ich bin mitlerweile am verzweifeln, ich habe versucht alexa auf meinem raspberry zu installieren und bin der Anleitung gefolgt...
leider bekomme ich bei der ausführung von mvn exec:exec folgenden Fehler
(Terminal 1 ist aktiv)
pi@raspberrypi:~/alexa-avs-sample-app/samples/javaclient $ mvn exec:exec -e
[INFO] Error stacktraces are turned on.
[INFO] Scanning for projects...
[INFO]
[INFO] ------------------------------------------------------------------------
[INFO] Building Alexa Voice Service Sample Java Client 20160207.8
[INFO]
[INFO] --- exec-maven-plugin:1.2.1:exec (default-cli) @ sample-java-client ---
Exception in thread "main" javax.json.stream.JsonParsingException: Unexpected char 103 at (line no=1, column no=1, offset=0)
at org.glassfish.json.JsonTokenizer.unexpectedChar(JsonTokenizer.java:532)
at org.glassfish.json.JsonTokenizer.nextToken(JsonTokenizer.java:415)
at org.glassfish.json.JsonParserImpl$NoneContext.getNextEvent(JsonParserImpl.java:222)
at org.glassfish.json.JsonParserImpl$StateIterator.next(JsonParserImpl.java:172)
at org.glassfish.json.JsonParserImpl.next(JsonParserImpl.java:149)
at org.glassfish.json.JsonReaderImpl.readObject(JsonReaderImpl.java:101)
at com.amazon.alexa.avs.config.DeviceConfigUtils.readConfigFile(DeviceConfigUtils.java:64)
at com.amazon.alexa.avs.config.DeviceConfigUtils.readConfigFile(DeviceConfigUtils.java:50)
at com.amazon.alexa.avs.App.<init>(App.java:39)
at com.amazon.alexa.avs.App.main(App.java:34)
[INFO] BUILD FAILURE
[INFO] Total time: 3.772 s
[INFO] Finished at: 2018-11-10T17:28:02+01:00
[INFO] Final Memory: 8M/20M
[ERROR] Failed to execute goal org.codehaus.mojo:exec-maven-plugin:1.2.1:exec (default-cli) on project sample-java-client: Command execution failed. Process exited with an error: 1 (Exit value: 1) -> [Help 1]
org.apache.maven.lifecycle.LifecycleExecutionException: Failed to execute goal org.codehaus.mojo:exec-maven-plugin:1.2.1:exec (default-cli) on project sample-java-client: Command execution failed.
at org.apache.maven.lifecycle.internal.MojoExecutor.execute(MojoExecutor.java:212)
at org.apache.maven.lifecycle.internal.MojoExecutor.execute(MojoExecutor.java:153)
at org.apache.maven.lifecycle.internal.MojoExecutor.execute(MojoExecutor.java:145)
at org.apache.maven.lifecycle.internal.LifecycleModuleBuilder.buildProject(LifecycleModuleBuilder.java:116)
at org.apache.maven.lifecycle.internal.LifecycleModuleBuilder.buildProject(LifecycleModuleBuilder.java:80)
at org.apache.maven.lifecycle.internal.builder.singlethreaded.SingleThreadedBuilder.build(SingleThreadedBuilder.java:51)
at org.apache.maven.lifecycle.internal.LifecycleStarter.execute(LifecycleStarter.java:128)
at org.apache.maven.DefaultMaven.doExecute(DefaultMaven.java:307)
at org.apache.maven.DefaultMaven.doExecute(DefaultMaven.java:193)
at org.apache.maven.DefaultMaven.execute(DefaultMaven.java:106)
at org.apache.maven.cli.MavenCli.execute(MavenCli.java:863)
at org.apache.maven.cli.MavenCli.doMain(MavenCli.java:288)
at org.apache.maven.cli.MavenCli.main(MavenCli.java:199)
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
at java.lang.reflect.Method.invoke(Method.java:497)
at org.codehaus.plexus.classworlds.launcher.Launcher.launchEnhanced(Launcher.java:289)
at org.codehaus.plexus.classworlds.launcher.Launcher.launch(Launcher.java:229)
at org.codehaus.plexus.classworlds.launcher.Launcher.mainWithExitCode(Launcher.java:415)
at org.codehaus.plexus.classworlds.launcher.Launcher.main(Launcher.java:356)
Caused by: org.apache.maven.plugin.MojoExecutionException: Command execution failed.
at org.codehaus.mojo.exec.ExecMojo.execute(ExecMojo.java:362)
at org.apache.maven.plugin.DefaultBuildPluginManager.executeMojo(DefaultBuildPluginManager.java:134)
at org.apache.maven.lifecycle.internal.MojoExecutor.execute(MojoExecutor.java:207)
... 20 more
Caused by: org.apache.commons.exec.ExecuteException: Process exited with an error: 1 (Exit value: 1)
at org.apache.commons.exec.DefaultExecutor.executeInternal(DefaultExecutor.java:377)
at org.apache.commons.exec.DefaultExecutor.execute(DefaultExecutor.java:160)
at org.codehaus.mojo.exec.ExecMojo.executeCommandLine(ExecMojo.java:610)
at org.codehaus.mojo.exec.ExecMojo.execute(ExecMojo.java:352)
... 22 more
[ERROR]
[ERROR] Re-run Maven using the -X switch to enable full debug logging.
[ERROR]
[ERROR] For more information about the errors and possible solutions, please read the following articles:
[ERROR] [Help 1] http://cwiki.apache.org/confluence/dis…cutionException
BITTE UM HILFE Danke lg
