pi@raspberrypi:~ $ sudo su
root@raspberrypi:/home/pi# docker run \
> -it \
> -v $(pwd)/data:/app/data \
> --device=/dev/serial/by-id/usb-Texas_Instruments_TI_CC2531_USB_CDC___0X00124B0018E32C4C-if00
"docker run" requires at least 1 argument.
See 'docker run --help'.
Usage: docker run [OPTIONS] IMAGE [COMMAND] [ARG...]
Run a command in a new container
root@raspberrypi:/home/pi# sudo koenkk/zigbee2mqtt:arm32v6
sudo: koenkk/zigbee2mqtt:arm32v6: Befehl nicht gefunden
Das kommt raus....???
