und zwar habe ich auf Openhabian, Homegear installiert und mit einer anderen SD-Karte meine HM-MOD-RPI-PCB, über Yahm auf den neusten Firmware stand gebracht (2.8.5?).
Nun wollte ich mit dem Befehl "pon" in Homegear meinen Funk Heizkörperthermostat von Homematic verbinden doch leider ohne Erfolg.
Die Config.txt und cmdline.txt wurden nach Anleitungen geändert und sehen so aus:
config.txt:
# For more options and information see# http://rpf.io/configtxt# Some settings may impact device functionality. See link above for details# uncomment if you get no picture on HDMI for a default "safe" mode#hdmi_safe=1# uncomment this if your display has a black border of unused pixels visible# and your display can output without overscan#disable_overscan=1# uncomment the following to adjust overscan. Use positive numbers if console# goes off screen, and negative if there is too much border#overscan_left=16#overscan_right=16#overscan_top=16#overscan_bottom=16# uncomment to force a console size. By default it will be display's size minus# overscan.#framebuffer_width=1280#framebuffer_height=720# uncomment if hdmi display is not detected and composite is being output#hdmi_force_hotplug=1# uncomment to force a specific HDMI mode (this will force VGA)#hdmi_group=1#hdmi_mode=1# uncomment to force a HDMI mode rather than DVI. This can make audio work in# DMT (computer monitor) modes#hdmi_drive=2# uncomment to increase signal to HDMI, if you have interference, blanking, or# no display#config_hdmi_boost=4# uncomment for composite PAL#sdtv_mode=2#uncomment to overclock the arm. 700 MHz is the default.#arm_freq=800# Uncomment some or all of these to enable the optional hardware interfaces#dtparam=i2c_arm=on#dtparam=i2s=on#dtparam=spi=on# Uncomment this to enable the lirc-rpi module#dtoverlay=lirc-rpi# Additional overlays and parameters are documented /boot/overlays/README# Enable audio (loads snd_bcm2835)dtparam=audio=ondtoverlay=pi3-miniuart-btdtparam=spi=onenable_uart=1gpu_mem=16dtparam=i2c_arm=on
cmdline.txt:
dwc_otg.lpm_enable=0 console=tty1 root=PARTUUID=9bff6b8e-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait
Homegear.log:
04/24/18 19:21:44.380 Module HomeMatic BidCoS: HM-MOD-RPI-PCB "My-HM-MOD-RPI-PCB": Error: No response received to packet: FD0003000003180A04/24/18 19:21:44.380 Module HomeMatic BidCoS: HM-MOD-RPI-PCB "My-HM-MOD-RPI-PCB": Error: Unknown packet received in response to init packet. Reconnecting...04/24/18 19:21:45.956 Module HomeMatic BidCoS: HM-MOD-RPI-PCB "My-HM-MOD-RPI-PCB": Warning: Connection closed (1). Trying to reconnect...04/24/18 19:21:45.956 Module HomeMatic BidCoS: HM-MOD-RPI-PCB "My-HM-MOD-RPI-PCB": Connecting to HM-MOD-RPI-PCB...04/24/18 19:21:47.957 Module HomeMatic BidCoS: HM-MOD-RPI-PCB "My-HM-MOD-RPI-PCB": Connected to HM-MOD-RPI-PCB.04/24/18 19:21:47.957 Debug: GPIO 18 set to 0.04/24/18 19:21:48.057 Debug: GPIO 18 set to 1.04/24/18 19:21:48.093 Module HomeMatic BidCoS: HM-MOD-RPI-PCB "My-HM-MOD-RPI-PCB": Debug: Packet received. Raw data: FD000C000000436F04/24/18 19:21:48.094 Module HomeMatic BidCoS: HM-MOD-RPI-PCB "My-HM-MOD-RPI-PCB": Debug: Packet received. Raw data: 5F4350555F424C7204/24/18 19:21:48.094 Module HomeMatic BidCoS: HM-MOD-RPI-PCB "My-HM-MOD-RPI-PCB": Debug: Packet received. Raw data: 5104/24/18 19:21:48.094 Module HomeMatic BidCoS: HM-MOD-RPI-PCB "My-HM-MOD-RPI-PCB": Debug: Packet received from HM-MOD-RPI-PCB: FD000C000000436F5F4350555F424C725104/24/18 19:21:49.094 Module HomeMatic BidCoS: HM-MOD-RPI-PCB "My-HM-MOD-RPI-PCB": Debug: Sending: FD0003000003180A04/24/18 19:21:49.625 Module HomeMatic BidCoS: HM-MOD-RPI-PCB "My-HM-MOD-RPI-PCB": Debug: Packet received. Raw data: FD0004000004019904/24/18 19:21:49.626 Module HomeMatic BidCoS: HM-MOD-RPI-PCB "My-HM-MOD-RPI-PCB": Debug: Packet received. Raw data: 3D04/24/18 19:21:49.626 Module HomeMatic BidCoS: HM-MOD-RPI-PCB "My-HM-MOD-RPI-PCB": Debug: Packet received from HM-MOD-RPI-PCB: FD000400000401993D04/24/18 19:21:49.664 Module HomeMatic BidCoS: HM-MOD-RPI-PCB "My-HM-MOD-RPI-PCB": Debug: Packet received. Raw data: FD0010FE0100447504/24/18 19:21:49.665 Module HomeMatic BidCoS: HM-MOD-RPI-PCB "My-HM-MOD-RPI-PCB": Debug: Packet received. Raw data: 616C436F50726F5F04/24/18 19:21:49.666 Module HomeMatic BidCoS: HM-MOD-RPI-PCB "My-HM-MOD-RPI-PCB": Debug: Packet received. Raw data: 417070B73604/24/18 19:21:49.666 Module HomeMatic BidCoS: HM-MOD-RPI-PCB "My-HM-MOD-RPI-PCB": Debug: Packet received from HM-MOD-RPI-PCB: FD0010FE01004475616C436F50726F5F417070B73604/24/18 19:21:54.095 Module HomeMatic BidCoS: HM-MOD-RPI-PCB "My-HM-MOD-RPI-PCB": Error: No response received to packet: FD0003000003180A04/24/18 19:21:54.095 Module HomeMatic BidCoS: HM-MOD-RPI-PCB "My-HM-MOD-RPI-PCB": Error: Unknown packet received in response to init packet. Reconnecting...04/24/18 19:21:55.671 Module HomeMatic BidCoS: HM-MOD-RPI-PCB "My-HM-MOD-RPI-PCB": Warning: Connection closed (1). Trying to reconnect...04/24/18 19:21:55.671 Module HomeMatic BidCoS: HM-MOD-RPI-PCB "My-HM-MOD-RPI-PCB": Connecting to HM-MOD-RPI-PCB...04/24/18 19:21:56.029 RPC Server (Port 2001): Debug: Packet received: 42696E000000001C0000000470696E67000000010000000300000008633265353966343704/24/18 19:21:56.029 RPC Server (Port 2001): Info: Client number 16 is calling RPC method: ping (2) Parameters:(String) c2e59f4704/24/18 19:21:56.029 RPC Server (Port 2001): Response: (Boolean) 104/24/18 19:21:56.029 RPC client: Debug: Calling RPC method "system.multicall" on server 192.168.0.104.04/24/18 19:21:56.029 RPC client: Parameters:04/24/18 19:21:56.029 RPC Server (Port 2001): Response binary:42696E01000000050000000201(Array length=1){ (Struct length=2) { [methodName] { (String) event } [params] { (Array length=4) { (String) RF-c2e59f47 (String) CENTRAL (String) PONG (String) c2e59f47 } } }}04/24/18 19:21:56.029 Debug: Calling getFileDescriptor...04/24/18 19:21:56.030 Debug: Connecting to host 192.168.0.104 on port 9126...04/24/18 19:21:56.030 Debug: Connected to host 192.168.0.104 on port 9126. Client number is: 20604/24/18 19:21:56.031 RPC client: Debug: Sending packet: 42696E00000000930000001073797374656D2E6D756C746963616C6C00000001000001000000000100000101000000020000000A6D6574686F644E616D6500000003000000056576656E7400000006706172616D730000010000000004000000030000000B52462D6332653539663437000000030000000743454E5452414C0000000300000004504F4E470000000300000008633265353966343704/24/18 19:21:56.032 RPC client: Debug: Packet received: 42696E0100000015000001000000000100000003000000056576656E7404/24/18 19:21:56.033 RPC client: Debug: Received packet from server 192.168.0.104: 42696E0100000015000001000000000100000003000000056576656E7404/24/18 19:21:56.033 RPC client: Response was:(Array length=1){ (String) event}04/24/18 19:21:57.672 Module HomeMatic BidCoS: HM-MOD-RPI-PCB "My-HM-MOD-RPI-PCB": Connected to HM-MOD-RPI-PCB.04/24/18 19:21:57.672 Debug: GPIO 18 set to 0.04/24/18 19:21:57.772 Debug: GPIO 18 set to 1.04/24/18 19:21:57.808 Module HomeMatic BidCoS: HM-MOD-RPI-PCB "My-HM-MOD-RPI-PCB": Debug: Packet received. Raw data: FD000C000000436F04/24/18 19:21:57.809 Module HomeMatic BidCoS: HM-MOD-RPI-PCB "My-HM-MOD-RPI-PCB": Debug: Packet received. Raw data: 5F4350555F424C7204/24/18 19:21:57.809 Module HomeMatic BidCoS: HM-MOD-RPI-PCB "My-HM-MOD-RPI-PCB": Debug: Packet received. Raw data: 5104/24/18 19:21:57.809 Module HomeMatic BidCoS: HM-MOD-RPI-PCB "My-HM-MOD-RPI-PCB": Debug: Packet received from HM-MOD-RPI-PCB: FD000C000000436F5F4350555F424C725104/24/18 19:21:58.809 Module HomeMatic BidCoS: HM-MOD-RPI-PCB "My-HM-MOD-RPI-PCB": Debug: Sending: FD0003000003180A04/24/18 19:21:59.340 Module HomeMatic BidCoS: HM-MOD-RPI-PCB "My-HM-MOD-RPI-PCB": Debug: Packet received. Raw data: FD0004000004019904/24/18 19:21:59.345 Module HomeMatic BidCoS: HM-MOD-RPI-PCB "My-HM-MOD-RPI-PCB": Debug: Packet received. Raw data: 3D04/24/18 19:21:59.345 Module HomeMatic BidCoS: HM-MOD-RPI-PCB "My-HM-MOD-RPI-PCB": Debug: Packet received from HM-MOD-RPI-PCB: FD000400000401993D04/24/18 19:21:59.379 Module HomeMatic BidCoS: HM-MOD-RPI-PCB "My-HM-MOD-RPI-PCB": Debug: Packet received. Raw data: FD0010FE0100447504/24/18 19:21:59.380 Module HomeMatic BidCoS: HM-MOD-RPI-PCB "My-HM-MOD-RPI-PCB": Debug: Packet received. Raw data: 616C436F50726F5F04/24/18 19:21:59.381 Module HomeMatic BidCoS: HM-MOD-RPI-PCB "My-HM-MOD-RPI-PCB": Debug: Packet received. Raw data: 417070B73604/24/18 19:21:59.381 Module HomeMatic BidCoS: HM-MOD-RPI-PCB "My-HM-MOD-RPI-PCB": Debug: Packet received from HM-MOD-RPI-PCB: FD0010FE01004475616C436F50726F5F417070B73604/24/18 19:22:03.810 Module HomeMatic BidCoS: HM-MOD-RPI-PCB "My-HM-MOD-RPI-PCB": Error: No response received to packet: FD0003000003180A04/24/18 19:22:03.810 Module HomeMatic BidCoS: HM-MOD-RPI-PCB "My-HM-MOD-RPI-PCB": Error: Unknown packet received in response to init packet. Reconnecting...04/24/18 19:22:05.385 Module HomeMatic BidCoS: HM-MOD-RPI-PCB "My-HM-MOD-RPI-PCB": Warning: Connection closed (1). Trying to reconnect...04/24/18 19:22:05.386 Module HomeMatic BidCoS: HM-MOD-RPI-PCB "My-HM-MOD-RPI-PCB": Connecting to HM-MOD-RPI-PCB...04/24/18 19:22:07.386 Module HomeMatic BidCoS: HM-MOD-RPI-PCB "My-HM-MOD-RPI-PCB": Connected to HM-MOD-RPI-PCB.04/24/18 19:22:07.387 Debug: GPIO 18 set to 0.04/24/18 19:22:07.487 Debug: GPIO 18 set to 1.
Homegear.err:
Hoffe es erkennt jemand den Fehler und kann mein Problem lösen
Danke schonmal & LG
