Das Update von Screenly schlägt aktuell fehl.
Zitatbash <(curl -sL https://www.screenlyapp.com/install-ose.sh)
Python
Using cached ansible-2.0.2.0.tar.gz
Could not import setuptools which is required to install from a source distribution.
File "/usr/local/lib/python2.7/dist-packages/pip/req/req_install.py", line 372, in setup_py
import setuptools # noqa
File "/usr/local/lib/python2.7/dist-packages/setuptools/__init__.py", line 11, in <module>
from setuptools.extern.six.moves import filterfalse, map
File "/usr/local/lib/python2.7/dist-packages/setuptools/extern/__init__.py", line 1, in <module>
from pkg_resources.extern import VendorImporter
ImportError: No module named extern
+ ansible-playbook site.yml --skip-tags enable-ssl
ERROR: become is not a legal parameter at this level in an Ansible Playbook
+ sudo apt-get autoclean
Ich bin für jede Hilfe dankbar.
