Okay jetzt wirds komisch
nix gemacht und nix geht mehr
Na mal abwarten was morgen passiert
raspThermoPrint? Schau mal ob du hier fündig wirst!
ähh, ganz vergessen, schau mal in die /etc/inittab, da dürfte noch ein getty auf ttyAMA0 laufen, der spuckt Dir dann immer dazwischen.
orb
seh ich gerade irgendwie nix von
# /etc/inittab: init(8) configuration.
# $Id: inittab,v 1.91 2002/01/25 13:35:21 miquels Exp $
# The default runlevel.
# Boot-time system configuration/initialization script.
# This is run first except when booting in emergency (-b) mode.
si::sysinit:/etc/init.d/rcS
# What to do in single-user mode.
~~:S:wait:/sbin/sulogin
# /etc/init.d executes the S and K scripts upon change
# of runlevel.
# Runlevel 0 is halt.
# Runlevel 1 is single-user.
# Runlevels 2-5 are multi-user.
# Runlevel 6 is reboot.
l0:0:wait:/etc/init.d/rc 0
l1:1:wait:/etc/init.d/rc 1
l2:2:wait:/etc/init.d/rc 2
l3:3:wait:/etc/init.d/rc 3
l4:4:wait:/etc/init.d/rc 4
l5:5:wait:/etc/init.d/rc 5
l6:6:wait:/etc/init.d/rc 6
# Normally not reached, but fallthrough in case of emergency.
z6:6:respawn:/sbin/sulogin
# What to do when CTRL-ALT-DEL is pressed.
ca:12345:ctrlaltdel:/sbin/shutdown -t1 -a -r now
# Action on special keypress (ALT-UpArrow).
#kb::kbrequest:/bin/echo "Keyboard Request--edit /etc/inittab to let this work."
# What to do when the power fails/returns.
pf::powerwait:/etc/init.d/powerfail start
pn::powerfailnow:/etc/init.d/powerfail now
po::powerokwait:/etc/init.d/powerfail stop
# /sbin/getty invocations for the runlevels.
# The "id" field MUST be the same as the last
# characters of the device (after "tty").
# Format:
# <id>:<runlevels>:<action>:<process>
# Note that on most Debian systems tty7 is used by the X Window System,
# so if you want to add more getty's go ahead but skip tty7 if you run X.
#1:2345:respawn:/sbin/getty 38400 tty1
#2:23:respawn:/sbin/getty 38400 tty2
#3:23:respawn:/sbin/getty 38400 tty3
#4:23:respawn:/sbin/getty 38400 tty4
#5:23:respawn:/sbin/getty 38400 tty5
#6:23:respawn:/sbin/getty 38400 tty6
# Example how to put a getty on a serial line (for a terminal)
#T0:23:respawn:/sbin/getty -L ttyS0 9600 vt100
#T1:23:respawn:/sbin/getty -L ttyS1 9600 vt100
# Example how to put a getty on a modem line.
#T3:23:respawn:/sbin/mgetty -x0 -s 57600 ttyS3
Alles anzeigen
Irgendwie ist er recht unzuverlässig.
Erst funtioniert er, dann nicht, ein paar stunden später wieder
Hier einmal aufgelistet was ich gemacht hab inc Server aufsetzen usw
[code=php]ssh root@192.168.178.25
fdisk /dev/mmcblk0
p
d
3
d
2
n
p
2
w
reboot
resize2fs /dev/mmcblk0p2
df -h /
cd /var
dd if=/dev/zero of=swapfile bs=1M count=128
mkswap /var/swapfile
swapon /var/swapfile
nano /etc/fstab
/dev/mmcblk0p3 --> in --> /var/swapfile
reboot
dpkg-reconfigure keyboard-configuration
dpkg-reconfigure tzdata
dpkg-reconfigure locales
reboot
groupadd www-data
usermod -a -G www-data www-data
apt-get update
apt-get install apache2
apt-get install php5
nano /var/www/phpinfo.php
<?php phpinfo(); ?>
reboot
apt-get install mysql-server mysql-client php5-mysql
reboot
apt-get install libapache2-mod-auth-mysql php5-mysql phpmyadmin
nano /etc/php5/apache2/php.ini
extension=mysql.so
ln -s /etc/phpmyadmin/apache.conf /etc/apache2/conf.d/phpmyadmin.conf
/etc/init.d/apache2 reload
reboot
chmod 666 /dev/ttyAMA0
nano /boot/cmdline.txt
112500 --> in --> 19200
reboot
[/php]
Das hat zwar den Vorteil, daß die Schnittstellengeschwindigkeit auf 19,2k gesetzt wird, Du hast aber wiederhin den getty und den Debugger auf der Schnittstelle laufen.
Ich hab die beiden Einträge ganz rausgeworfen. Die Geschwindigkeit kannst Du dann z.B. mit
festlegen. Die Zeile kannst Du auch in der rc.local eintragen.
Das hat auch den Vorteil, daß nicht irgendwelche Treiber (z.B. der für OneWire) beim Booten alles würfeln.
orb
Danke aber ich hab es irgendwie hingekriegt das nu garnix mehr geht.
Server mal neu aufsetzen und nochmal von vorne anfangen.
Aber ich muss nu das projekt ein wenig auf eis legen muss ne neue Maschine aufa Arbeit kennenlernen.
Denke es wird sich noch um 2-2,5 Wochen handeln bis ich wieder nen klaren kopf hab und mich auf dieses Projekt konzentrieren kann.
Jawoll projekt vergessen und siehe da aus 2-25 Wochen wurden dann ja monate... egal
Neue energie für das Projekt getankt.
Server aufgesetzt wie bereits beschrieben....
probleme immernoch die gleichen.
Welche sind das aktuell?
Also
Neustart des Rpi drucken nicht möglich erst nach "[font="Monaco, Consolas, Courier, monospace"]chmod 666 /dev/ttyAMA0"[/font]
[font="Monaco, Consolas, Courier, monospace"]Beim Drucken aus Folgendem Php Script:[/font]
$kill = "\n\r";
$top = "Einkaufsliste\n\r";
$main = "Hallo Drucker!\n\r";
$bottom = "\n\r";
$string = $kill.$top.$main.$bottom.$bottom;
$pointer = fopen("/dev/ttyAMA0","w");
fwrite ($pointer, $string);
fclose($pointer);
Wird die erste Zeile "Einkaufsliste" vollkommen falsch gedruckt. Zweite Zeile ist okay
Erneutes öffnen der Seite führt nicht zu einem Druck ergebniss.. Warum auch immer funtioniert es erst nach mehreren minuten wider
Das Rechteproblem sollte sich erledigen, wenn Du den Nutzer unter dem der Apache läuft in die dialout-Gruppe packst.
Das andere Problem klingt danach, daß da noch ein Prozess auf die Schnittstelle zugreift und dazwischen funkt.
Bei mir läuft alles als "root"
Ich hab echt keine ahnung was da noch zwischen Funken kann.
Das komische dabei ist echt... mal geht es und mal nicht.
apache läuft bei Dir als root? sicher?
mach mal ein 'ps -ef|grep apache'
Der läuft eigendlich unter apache, www oder auch web
Verdammt du hast recht
@eknab Moin, ich wollte mal fragen ob du den Thermodrucker von eBay benutzt oder den Tinker drucker. Ich bin mir bei dem eBay Thermodrucker nicht ganz sicher wie ich die USB Bridge des LTP port ansprechen soll unter debian. Hast du damit schon was erreicht oder machst du es über serielle Schnittstelle mit einem anderen Drucker ?
Gruß !
Hallo Hate,
ich habe diesen hier http://www.tinkersoup.de/product_info.php?products_id=703 .
Die eBay dinger hatte ich hier rumfliegen und waren als Notfall gedacht fals ich den Thermal Printer zerstört habe, war nicht der fall.
Angeschlossen ist der Drucker so http://tobiscorner.floery.net/raspberry-pi/c…e-raspberry-pi/ .
Ich komme momentan nicht weiter.
Ergebnisse siehst du oben.
LG
