Hallo, ich habe Motion auf meinem Pi laufen.
Ab und zu spinnt es allerdings:
Jul 21 06:43:01 raspberrypi /USR/SBIN/CRON[17190]: (root) CMD (/home/pi/pi_scripte_motion/move_snapshot.pl > /dev/null 2>&1)
Jul 21 06:43:01 raspberrypi /USR/SBIN/CRON[17191]: (root) CMD (/home/pi/pi_scripte_motion/upload_ftp_crown.pl > /dev/null 2>&1)
Jul 21 06:43:45 raspberrypi kernel: [ 9520.323807] uvcvideo: Failed to query (SET_CUR) UVC control 2 on unit 2: -110 (exp. 2).
Jul 21 06:43:45 raspberrypi kernel: [ 9520.823008] uvcvideo: Failed to query (SET_CUR) UVC control 2 on unit 2: -110 (exp. 2).
Jul 21 06:43:46 raspberrypi kernel: [ 9521.322899] uvcvideo: Failed to query (SET_CUR) UVC control 2 on unit 2: -110 (exp. 2).
Jul 21 06:43:47 raspberrypi kernel: [ 9521.933087] uvcvideo: Failed to query (SET_CUR) UVC control 2 on unit 2: -110 (exp. 2).
Jul 21 06:43:47 raspberrypi kernel: [ 9522.683023] uvcvideo: Failed to query (SET_CUR) UVC control 2 on unit 2: -110 (exp. 2).
Jul 21 06:43:48 raspberrypi kernel: [ 9523.353032] uvcvideo: Failed to query (SET_CUR) UVC control 2 on unit 2: -110 (exp. 2).
Jul 21 06:43:49 raspberrypi kernel: [ 9524.213072] uvcvideo: Failed to query (SET_CUR) UVC control 2 on unit 2: -110 (exp. 2).
Jul 21 06:43:49 raspberrypi kernel: [ 9524.862971] uvcvideo: Failed to query (SET_CUR) UVC control 2 on unit 2: -110 (exp. 2).
Jul 21 06:43:50 raspberrypi kernel: [ 9525.313017] uvcvideo: Failed to query (SET_CUR) UVC control 2 on unit 2: -110 (exp. 2).
Jul 21 06:43:51 raspberrypi kernel: [ 9526.703066] uvcvideo: Failed to query (SET_CUR) UVC control 2 on unit 2: -110 (exp. 2).
Jul 21 06:43:52 raspberrypi kernel: [ 9527.613065] uvcvideo: Failed to query (SET_CUR) UVC control 2 on unit 2: -110 (exp. 2).
Jul 21 06:44:02 raspberrypi /USR/SBIN/CRON[17952]: (root) CMD (/home/pi/pi_scripte_motion/move_snapshot.pl > /dev/null 2>&1)
Display More
Läuft aber dann wieder einfach weiter.
Ich habe eine Webcam Logitech C290 mit einem aktiven USB Hub an dem Pi hängen.
Hat da jemand einen Tipp?
mfg
druckgott
