Es gibt ein neues Debian sowie Arch Linux ARM build.
Download
The Debian image contains the following updates to the prior 13-04-2012 release:
- Dom’s overscan adjustments
- Dom’s ALSA driver
- re-enable 1600×1200 output (regression in 13-04-2012 release)
- boot file tidyup – and remove test cmdline file
- vcgencmd provides a version number
- fixes for EDID parsing
- drive DMT modes in DVI modes by default, even if HDMI is reported as supported
- some initial packages that might make setting up Wi-Fi possible
- includes the non-free software source (nothing from it though) – useful for Wi-Fi firmware
- the latest snapshot of the Qt5 code
- a small package that will allow Raspberry Pi to be used as for Qt5 development out of the box
- Raspberry Pi wallpaper on white background
- LXDE theme for user “pi” is now “mist” (performance improvement)
- a new Python IDE “spe” and related tools
- winpdb – python debugger
- wxglade – python dialogue designer
- python-pygame
- the “scratch” educational programming tool and required squeak-vm
- lxtask – runs a task manager when CTRL-ALT-DEL pressed in LXDE
- release identification in /etc/issue-rpi and /boot/issue.txt
- ssh disabled by default – boot commands taken from /boot/boot.rc if present – candidate to enable ssh included
- timezone set to Europe/London
- tidied hidden files
- package cache is clean
Mehr Infos gibt es hier:
Quelle: http://www.raspberrypi.org/archives/1097
