Hallo zusammen,
mein Ambilight läuft seit Monaten gut.
Seit gestern geht gar nichts mehr.
Strom, HyperCon usw. alles gecheckt.
Habe jetzt Openelec neu installiert und alles neu gemacht.
Hier mal die config.
Fällt euch etwas auf????
Kann es sein das die APA 102 defekt sind?
Wie bekommt man das raus?
Danke für eure Unterstützung...
// Automatically generated configuration file for Hyperion ambilight daemon
// Notice: All values are explained with comments at our wiki: wiki.hyperion-project.org (config area)
// Generated by: HyperCon (The Hyperion deamon configuration file builder)
// Created with HyperCon V1.03.1 (11.06.2016)
// DEVICE CONFIGURATION
"device" :
"name" : "MyHyperionConfig",
"type" : "apa102",
"output" : "/dev/spidev0.0",
"rate" : 1000000,
"colorOrder" : "bgr"
// COLOR CALIBRATION CONFIG
"color" :
"channelAdjustment" :
"id" : "default",
"leds" : "*",
"pureRed" :
"redChannel" : 255,
"greenChannel" : 0,
"blueChannel" : 0
"pureGreen" :
"redChannel" : 0,
"greenChannel" : 255,
"blueChannel" : 0
"pureBlue" :
"redChannel" : 0,
"greenChannel" : 0,
"blueChannel" : 255
"temperature" :
"id" : "default",
"leds" : "*",
"correctionValues" :
"red" : 255,
"green" : 255,
"blue" : 255
"transform" :
"id" : "default",
"leds" : "*",
"hsl" :
"saturationGain" : 1.0000,
"luminanceGain" : 1.0000,
"luminanceMinimum" : 0.0000
"red" :
"threshold" : 0.0000,
"gamma" : 2.5000
"green" :
"gamma" : 2.5000
"blue" :
"gamma" : 2.5000
// SMOOTHING CONFIG
"smoothing" :
"type" : "linear",
"time_ms" : 100,
"updateFrequency" : 25.0000,
"updateDelay" : 0
// V4L2 GRABBER CONFIG
"grabber-v4l2" :
"device" : "/dev/video0",
"input" : 0,
"standard" : "PAL",
"width" : -1,
"height" : -1,
"frameDecimation" : 2,
"sizeDecimation" : 4,
"priority" : 800,
"mode" : "2D",
"cropLeft" : 6,
"cropRight" : 6,
"cropTop" : 2,
"cropBottom" : 2,
"redSignalThreshold" : 0.1,
"greenSignalThreshold" : 0.1,
"blueSignalThreshold" : 0.1
// FRAME GRABBER CONFIG
"framegrabber" :
"width" : 64,
"height" : 64,
"frequency_Hz" : 10.0,
"priority" : 890
// BLACKBORDER CONFIG
"blackborderdetector" :
"enable" : true,
"threshold" : 0.0,
"unknownFrameCnt" : 600,
"borderFrameCnt" : 50,
"maxInconsistentCnt" : 10,
"blurRemoveCnt" : 1,
"mode" : "default"
// KODI CHECK CONFIG
"xbmcVideoChecker" :
"xbmcAddress" : "127.0.0.1",
"xbmcTcpPort" : 9090,
"grabVideo" : true,
"grabPictures" : true,
"grabAudio" : false,
"grabMenu" : true,
"grabPause" : true,
"grabScreensaver" : true,
"enable3DDetection" : true
// BOOTEFFECT CONFIG
"bootsequence" :
"color" : [0,0,0],
"effect" : "Rainbow swirl",
"duration_ms" : 30000,
"priority" : 800
// JSON SERVER CONFIG
"jsonServer" :
"port" : 19444
// PROTO SERVER CONFIG
"protoServer" :
"port" : 19445
// EFFECT PATH
"effects" :
"paths" :
"/storage/hyperion/effects",
"/usr/share/hyperion/effects"
// NO BOBLIGHT SERVER CONFIG
// NO JSON/PROTO FORWARD CONFIG
// LED CONFIGURATION
"leds" :
"index" : 0,
"hscan" : { "minimum" : 0.6129, "maximum" : 0.6452 },
"vscan" : { "minimum" : 0.9200, "maximum" : 1.0000 }
"index" : 1,
"hscan" : { "minimum" : 0.6452, "maximum" : 0.6774 },
"index" : 2,
"hscan" : { "minimum" : 0.6774, "maximum" : 0.7097 },
"index" : 3,
"hscan" : { "minimum" : 0.7097, "maximum" : 0.7419 },
"index" : 4,
"hscan" : { "minimum" : 0.7419, "maximum" : 0.7742 },
"index" : 5,
"hscan" : { "minimum" : 0.7742, "maximum" : 0.8065 },
"index" : 6,
"hscan" : { "minimum" : 0.8065, "maximum" : 0.8387 },
"index" : 7,
"hscan" : { "minimum" : 0.8387, "maximum" : 0.8710 },
"index" : 8,
"hscan" : { "minimum" : 0.8710, "maximum" : 0.9032 },
"index" : 9,
"hscan" : { "minimum" : 0.9032, "maximum" : 0.9355 },
"index" : 10,
"hscan" : { "minimum" : 0.9355, "maximum" : 0.9677 },
"index" : 11,
"hscan" : { "minimum" : 0.9677, "maximum" : 1.0000 },
"index" : 12,
"hscan" : { "minimum" : 0.9500, "maximum" : 1.0000 },
"vscan" : { "minimum" : 0.9412, "maximum" : 1.0000 }
"index" : 13,
"vscan" : { "minimum" : 0.8824, "maximum" : 0.9412 }
"index" : 14,
"vscan" : { "minimum" : 0.8235, "maximum" : 0.8824 }
"index" : 15,
"vscan" : { "minimum" : 0.7647, "maximum" : 0.8235 }
"index" : 16,
"vscan" : { "minimum" : 0.7059, "maximum" : 0.7647 }
"index" : 17,
"vscan" : { "minimum" : 0.6471, "maximum" : 0.7059 }
"index" : 18,
"vscan" : { "minimum" : 0.5882, "maximum" : 0.6471 }
"index" : 19,
"vscan" : { "minimum" : 0.5294, "maximum" : 0.5882 }
"index" : 20,
"vscan" : { "minimum" : 0.4706, "maximum" : 0.5294 }
"index" : 21,
"vscan" : { "minimum" : 0.4118, "maximum" : 0.4706 }
"index" : 22,
"vscan" : { "minimum" : 0.3529, "maximum" : 0.4118 }
"index" : 23,
"vscan" : { "minimum" : 0.2941, "maximum" : 0.3529 }
"index" : 24,
"vscan" : { "minimum" : 0.2353, "maximum" : 0.2941 }
"index" : 25,
"vscan" : { "minimum" : 0.1765, "maximum" : 0.2353 }
"index" : 26,
"vscan" : { "minimum" : 0.1176, "maximum" : 0.1765 }
"index" : 27,
"vscan" : { "minimum" : 0.0588, "maximum" : 0.1176 }
"index" : 28,
"vscan" : { "minimum" : 0.0000, "maximum" : 0.0588 }
"index" : 29,
"vscan" : { "minimum" : 0.0000, "maximum" : 0.0800 }
"index" : 30,
"index" : 31,
"index" : 32,
"index" : 33,
"index" : 34,
"index" : 35,
"index" : 36,
"index" : 37,
"index" : 38,
"index" : 39,
"index" : 40,
"index" : 41,
"hscan" : { "minimum" : 0.5806, "maximum" : 0.6129 },
"index" : 42,
"hscan" : { "minimum" : 0.5484, "maximum" : 0.5806 },
"index" : 43,
"hscan" : { "minimum" : 0.5161, "maximum" : 0.5484 },
"index" : 44,
"hscan" : { "minimum" : 0.4839, "maximum" : 0.5161 },
"index" : 45,
"hscan" : { "minimum" : 0.4516, "maximum" : 0.4839 },
"index" : 46,
"hscan" : { "minimum" : 0.4194, "maximum" : 0.4516 },
"index" : 47,
"hscan" : { "minimum" : 0.3871, "maximum" : 0.4194 },
"index" : 48,
"hscan" : { "minimum" : 0.3548, "maximum" : 0.3871 },
"index" : 49,
"hscan" : { "minimum" : 0.3226, "maximum" : 0.3548 },
"index" : 50,
"hscan" : { "minimum" : 0.2903, "maximum" : 0.3226 },
"index" : 51,
"hscan" : { "minimum" : 0.2581, "maximum" : 0.2903 },
"index" : 52,
"hscan" : { "minimum" : 0.2258, "maximum" : 0.2581 },
"index" : 53,
"hscan" : { "minimum" : 0.1935, "maximum" : 0.2258 },
"index" : 54,
"hscan" : { "minimum" : 0.1613, "maximum" : 0.1935 },
"index" : 55,
"hscan" : { "minimum" : 0.1290, "maximum" : 0.1613 },
"index" : 56,
"hscan" : { "minimum" : 0.0968, "maximum" : 0.1290 },
"index" : 57,
"hscan" : { "minimum" : 0.0645, "maximum" : 0.0968 },
"index" : 58,
"hscan" : { "minimum" : 0.0323, "maximum" : 0.0645 },
"index" : 59,
"hscan" : { "minimum" : 0.0000, "maximum" : 0.0323 },
"index" : 60,
"hscan" : { "minimum" : 0.0000, "maximum" : 0.0500 },
"index" : 61,
"index" : 62,
"index" : 63,
"index" : 64,
"index" : 65,
"index" : 66,
"index" : 67,
"index" : 68,
"index" : 69,
"index" : 70,
"index" : 71,
"index" : 72,
"index" : 73,
"index" : 74,
"index" : 75,
"index" : 76,
"index" : 77,
"index" : 78,
"index" : 79,
"index" : 80,
"index" : 81,
"index" : 82,
"index" : 83,
"index" : 84,
"index" : 85,
"index" : 86,
"index" : 87,
"index" : 88,
"index" : 89,
"endOfJson" : "endOfJson"
Display More
