have two data points in the class
interval 1.5-2.5, three data points in the class interval 2.5-3.5, and one in
the class interval 3.5-4.5. The median of these data points is 2.8333...
Calculating variability or spread
pvariance Population variance of data.
variance Sample variance of data.
pstdev Population standard deviation of data.
stdev Sample standard deviation of data.
Calculate the standard deviation of sample data:
>>> stdev([2.5, 3.25, 5.5, 11.25, 11.75]) #doctest: +ELLIPSIS
4.38961843444...
If you have previously calculated the mean, you can pass it as the optional
second argument to the four "spread" functions to avoid recalculating it:
>>> data = [1, 2, 2, 4, 4, 4, 5, 6]
>>> mu = mean(data)
>>> pvariance(data, mu)
2.5
Exceptions
A single exception is defined: StatisticsError is a subclass of ValueError.
SyntaxError: invalid syntax
Running setup.py install for docutils
copy/convert test suite
changing mode of build/scripts-3.2/rst2html.py from 644 to 755
changing mode of build/scripts-3.2/rst2s5.py from 644 to 755
changing mode of build/scripts-3.2/rst2latex.py from 644 to 755
changing mode of build/scripts-3.2/rst2xetex.py from 644 to 755
changing mode of build/scripts-3.2/rst2man.py from 644 to 755
changing mode of build/scripts-3.2/rst2xml.py from 644 to 755
changing mode of build/scripts-3.2/rst2pseudoxml.py from 644 to 755
changing mode of build/scripts-3.2/rstpep2html.py from 644 to 755
changing mode of build/scripts-3.2/rst2odt.py from 644 to 755
changing mode of build/scripts-3.2/rst2odt_prepstyles.py from 644 to 755
File "/usr/local/lib/python3.2/dist-packages/docutils/utils/math/math2html.py", line 87
u'@article':u'$authors. $title. <i>$journal</i>,{ {$volume:}$pages,} $month $year.{ doi: $doi.}{ URL <a href="$url">$url</a>.}{ $note.}',
File "/usr/local/lib/python3.2/dist-packages/docutils/writers/latex2e/__init__.py", line 716
ord('#'): ur'\#',
File "/usr/local/lib/python3.2/dist-packages/docutils/writers/docutils_xml.py", line 177
except xml.sax._exceptions.SAXParseException, error:
File "/usr/local/lib/python3.2/dist-packages/docutils/writers/odf_odt/__init__.py", line 38
except ImportError, e:
File "/usr/local/lib/python3.2/dist-packages/docutils/writers/html4css1/__init__.py", line 342
ord('&'): u'&',
File "/usr/local/lib/python3.2/dist-packages/docutils/writers/manpage.py", line 275
text = text.replace(u'\xa0', '\\ ')
File "/usr/local/lib/python3.2/dist-packages/docutils/writers/xetex/__init__.py", line 117
self.literal_double_quote = u'"' # TODO: use \textquotedbl
changing mode of /usr/local/bin/rst2man.py to 755
changing mode of /usr/local/bin/rst2pseudoxml.py to 755
changing mode of /usr/local/bin/rst2xetex.py to 755
changing mode of /usr/local/bin/rst2latex.py to 755
changing mode of /usr/local/bin/rst2odt.py to 755
changing mode of /usr/local/bin/rst2xml.py to 755
changing mode of /usr/local/bin/rst2s5.py to 755
changing mode of /usr/local/bin/rst2html.py to 755
changing mode of /usr/local/bin/rst2odt_prepstyles.py to 755
changing mode of /usr/local/bin/rstpep2html.py to 755
Successfully installed statistics docutils
Cleaning up...
Alles anzeigen
Bitte um Hiiiiilfe
Danke
Gottfried
