Peppy WebRadio
  • jaja der Alzheimer schlägt zu. War es dann jar der an einer langsamen Leitung hing?
    Jedenfalls ist mir in Erinnerung, daß ich darauf aufpassen muß.
    Schönen Gruß, kle
  • Wow, you have 3 different systems.
    Did you buy all enclosures or made some of them yourself?
    As it was mentioned already the only recommendation would be to improve the
    sound quality as the sound from 3.5 mm jack is not so good. But for
    that you need to attach additional DAC or Amplifier to the GPIO. In that
    case the design becomes not so compact. Only if USB DAC is in use...
    Congratulations! Great job!
    If you have any questions/proposals feel free to post it here or contact me directly.
  • Hi peppy.player,
    with the same hardware I used NewTron-Radio.
    Instead of raspbian-lite as OS I used pipaos (pipaos-guarana-console-5.0.img.gz), a very fast and small 'raspbian-jessie-lite'.
    Sound via bluetooth to speaker JBL Go.
    I used the bluez-alsa package for bluetooth.
    Best regards, kle
    I bought them all.
    Edited once, last by kle ().
    Bluetooth is a good alternative. Though I've never used it myself.
    Could you share the details of this connection?
    What are the extra steps required? Do you really need any additional packages?
    Is it reliable connection? Does it work well with WiFi? How far you can move the speakers?
    How about sound quality?
    Thanks in advance!
  • about Raspis, Raspbian and Bluetooth
    RPi 3B and RPi Zero W have an internal bluetooth controller. You need the package pi-bluetooth to use the internal controller.
    Attention: the internal bluetooth controller uses the serial interface.
    Every Raspbian Release (wheezy, jessie and stretch) handles bluetooth devices in a special way.
    wheezy --> alsa --> bt-speaker
    jessie --> alsa --> pulseaudio1 --> bt-speaker
    stretch --> alsa2 --> bt-speaker
    1 pulseaudio sound server uses the pulseaudio-module-bluetooth to send sound to a bt-speaker.
    2 alsa uses bluealsa (package bluez-alsa) to send sound to a bt-speaker.
    jessie and stretch there is the command bluetoothctl to control bluetooth devices (scan, pair, trust, connect, disconnect, remove, ...).
    pulseaudio runs as session daemon.
    mpd runs as system daemon.
    jessie GUI has bluetooth desktop controls to connect a speaker to pulseaudio.
    stretch GUI has bluetooth desktop controls to connect a speaker to bluealsa.
    You can build bluealsa also for jessie (raspbian-jessie-lite, pipaos-guarana-console, )
    If the package pulseaudio-module-bluetooth is installed, remove it. (Afterwards jessie bluetooth desktop controls doesn't work any more!)
    Bluealsa works with jessie/stretch and mpd/vlc1/???mplayer
    1 there is an issue #23 'bad sound with VLC' and a work around. Details in Bluetooth for Peppy Player with VLC.
    Proposals for improvement welcome.
    Edited 2 times, last by kle ().
  • Bluetooth for Peppy Player with VLC
    1. The adafruit GUI image 2016-11-08-pitft-35r.zip for Peppy Player contains pulseaudio-module-bluetooth.
      To prevent problems with bluealsa it shall be removed.
      sudo apt-get remove pulseaudio-module-bluetooth
    2. Using bluealsa in jessie
      Link (ignore mpd paragraphs)
    3. Change players.txt
      nano ~/Peppy/players.txt
      [audio]
      player.name = vlc
      music.folder.linux = /home/pi/Music
      [vlc.linux]
      #server.command = --aout=alsa --alsa-audio-device=hw --verbose=-1
      server.command = --aout=alsa --alsa-audio-device=headset --verbose=-1
    4. Check vlc
      There is an issue #23 'bad sound with VLC'
      if aplay -D headset /usr/share/sounds/alsa/Front_Center.wav works
      and cvlc --aout=alsa --alsa-audio-device=headset --verbose=-1 http://st01.dlf.de/dlf/01/128/mp3/stream.mp3 doesn't
      then modify asound.conf, add line delay -20000.
    5. Run Peppy Player
      cd ~/Peppy
      sudo python3 peppy.py &
      If it works you can edit /etc/rc.local to autostart Peppy Player
      sudo nano /etc/rc.local
      cd /home/pi/Peppy
      python3 peppy.py &
      exit 0
    Edited 37 times, last by kle: use python3 ().
  • Bluetooth for Peppy Player with MPLAYER
    same as VLC except
    3. change players.txt
    [audio]
    player.name = mplayer
    [mplayer.linux]
    #server.command = mplayer -ao alsa:device=hifiberry -idle -slave -quiet -msglevel statusline=6 -msglevel global=6
    server.command = mplayer -ao alsa:device=headset -idle -slave -quiet -msglevel statusline=6 -msglevel global=6
    Edited 3 times, last by kle ().
  • New version (Vermeer Edition) of the Peppy Player was just released.
    User kle from this forum provided very valuable and helpful input for this release especially in resolving several issues related to the Peppy Player configuration. Thanks a lot Klaus! I appreciate your help very much!
    Here are the new features:
    - Replaced HiFiBerry Amp+ by HiFiBerry Amp2. That solved audiobooks playback issues.
    https://github.com/project-owner/Peppy.doc/wiki/Amplifier
    https://github.com/project-own…py.doc/wiki/HiFiBerry-Amp
    - Added CD Player mode.
    https://github.com/project-owner/Peppy.doc/wiki/CD-Player
    https://github.com/project-owner/Peppy.doc/wiki/CD-Browser
    - Made Home menu customizable.
    - Added configuration files for screensavers.
    - Refactored VU Meter screensaver.
    - Improved logging functionality.
    - Provided disk images to simplify player installation and configuration.
    https://github.com/project-own…yers.doc/wiki/Disk-Images
    - Added Wish List to the Wiki pages:
    https://github.com/project-own…layers.doc/wiki/Wish-List
    - Updated Gallery with new images depicting projects created by Klaus:
    https://github.com/project-own…yPlayers.doc/wiki/Gallery
  • New version (Rubens Edition) of the Peppy Player was released today.
    New features:
    - Streamlined the process of adding new languages.
    https://github.com/project-owner/Peppy.doc/wiki/Languages
    Here are the screenshots showing Language and Home menus in Japanese:
    [Blocked Image: https://raw.githubusercontent.com/project-owner/Peppy.doc/master/images/software/j-2.png]
    [Blocked Image: https://raw.githubusercontent.com/project-owner/Peppy.doc/master/images/software/j-3.png]
    - Added CD album art functionality. The CD cover images are retrieved from the largest free web collection on Discogs.com. Here are examples of CD Player with album art:
    [Blocked Image: https://raw.githubusercontent.com/project-owner/Peppy.doc/master/images/software/cd-art-1.png]
    [Blocked Image: https://raw.githubusercontent.com/project-owner/Peppy.doc/master/images/software/cd-art-2.png]
    - Made Screensaver and Language menus customizable.
    - Implemented Weather forecast screensaver.
    https://github.com/project-owner/Peppy.doc/wiki/Weather
    Here are the examples of the Weather screensaver:
    [Blocked Image: https://raw.githubusercontent.com/project-owner/Peppy.doc/master/images/software/weather-de.png]
    [Blocked Image: https://raw.githubusercontent.com/project-owner/Peppy.doc/master/images/software/weather-fr.png]
    - Added information about connecting Bluetooth devices.
    https://github.com/project-own…oc/wiki/Bluetooth-Devices
    - Provided disk images.
  • Nach der Installation kann ich Peppy starten, wenn ich es aus dem Ordner Peppy starte läuft alles, beim Start aus dem pi Verzeichnis mit Python3 /home/pi/Peppy/peppy.py kommt die Fehlermeldung unten:
    Jemand eine Idee?
    Ziel ist es Peppy automatisch zu starten. Wie kann man Peppy mit Hilfe der LXDE Autostart starten? Müsse zuerst wissen warum man nicht aus einem anderen Order starten kann.
    File "/usr/lib/python3.5/configparser.py", line 1135, in _unify_values
    sectiondict = self._sections[section]
    KeyError: 'screen.info'
    During handling of the above exception, another exception occurred:
    File "./Peppy/peppy.py", line 1120, in <module>
    main()
    File "./Peppy/peppy.py", line 1116, in main
    peppy = Peppy()
    File "./Peppy/peppy.py", line 70, in __init__
    self.util = Util()
    File "/home/pi/Peppy/util/util.py", line 123, in __init__
    self.config_class = Config()
    File "/home/pi/Peppy/util/config.py", line 91, in __init__
    self.load_config(self.config)
    File "/home/pi/Peppy/util/config.py", line 112, in load_config
    c = {WIDTH : config_file.getint(SCREEN_INFO, WIDTH)}
    File "/usr/lib/python3.5/configparser.py", line 816, in getint
    fallback=fallback, **kwargs)
    File "/usr/lib/python3.5/configparser.py", line 806, in _get_conv
    **kwargs)
    File "/usr/lib/python3.5/configparser.py", line 800, in _get
    return conv(self.get(section, option, **kwargs))
    File "/usr/lib/python3.5/configparser.py", line 778, in get
    d = self._unify_values(section, vars)
    File "/usr/lib/python3.5/configparser.py", line 1138, in _unify_values
    raise NoSectionError(section)
    configparser.NoSectionError: No section: 'screen.info'
  • Peppy kann die Konfigurationsdatei nicht finden, wenn du sie aus einem anderen Ordner starten.
    Du müssen zuerst den Ordner wechseln. Zum Beispiel um den Spieler automatisch zu starten
    Beim Start kann die folgende Zeile zur Datei /etc/rc.local hinzugefügt werden:
    su pi -c 'cd /home/pi/Peppy; openvt -s -- python3 peppy.py'
    Dies wird hier beschrieben:
    https://github.com/project-own…peppy-player-installation
    Tschüss
  • Mein System:
    Raspbian 4.14
    Kedei 3,5" Touchscreen
    sonst erstmal nichts.
    Autostart mit rc.local startet bevor die Oberfläche gestartet ist -> funktioniert bei mir nicht, daher wollte ich Peppy in der /etc/xdg/lxsession/LXDE-pi/autostart eintragen.
    Du bootest in die grafische Oberfläche.
    Der Peppy-Player läuft in der Konsole.
    Ich habe es nur über RealVNC geschafft, den Peppy-Player in der grafischen Oberfläche zu automatisch starten. Der TFT-Screen bleibt dann schwarz.
    Auch kalibrieren mit kleinen Displays ist schwierig.
    ---- prinzipiell sollte es so gehen: ---
    zum Autostart von Programmen mit Grafik-Oberfläche (hier pygame) bei Desktop (oder auch GUI genannt) sollte X11 gestartet sein.
    ich würde die Datei /home/pi/.config/lxsession/LXDE-pi/autostart benutzen, da das peppy.py unter dem Benutzer 'pi' laufen muß (wegen der Rechte).
    • Du erzeugst das bin-Unterverzeichnis mit cd /home/pi; mkdir bin
    • dort erzeugst Du ein Start-Script /home/pi/bin/peppy-start.sh.
      Inhalt siehe unten.
    • Du machst es ausführbar mit chmod +x /home/pi/bin/peppy-start.sh
    • In der Autostart-Datei /home/pi/.config/lxsession/LXDE-pi/autostart fügst Du am Ende die Zeile /home/pi/bin/peppy-start.sh
    Bash: /home/pi/bin/peppy-start.sh
    #!/bin/sh
    cd /home/pi/Peppy
    Aber, wie gesagt das Touchdisplay bleibt schwarz.
    Schönen Gruß, kle
  • Ich habe diese anzeige noch nie probiert. Soweit ich verstehe, funktioniert diese anzeige nur mit einem eigenen Disk-Image, das einen grafischen desktop (X) hat. Ist es möglich, bildschirmtreiber auf Raspbian Stretch Lite zu installieren, die keinen grafischen desktop haben?
