Hallo zusammen,
ich bin Neuling und habe das Ambilight Projekt mal umgesetzt. Alles nach einer Anleitung verbaut.
WS2801 LED, Netzteil, Pi 3 etc.
Es läuft nur ich bekomme die Farben nicht richtig dargestellt. Habe schon alle Einstellungen bzgl. RGB etc. im Hyperion probiert.
Ich hoffe das einer von euch mir weiterhelfen kann.
Anbei ein paar Bilder..
DANKE im Voraus.
// Automatically generated configuration file for Hyperion ambilight daemon
// Notice: All values are explained with comments at our wiki: wiki.hyperion-project.org (config area)
// Generated by: HyperCon (The Hyperion deamon configuration file builder)
// Created with HyperCon V1.03.1 (11.06.2016)
// DEVICE CONFIGURATION
"device" :
"name" : "MyHyperionConfig",
"type" : "ws2801",
"output" : "/dev/spidev0.0",
"rate" : 1000000,
"colorOrder" : "rbg"
// COLOR CALIBRATION CONFIG
"color" :
"channelAdjustment" :
"id" : "default",
"leds" : "*",
"pureRed" :
"redChannel" : 255,
"greenChannel" : 0,
"blueChannel" : 0
"pureGreen" :
"redChannel" : 0,
"greenChannel" : 255,
"blueChannel" : 255
"pureBlue" :
"redChannel" : 0,
"greenChannel" : 0,
"blueChannel" : 255
"temperature" :
"id" : "default",
"leds" : "*",
"correctionValues" :
"red" : 255,
"green" : 255,
"blue" : 255
"transform" :
"id" : "default",
"leds" : "*",
"hsl" :
"saturationGain" : 1.0000,
"luminanceGain" : 1.0000,
"luminanceMinimum" : 0.0000
"red" :
"threshold" : 0.0000,
"gamma" : 2.5000
"green" :
"gamma" : 2.5000
"blue" :
"gamma" : 2.5000
// SMOOTHING CONFIG
"smoothing" :
"type" : "linear",
"time_ms" : 100,
"updateFrequency" : 25.0000,
"updateDelay" : 0
// NO V4L2 GRABBER CONFIG
// FRAME GRABBER CONFIG
"framegrabber" :
"width" : 64,
"height" : 64,
"frequency_Hz" : 10.0,
"priority" : 890
// BLACKBORDER CONFIG
"blackborderdetector" :
"enable" : true,
"threshold" : 0.0,
"unknownFrameCnt" : 600,
"borderFrameCnt" : 50,
"maxInconsistentCnt" : 10,
"blurRemoveCnt" : 1,
"mode" : "default"
// KODI CHECK CONFIG
"xbmcVideoChecker" :
"xbmcAddress" : "127.0.0.1",
"xbmcTcpPort" : 9090,
"grabVideo" : true,
"grabPictures" : true,
"grabAudio" : false,
"grabMenu" : true,
"grabPause" : true,
"grabScreensaver" : false,
"enable3DDetection" : true
// BOOTEFFECT CONFIG
"bootsequence" :
"color" : [0,0,0],
"effect" : "Cinema brighten lights",
"duration_ms" : 3000,
"priority" : 700
// JSON SERVER CONFIG
"jsonServer" :
"port" : 19444
// PROTO SERVER CONFIG
"protoServer" :
"port" : 19445
// JSON/PROTO FORWARD CONFIG
"forwarder" :
"json" : ["127.0.0.1:19446"],
"proto" : ["127.0.0.1:19447"]
// EFFECT PATH
"effects" :
"paths" :
"/storage/hyperion/effects",
"/usr/share/hyperion/effects"
// NO BOBLIGHT SERVER CONFIG
// LED CONFIGURATION
"leds" :
"index" : 0,
"hscan" : { "minimum" : 0.6563, "maximum" : 0.6875 },
"vscan" : { "minimum" : 0.9200, "maximum" : 1.0000 }
"index" : 1,
"hscan" : { "minimum" : 0.6875, "maximum" : 0.7188 },
"index" : 2,
"hscan" : { "minimum" : 0.7188, "maximum" : 0.7500 },
"index" : 3,
"hscan" : { "minimum" : 0.7500, "maximum" : 0.7813 },
"index" : 4,
"hscan" : { "minimum" : 0.7813, "maximum" : 0.8125 },
"index" : 5,
"hscan" : { "minimum" : 0.8125, "maximum" : 0.8438 },
"index" : 6,
"hscan" : { "minimum" : 0.8438, "maximum" : 0.8750 },
"index" : 7,
"hscan" : { "minimum" : 0.8750, "maximum" : 0.9063 },
"index" : 8,
"hscan" : { "minimum" : 0.9063, "maximum" : 0.9375 },
"index" : 9,
"hscan" : { "minimum" : 0.9375, "maximum" : 0.9688 },
"index" : 10,
"hscan" : { "minimum" : 0.9688, "maximum" : 1.0000 },
"index" : 11,
"hscan" : { "minimum" : 0.9500, "maximum" : 1.0000 },
"vscan" : { "minimum" : 0.9412, "maximum" : 1.0000 }
"index" : 12,
"vscan" : { "minimum" : 0.8824, "maximum" : 0.9412 }
"index" : 13,
"vscan" : { "minimum" : 0.8235, "maximum" : 0.8824 }
"index" : 14,
"vscan" : { "minimum" : 0.7647, "maximum" : 0.8235 }
"index" : 15,
"vscan" : { "minimum" : 0.7059, "maximum" : 0.7647 }
"index" : 16,
"vscan" : { "minimum" : 0.6471, "maximum" : 0.7059 }
"index" : 17,
"vscan" : { "minimum" : 0.5882, "maximum" : 0.6471 }
"index" : 18,
"vscan" : { "minimum" : 0.5294, "maximum" : 0.5882 }
"index" : 19,
"vscan" : { "minimum" : 0.4706, "maximum" : 0.5294 }
"index" : 20,
"vscan" : { "minimum" : 0.4118, "maximum" : 0.4706 }
"index" : 21,
"vscan" : { "minimum" : 0.3529, "maximum" : 0.4118 }
"index" : 22,
"vscan" : { "minimum" : 0.2941, "maximum" : 0.3529 }
"index" : 23,
"vscan" : { "minimum" : 0.2353, "maximum" : 0.2941 }
"index" : 24,
"vscan" : { "minimum" : 0.1765, "maximum" : 0.2353 }
"index" : 25,
"vscan" : { "minimum" : 0.1176, "maximum" : 0.1765 }
"index" : 26,
"vscan" : { "minimum" : 0.0588, "maximum" : 0.1176 }
"index" : 27,
"vscan" : { "minimum" : 0.0000, "maximum" : 0.0588 }
"index" : 28,
"vscan" : { "minimum" : 0.0000, "maximum" : 0.0800 }
"index" : 29,
"index" : 30,
"index" : 31,
"index" : 32,
"index" : 33,
"index" : 34,
"index" : 35,
"index" : 36,
"index" : 37,
"index" : 38,
"index" : 39,
"hscan" : { "minimum" : 0.6250, "maximum" : 0.6563 },
"index" : 40,
"hscan" : { "minimum" : 0.5938, "maximum" : 0.6250 },
"index" : 41,
"hscan" : { "minimum" : 0.5625, "maximum" : 0.5938 },
"index" : 42,
"hscan" : { "minimum" : 0.5313, "maximum" : 0.5625 },
"index" : 43,
"hscan" : { "minimum" : 0.5000, "maximum" : 0.5313 },
"index" : 44,
"hscan" : { "minimum" : 0.4688, "maximum" : 0.5000 },
"index" : 45,
"hscan" : { "minimum" : 0.4375, "maximum" : 0.4688 },
"index" : 46,
"hscan" : { "minimum" : 0.4063, "maximum" : 0.4375 },
"index" : 47,
"hscan" : { "minimum" : 0.3750, "maximum" : 0.4063 },
"index" : 48,
"hscan" : { "minimum" : 0.3438, "maximum" : 0.3750 },
"index" : 49,
"hscan" : { "minimum" : 0.3125, "maximum" : 0.3438 },
"index" : 50,
"hscan" : { "minimum" : 0.2813, "maximum" : 0.3125 },
"index" : 51,
"hscan" : { "minimum" : 0.2500, "maximum" : 0.2813 },
"index" : 52,
"hscan" : { "minimum" : 0.2188, "maximum" : 0.2500 },
"index" : 53,
"hscan" : { "minimum" : 0.1875, "maximum" : 0.2188 },
"index" : 54,
"hscan" : { "minimum" : 0.1563, "maximum" : 0.1875 },
"index" : 55,
"hscan" : { "minimum" : 0.1250, "maximum" : 0.1563 },
"index" : 56,
"hscan" : { "minimum" : 0.0938, "maximum" : 0.1250 },
"index" : 57,
"hscan" : { "minimum" : 0.0625, "maximum" : 0.0938 },
"index" : 58,
"hscan" : { "minimum" : 0.0313, "maximum" : 0.0625 },
"index" : 59,
"hscan" : { "minimum" : 0.0000, "maximum" : 0.0313 },
"index" : 60,
"hscan" : { "minimum" : 0.0000, "maximum" : 0.0500 },
"index" : 61,
"index" : 62,
"index" : 63,
"index" : 64,
"index" : 65,
"index" : 66,
"index" : 67,
"index" : 68,
"index" : 69,
"index" : 70,
"index" : 71,
"index" : 72,
"index" : 73,
"index" : 74,
"index" : 75,
"index" : 76,
"index" : 77,
"index" : 78,
"index" : 79,
"index" : 80,
"index" : 81,
"index" : 82,
"index" : 83,
"index" : 84,
"index" : 85,
"index" : 86,
"index" : 87,
"endOfJson" : "endOfJson"
Display More
