ich versuche seit Stunden meinen Flightradar unter Raspbian Stretch in Betrieb zu nehmen.
Damit dump1090 bzw. fr24feed auf den RTL2838 Stick zugreifen können muss ich beide Dienste stoppen und fr24feed von Hand starten. Dort kommt dann folgende Ausgabe:
pi@flightradar:~ $ sudo fr24feed
2018-09-12 15:46:41 | [main][i]FR24 Feeder/Decoder
2018-09-12 15:46:41 | [main][i]Version: 1.0.19-15/generic
2018-09-12 15:46:41 | [main][i]Built on Feb 6 2018 09:19:16 (HEAD-0bb4994.git/Linux/static_arm)
2018-09-12 15:46:41 | [main][i]Running on: pi24-raspbian9
2018-09-12 15:46:41 | [main][i]Local IP(s): 192.168.178.20
2018-09-12 15:46:41 | [main][i]Copyright 2012-2018 Flightradar24 AB
2018-09-12 15:46:41 | [main][i]https://www.flightradar24.com
2018-09-12 15:46:41 | [main][i]DNS mode: PING
2018-09-12 15:46:41 | [main][i]Automatic updates are ENABLED
2018-09-12 15:46:41 | ERROR
2018-09-12 15:46:41 | [w]Detected --net argument for dump1090, disabling internal RAW feed!
2018-09-12 15:46:41 | [w]Detected --net argument for dump1090, disabling internal BS feed!
2018-09-12 15:46:41 | [main][i]Reader thread started
2018-09-12 15:46:41 | [main][i]MLAT data feed started
2018-09-12 15:46:41 | [mlat][i]Waiting for MLAT configuration
2018-09-12 15:46:41 | [reader][i]Initializing reader
2018-09-12 15:46:41 | [reader][i]Connecting to DVBT receiver via (exe:///usr/bin/dump1090-mutability --net --net-http-port 8080 --raw --mlat)
2018-09-12 15:46:41 | [master][i]Starting processing thread
2018-09-12 15:46:41 | [httpd][i]Server started, listening on 0.0.0.0:8754
2018-09-12 15:46:41 | [reader][i]Connected to the receiver, configuring
2018-09-12 15:46:41 | [reader][i]Configured, processing messages
Wed Sep 12 15:46:41 2018 UTC dump1090-mutability v1.14 starting up.
Found 1 device(s):
0: Realtek, RTL2838UHIDIR, SN: 00000001 (currently selected)
Found Fitipower FC0012 tuner
Max available gain is: 19.20 dB
Setting gain to: 19.20 dB
[FC0012] no valid PLL combination found for 1090000000 Hz!
Exact sample rate is: 2000000.052982 Hz
Gain reported by device: 19.20 dB
2018-09-12 15:46:42 | [time][i]Synchronizing time via NTP
2018-09-12 15:47:09 | [time][i]Time synchronized correctly, offset -0.0015 seconds
2018-09-12 15:47:09 | [main][i]Feed Network client started
2018-09-12 15:47:09 | [feed][i]Downloading configuration
2018-09-12 15:47:10 | [feed][c]Interval: 5s
2018-09-12 15:47:10 | [feed][c]Latitude: XX.XXXX
2018-09-12 15:47:10 | [feed][c]Longitude: X.XXXX
2018-09-12 15:47:10 | [feed][c]GND: YES
2018-09-12 15:47:10 | [feed][c]NonADSB: YES
2018-09-12 15:47:10 | [feed][c]Timestamps: optional
2018-09-12 15:47:10 | [feed][c]Max range AIR: 350.0nm
2018-09-12 15:47:10 | [feed][c]Max range GND: 100.0nm
2018-09-12 15:47:10 | [feed][i]defined 4 servers
2018-09-12 15:47:10 | [feed][n]XXXXXXX@XXX.XXX.XX.XX:8099/UDP
2018-09-12 15:47:10 | [feed][n]connecting
2018-09-12 15:47:10 | [stats][i]Stats thread started
2018-09-12 15:47:10 | [feed][n]connected via UDP (fd 7)
2018-09-12 15:47:10 | [feed][n]working
2018-09-12 15:47:40 | [feed][n]ping 1
2018-09-12 15:47:41 | [feed][n]syncing stream result: 1
2018-09-12 15:48:10 | [feed][n]ping 2
2018-09-12 15:48:11 | [feed][n]syncing stream result: 1
2018-09-12 15:48:40 | [feed][n]ping 3
2018-09-12 15:48:41 | [feed][n]syncing stream result: 1
2018-09-12 15:49:10 | [feed][n]ping 4
2018-09-12 15:49:11 | [feed][n]syncing stream result: 1
^C2018-09-12 15:49:27 | [main][i]Terminating on user request
2018-09-12 15:49:27 | [main][i]Terminating worker threads
Wed Sep 12 15:49:27 2018 UTC Caught SIGINT, shutting down..
Wed Sep 12 15:49:27 2018 UTC Normal exit.
2018-09-12 15:49:27 | [reader][i]Connection terminated
2018-09-12 15:49:27 | [main][i]Terminating child process 3293 with SIGTERM
2018-09-12 15:49:27 | [reader][i]Terminating on request
2018-09-12 15:49:29 | [master][i]Terminating on request
2018-09-12 15:49:29 | [feed][n]busy
2018-09-12 15:49:29 | [feed][n]disconnected
2018-09-12 15:49:29 | [feed][x]Feeding thread terminated
Bei FlightRadar24 wird mein Radar als Offline angezeigt, obwohl er ja eigentlich online sein sollte. Wenn ich den fr24feed Dienst wieder aktiviere und fr24feed-status eingebe, erhalte ich folgende Ausgabe:
pi@flightradar:~ $ sudo fr24feed-status
[ ok ] FR24 Feeder/Decoder Process: running.
[ ok ] FR24 Stats Timestamp: 2018-09-12 15:51:05.
[ ok ] FR24 Link: connected [UDP].
[ ok ] FR24 Radar: T-XXXXXXX.
[ ok ] FR24 Tracked AC:.
[ ok ] Receiver: connected ( MSGS/ SYNC).
[FAIL] FR24 MLAT: not running ... failed!
Ich weiß so langsam nicht mehr weiter, zumal ich auch der Meinung bin dass sowas ohne Probleme funktionieren sollte, vor allem beim offiziellen Image von FlightRadar24 (basiert auf einem älteren Raspbian Stretch), welches ich verwende.
Ich hoffe ihr könnt mir bei meinem Problem helfen und ich soweit alle nötigen Info mitgegeben habe, falls nicht, sagt bitte einfach Bescheid.
