Jetzt hänge ich fest...
Nur die Subdomain "baikal.mydomain.de" soll automatisch auf https:// redirectet werden - funktioniert, Zertifikat klappt.
Aber leider werden nun ALLE http-Anfragen auf https umgeleitet.. also z.B. auch http://www.mydomain.de
Wo ist mein Denkfehler?
Bin für jede Hilfe dankbar!
server.modules = (
"mod_access",
"mod_alias",
"mod_compress",
"mod_redirect",
# "mod_rewrite",
"mod_auth",
"mod_accesslog",
server.document-root = "/var/www/html"
server.upload-dirs = ( "/var/cache/lighttpd/uploads" )
server.errorlog = "/var/log/lighttpd/error.log"
server.pid-file = "/var/run/lighttpd.pid"
server.username = "www-data"
server.groupname = "www-data"
server.port = 80
server.follow-symlink = "enable"
index-file.names = ( "index.php", "index.html", "index.lighttpd.html" )
url.access-deny = ( "~", ".inc" )
static-file.exclude-extensions = ( ".php", ".pl", ".fcgi" )
compress.cache-dir = "/var/cache/lighttpd/compress/"
compress.filetype = ( "application/javascript", "text/css", "text/html", "text/plain" )
# default listening port for IPv6 falls back to the IPv4 port
include_shell "/usr/share/lighttpd/use-ipv6.pl " + server.port
include_shell "/usr/share/lighttpd/create-mime.assign.pl"
include_shell "/usr/share/lighttpd/include-conf-enabled.pl"
include_shell "cat /etc/lighttpd/vhosts.d/*.conf"
### Login erforderlich für phpMyAdmin ###
auth.debug = 2
auth.backend = "plain"
auth.backend.plain.userfile = "/xxx/xxx/xxx.txt"
auth.require = ( "/phpmyadmin/" =>
"method" => "basic",
"realm" => "Login",
"require" => "user=xxx"
$HTTP["scheme"] == "http" {
$HTTP["host"] == "baikal.mydomain.de" {
url.redirect = ("^/baikal/.*" => "https://baikal.mydomain.de$0")
## enable ssl
$SERVER["socket"] == ":443" {
ssl.engine = "enable"
ssl.ca-file = "/etc/lighttpd/startssl.pem"
ssl.pemfile = "/etc/lighttpd/baikal-mydomain.pem"
Alles anzeigen
