Hallo Leute,
wollte es mir einfach machen und bin nach diesem Tutorial vorgegangen. Dieses Tutorial bringt dieses Install-Skript mit.
# Sample configuration file for jasper-install. Please read the documentation
# for instructions.
# This file is part of the project http://github.com/bablokb/jasper-install
# Copyright Bernhard Bablok (mail at bablokb dot de)
# Released under the GPL V3
ACTIVE_STT="pocketsphinx" # choose one of the supported STT-modules
ACTIVE_TTS="espeak" # choose one of the supported TTS-modules
LOGFILE="./jasper-install.log"
PREFIX="/usr/local" # target installation directory
DEFAULT_USER="pi" # default user of this machine
USER_ADD=jasper # system-user to run system service
# will also be owner of the jasper software
SPHINX_VERSION=0.8
OPENFST_VERSION="1.3.4"
M2M_ALIGNER_VERSION="1.2"
MITLM_VERSION="0.4.1"
PHONETISAURUS_VERSION="0.8a"
JULIUS_VERSION="4.3.1"
JULIUS_AM_VERSION="0.9.0"
INSTALL_update=1 # required
INSTALL_upgrade=0 # optional, lengthy, recommended
INSTALL_swap=1 # required for pocketsphinx
INSTALL_devtools=1 # required
INSTALL_alsa=1 # optional, configures sound-system
INSTALL_user=1 # required
INSTALL_jasper=1 # required
# STT-engines (one required)
# Pocketsphinx and prereqs
INSTALL_pocketsphinx=1 # model2 only, does not work for model1
INSTALL_pocketsphinx_cfg=1 # jasper-configuration for pocketsphinx
INSTALL_pocketsphinx_src=0 # model1 needs source-compile
INSTALL_pocketsphinx_data=0 # needed if compiled from source
INSTALL_CMUCLMTK=1 # needed for pocketsphinx
INSTALL_openfst=1 # needed for pocketsphinx
INSTALL_m2m_aligner=1 # needed for pocketsphinx
INSTALL_mitlm=1 # needed for pocketsphinx
INSTALL_phonetisaurus=1 # needed for pocketsphinx
INSTALL_phonetisaurus_exp=0 # alternative, not really recommended
INSTALL_phonetisaurus_fst=1 # needed for pocketsphinx
# Julius
INSTALL_julius=1
INSTALL_julius_cfg=1 # jasper-configuration for julius
INSTALL_julius_modlex=1
# TTS-engines (one required)
INSTALL_espeak=1
INSTALL_festival=1
INSTALL_flite=1
INSTALL_svoxpico=1
INSTALL_google_tts=1
INSTALL_ivona=1
# some post-install work
INSTALL_finalize=1 # required
INSTALL_service=0 # optional
INSTALL_cleanup=0 # optional
INSTALL_thomas=0 # optional, replaces keyword JASPER with THOMAS
Alles anzeigen
Hier mal die Fehlerausgabe.
Python
File "/usr/local/lib/jasper/jasper.py", line 12, in <module>
from client import tts
File "/usr/local/lib/jasper/client/tts.py", line 41, in <module>
import diagnose
File "/usr/local/lib/jasper/client/diagnose.py", line 9, in <module>
import pip.req
File "/usr/lib/python2.7/dist-packages/pip/__init__.py", line 74, in <module>
from pip.vcs import git, mercurial, subversion, bazaar # noqa
File "/usr/lib/python2.7/dist-packages/pip/vcs/mercurial.py", line 9, in <module>
from pip.download import path_to_url
File "/usr/lib/python2.7/dist-packages/pip/download.py", line 25, in <module>
from requests.compat import IncompleteRead
ImportError: cannot import name IncompleteRead
Alles anzeigen
Hat jemand vielleicht eine Erleuchtung was da falsch gelaufen ist. Und vielen Dank fuer die Muehe.
Gruss,
gutschy
