Failed to start /etc/rc.local Compatibility.
  • Beim Systemstart meines aktuellen Raspbians listet er auf was er macht und kurz vor Schluss kommt folgende Fehlermeldung:
    See `systemct] status rc-local.service` for details.
    Starting Hold until boot process finished up...
    Starting Terminate Plymouth BootScreen...
    Ich weiss nicht was das bedeutet, das System macht sonst keine auffaelligen Probleme. Ich hatte die Aufloesung geaendert und die eine oder andere Software installiert, seitdem kam das irgendwann. Weiss jemand was das bedeutet und wie man das fixen kann?
    Raspberry Pi 3
    Raspian GNU/Linux 8.0 (Jessie)
    Kernel: 4.9.35-v7*
  • 1.
    pi@raspberrypi:~ $ cat /etc/rc.local
    #!/bin/sh -e
    # rc.local
    # This script is executed at the end of each multiuser runlevel.
    # Make sure that the script will "exit 0" on success or any other
    # value on error.
    # In order to enable or disable this script just change the execution
    # bits.
    # By default this script does nothing.
    # Print the IP address
    _IP=$(hostname -I) || true
    if [ "$_IP" ]; then
    printf "My IP address is %s\n" "$_IP"
    fi
    /usr/bin/numlockx on
    exit 0
    2.
    pi@raspberrypi:~ $ systemctl cat rc-local.service
    # Warning: rc-local.service changed on disk, the version systemd has loaded is o
    # This output shows the current version of the unit's original fragment and drop
    # If fragments or drop-ins were added or removed, they are not properly reflecte
    # Run 'systemctl daemon-reload' to reload units.
    # /lib/systemd/system/rc-local.service
    # This file is part of systemd.
    # systemd is free software; you can redistribute it and/or modify it
    # under the terms of the GNU Lesser General Public License as published by
    # the Free Software Foundation; either version 2.1 of the License, or
    # (at your option) any later version.
    # This unit gets pulled automatically into multi-user.target by
    # systemd-rc-local-generator if /etc/rc.local is executable.
    [Unit]
    Description=/etc/rc.local Compatibility
    ConditionFileIsExecutable=/etc/rc.local
    After=network.target
    [Service]
    Type=forking
    3.
    pi@raspberrypi:~ $ systemd-analyze blame
    21.668s nmbd.service
    7.633s hciuart.service
    3.223s apt-daily.service
    1.912s dev-mmcblk0p2.device
    1.647s apt-daily-upgrade.service
    1.546s raspi-config.service
    1.342s networking.service
    1.210s smbd.service
    925ms lightdm.service
    923ms dphys-swapfile.service
    543ms keyboard-setup.service
    491ms exagear-guest-raspbian-8.service
    407ms systemd-fsck-root.service
    393ms rc-local.service
    383ms systemd-fsck@dev-disk-by\x2dpartuuid-fce36bff\x2d01.service
    369ms systemd-timesyncd.service
    339ms run-rpc_pipefs.mount
    337ms dhcpcd.service
    336ms sys-kernel-debug.mount
    336ms triggerhappy.service
    328ms systemd-udev-trigger.service
    319ms colord.service
    305ms systemd-logind.service
    4.
    pi@raspberrypi:~ $ systemd-analyze time
    Startup finished in 1.824s (kernel) + 27.556s (userspace) = 29.381s
    Raspberry Pi 3
    Kernel: 4.9.35-v7*
  • Ist das alles?
    Welches raspbian hast Du auf deinem PI? So sieht das z. B. auf meinem stretch aus:
  • Der vorletzten Zeile in der rc.local würde ich noch ein & spendieren und damit in den Hintergrund schicken, also:
    fi
    /usr/bin/numlockx on &
    exit 0
    "Alles, was wir sind, ist Sand im Wind, Hoschi."
  • Ich habe das allerneueste Raspbian.
    Wie aendere ich den Eintrag? Ich habe ein Tool installiert womit beim Start automatisch Numlock aktiviert wird. Ich besitze einen Keyrah Adapter damit meine Amiga 1200 Tastatur wenigstens ein Laempchen leuchtet. Scheinbar hat es damit zutun (?).
    Raspberry Pi 3
    Kernel: 4.9.35-v7*
  • Fehler ist weg, danke! Aber der Startbildschirm erscheint nicht, stattdessen listet er mir beim starten auf was er macht. Wie kann ich de Startbildschirm wieder aktivieren?
    Raspberry Pi 3
    Kernel: 4.9.35-v7*
  • Evtl. hast Du in der /boot/config.txt einen Eintrag mit disable_splash=1? Falls ja, dann
    1. sudo nano /boot/config.txt
    und ändere den Wert auf 0, also disable_splash=0.
    Aber das ist ein anderes Thema...
  • Ne, dieser Eintrag fehlt voellig in der config.txt. Hatte ihn manuell eingefuegt, aber leider ohne Erfolg.
    Stimmt, ist eigentlich ein anderes Thema. Aber dadurch kam der Fehler zum Vorschein. Vielleicht hat das System das extra gemacht damit man den Fehler sehe nkann (?).
    Raspberry Pi 3
    Kernel: 4.9.35-v7*
  • Thema trotzdem soweit erledigt, habe vielen Dank. Vielleicht mache ich einen neuen Thread auf falls Google nichts dazu findet.
    Raspberry Pi 3
    Kernel: 4.9.35-v7*
  • Jo, wieder Volltreffer, das war es gewesen, danke dir! Frage mich nur wie sich das umstellen konnte, ich habe dort nichts gemacht.
    Raspberry Pi 3
    Kernel: 4.9.35-v7*
