top und htop hat nichts wesentliches gezeigt
config.txt
Code Alles anzeigenmax_usb_current=1 hdmi_force_hotplug=1 hdmi_group=2 hdmi_mode=35 # For more options and information see # http://www.raspberrypi.org/documentation/configuration/config-txt.md # Some settings may impact device functionality. See link above for details # uncomment if you get no picture on HDMI for a default "safe" mode #hdmi_safe=1 # uncomment this if your display has a black border of unused pixels visible # and your display can output without overscan #disable_overscan=1 # uncomment the following to adjust overscan. Use positive numbers if console # goes off screen, and negative if there is too much border #overscan_left=16 #overscan_right=16 #overscan_top=16 #overscan_bottom=16 # uncomment to force a console size. By default it will be display's size minus # overscan. #framebuffer_width=1280 #framebuffer_height=720 # uncomment if hdmi display is not detected and composite is being output #hdmi_force_hotplug=1 # uncomment to force a specific HDMI mode (this will force VGA) #hdmi_group=1 #hdmi_mode=1 # uncomment to force a HDMI mode rather than DVI. This can make audio work in # DMT (computer monitor) modes #hdmi_drive=2 # uncomment to increase signal to HDMI, if you have interference, blanking, or # no display #config_hdmi_boost=4 # uncomment for composite PAL #sdtv_mode=2 #uncomment to overclock the arm. 700 MHz is the default. #arm_freq=800 # Uncomment some or all of these to enable the optional hardware interfaces #dtparam=i2c_arm=on #dtparam=i2s=on #dtparam=spi=on # Uncomment this to enable the lirc-rpi module #dtoverlay=lirc-rpi # Additional overlays and parameters are documented /boot/overlays/README # Enable audio (loads snd_bcm2835) dtparam=audio=on
Codepi@raspbianPI3:~ $ cat /etc/os-release PRETTY_NAME="Raspbian GNU/Linux 8 (jessie)" NAME="Raspbian GNU/Linux" VERSION_ID="8" VERSION="8 (jessie)" ID=raspbian ID_LIKE=debian HOME_URL="http://www.raspbian.org/" SUPPORT_URL="http://www.raspbian.org/RaspbianForums" BUG_REPORT_URL="http://www.raspbian.org/RaspbianBugs"
raspbian P3 hängt sich regelmäßig auf
jar -
26. Oktober 2017 um 13:23 -
Erledigt
raspbian P3 hängt sich regelmäßig auf? Schau mal ob du hier fündig wirst!
hier sollten ...
Schau mal mit pmap, sofort nach dem reboot (und schon richtig geöffnetem Browser) _und_ wenn "fast nichts mehr geht" nach, wie viel Speicher dem chromium-browser-Prozess (... wenn Du alle deine Tabs offen hast) mit der Parent-PID 1, zugerodnet ist.
i. d. R. die 2. PID nach der 1 (PPID).
Was ist das für eine Software die sich gerne aufhängt? Könnte man evtl. nur diese "Software" neu starten (... wenn sie sich auch aufgehängt hat), statt den PI?
Ausgaben bitte in CODE posten.
Dann solltest du lieber die Software prüfen und herausfinden wieso sich diese aufhängt sowie dieses Problem dann auch wirklich zu beheben - den Pi deshalb jedes mal komplett neu zu starten löst nämlich keine Probleme sondern ignoriert's nur.... Mal davon abgesehen das man deshalb eigentlich nicht den ganzen Rechner neustartet...
also bei mir hängt sich unter raspbian der Chromium Browser regelmäßig auf, in der Art das der PI nahezu unbedienbar wird, Terminal oder auch von Putty kommt dann manchmal keinerlei Rückmeldung mehr, bzw. dauert u.U. ewig.
Ich wäre froh wenn man das ohne Reset oder neu starten hin bekäme, ist aber leider noch keine Lösung in Sicht
Bin ich denn der einzige mit dem Problem?
Epiphany & Firefox läuft noch schlechter
config.txt
Infos: welche Raspbian Version du hast
gerade klemmts wieder
kleinSchrift ist groß und umgekehrt
Fenster schliessen am X ist nicht möglich
Alles anzeigentop - 13:07:25 up 1 day, 18:03, 3 users, load average: 0,62, 0,71, 0,64 Tasks: 171 total, 3 running, 168 sleeping, 0 stopped, 0 zombie %Cpu(s): 21,1 us, 2,2 sy, 0,0 ni, 76,5 id, 0,1 wa, 0,0 hi, 0,1 si, 0,0 st KiB Mem: 947732 total, 915168 used, 32564 free, 8600 buffers KiB Swap: 102396 total, 102384 used, 12 free. 378356 cached Mem PID USER PR NI VIRT RES SHR S %CPU %MEM TIME+ COMMAND 1318 pi 20 0 35252 3128 1452 S 48,3 0,3 20:06.27 synergyc 22054 pi 20 0 575708 258684 219952 S 18,5 27,3 109:10.69 chromium-b+ 1413 pi 20 0 720188 152080 8592 S 13,9 16,0 504:02.60 java 1073 root 20 0 184292 56624 23192 R 5,3 6,0 76:13.61 Xorg 1561 pi 20 0 818696 84136 47272 S 5,3 8,9 292:54.57 chromium-b+ 7418 pi 20 0 47024 18820 15916 R 2,0 2,0 0:01.24 lxterminal 1969 pi 20 0 472220 89304 40844 S 1,7 9,4 34:32.51 chromium-b+ 1227 pi 20 0 106068 12408 9288 S 0,3 1,3 6:29.59 lxpanel 1628 pi 20 0 464820 96668 17184 S 0,3 10,2 8:23.61 chromium-b+ 7545 pi 20 0 5112 2312 1920 R 0,3 0,2 0:00.12 top 1 root 20 0 22968 2448 1620 S 0,0 0,3 0:07.35 systemd 2 root 20 0 0 0 0 S 0,0 0,0 0:00.14 kthreadd 3 root 20 0 0 0 0 S 0,0 0,0 0:16.25 ksoftirqd/0 5 root 0 -20 0 0 0 S 0,0 0,0 0:00.00 kworker/0:+ 7 root 20 0 0 0 0 S 0,0 0,0 0:46.05 rcu_sched 8 root 20 0 0 0 0 S 0,0 0,0 0:00.00 rcu_bh 9 root rt 0 0 0 0 S 0,0 0,0 0:00.01 migration/0
nun siehts freundlicher aus nach reboot
Tasks: 165 total, 1 running, 164 sleeping, 0 stopped, 0 zombie
%Cpu(s): 5,0 us, 0,7 sy, 0,0 ni, 94,3 id, 0,0 wa, 0,0 hi, 0,0 si, 0,0 st
KiB Mem: 947732 total, 429048 used, 518684 free, 23832 buffers
KiB Swap: 102396 total, 0 used, 102396 free. 192244 cached Mem
endlich wieder freies RAM und freies SWAPalso RAM und SWAP läuft zu
Da ich in deiner config.txt kein gpu_mem Eintrag sehe wird der Default 64 verwendet und das kann bereits für eine Desktopumgebung alleine zu wenig sein, dann noch zusätzlich einen Browser und die Grenze ist erreicht. Setz gpu_mem mal auf 128 (empfohlener Wert für Desktop).
OK versuche ich mal
chromium-b+ hat ebenfalls mehrere Prozesse - hast du mehrere Tabs auf?
ja immer
Linux handhabt die RAM Verwaltung anders & besser. Freier Arbeitsspeicher ist verschwendeter Arbeitsspeicher.
hat nicht genutzt, war sogar contraproduktiv?
es geht schneller zäher
KiB Mem: 752852 total, 722328 used, 30524 free, 1620 buffers
KiB Swap: 102396 total, 102396 used, 0 free. 262056 cached Mem
OK
das ist dann aber ein Schwäche der Software auf dem PI, denn es funktioniert kurz nach dem reboot alles prima.
Das über die Laufzeit der mem ausgeht ist miese SW ergo gibt es offensichtlich Gründe regelmäßig ein reboot durchzuführen was hier ja öfter bezweifelt wird!
Man kann jeden Computer dazu kriegen dass der RAM voll ausgelastet wird. Auf jedem Computer kriegt man dann ähnliche Probleme.
Mit der Software hat das auch nur indirekt etwas zu tun. Du kannst halt einfach nicht zig Programme gleichzeitig auf haben - man muss irgendwann mal welche beenden.ich sehe das anders, was hier bei mir auf dem PI läuft ist nur statisch, eigentlich sind nur im Chromium 3 Tabs offen die nichts machen, da könnte ja auch mal von Chromium die swap Datei aufgeräumt werden.
Für mich bleibt das falsche Programmierung, selbst auf dem CBM von 1977 kannte man die garbage collection
Auf dem raidsonic NAS 2001b musste ich das auch selber nachrüsten sonst wuchs die LOG Datei ins unendliche.
Chromium abschiessen reicht bzw. hat genügt!
andere Browser laufen noch schlechter
eigentlich läuft nur kodi remote und mein webserver auf pollin netio
du hast ja Recht aber es passt zum Thema das der PI reboot braucht.
Automatischer Neustart des Raspberry Pi
Ich habe versucht meine Beiträge mit Zitate zu verschieben, aber der Editor macht das unmöglich, sollten sich hier Lösungen ergeben dann interessiert das sicher auch den TO!
EDIT, nun habe ich es geschafft, ob die beiden Threads nun lesbarer sind?
Magst du uns wirklich nicht verraten welche Seiten du in den 3 Tabs geöffnet hast?
Vielleicht sind ja auch diese Seiten schuld und schlecht programmiert, und ballern durch lange Laufzeit den Ram voll - gibts leider.
Wieso hast du überhaupt 3 Tabs auf wenn die denn aber gar nichts "machen"?
Aber wie du ja mittlerweile selbst festgestellt hast, hilft es bereits nur Chromium neu zu starten. Man kann also nicht einfach alles in einen Topf schmeißen - IBM oder irgendwelche Logs...
Also hat es meiner Meinung nach eindeutig etwas mit diesen ominösen 3 Seiten zu tun. Um das wiederum weiter zu analysieren könnte man zB nur mal eine auf haben - also alle Kombinationsmöglichkeiten durchprobieren, mal nur Seite#1, dann nur #2, dann nur #3, dann #1 und #2, dann #1 und #3 usw.. Entweder nur eine bestimmte Seite ist Schuld, oder irgendeine Kombination...
eine Seite zu gelassen und es hält schon länger durch
Neues:
https://willy-tech.de/swap-vergroessern/
ich wählte:
In diesem Fall muss der numerische Wert angepasst werden, 512 für eine 512 MB Große SWAP-Partition („CONF_SWAPSIZE=1024″).
Anschließend sollte der Raspberry Pi bzw. das Linux-System neugestartet werden.
bis jetzt läufts besser
