Ambilight flimmert auf einmal
  • Hey,
    von jetzt auf gleich fängt mein Ambilight an zu flimmern, nachdem es die ganze Zeit super funktioniert hat.
    Ja, ich habe einen Pegelwandler verbaut, andere Komponenten:
    Splitter: https://www.amazon.de/gp/product/B01615JA3A/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1 (Affiliate-Link) [Anzeige]
    Converter: https://www.amazon.de/gp/product/B01AG0MDY4/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1 (Affiliate-Link) [Anzeige]
    LED: https://www.amazon.de/gp/product/B06X9YC8N2/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1 (Affiliate-Link) [Anzeige]
    Netzteil: https://www.ebay.de/itm/Netzte…m:mZLb5mZFisKe1mLAMHlcVlg (RS-150-5 -130W, 5V)
    Raspberry Pi 3
    Config:
    Spoiler anzeigen
    // Automatically generated configuration file for Hyperion ambilight daemon
    // Notice: All values are explained with comments at our wiki: wiki.hyperion-project.org (config area)
    // Generated by: HyperCon (The Hyperion deamon configuration file builder)
    // Created with HyperCon V1.03.3 (22.10.2017)
    // DEVICE CONFIGURATION
    "device" :
    "name" : "MyHyperionConfig",
    "type" : "apa102",
    "output" : "/dev/spidev0.0",
    "rate" : 1000000,
    "colorOrder" : "bgr"
    // COLOR CALIBRATION CONFIG
    "color" :
    "channelAdjustment" :
    "id" : "default",
    "leds" : "*",
    "pureRed" :
    "redChannel" : 255,
    "greenChannel" : 0,
    "blueChannel" : 0
    "pureGreen" :
    "redChannel" : 0,
    "greenChannel" : 255,
    "blueChannel" : 0
    "pureBlue" :
    "redChannel" : 0,
    "greenChannel" : 0,
    "blueChannel" : 255
    "temperature" :
    "id" : "default",
    "leds" : "*",
    "correctionValues" :
    "red" : 201,
    "green" : 226,
    "blue" : 255
    "transform" :
    "id" : "default",
    "leds" : "*",
    "hsl" :
    "saturationGain" : 0.6500,
    "luminanceGain" : 1.0000,
    "luminanceMinimum" : 0.0000
    "red" :
    "threshold" : 0.1000,
    "gamma" : 2.1000
    "green" :
    "gamma" : 2.1000
    "blue" :
    "gamma" : 2.4000
    // SMOOTHING CONFIG
    "smoothing" :
    "type" : "linear",
    "time_ms" : 200,
    "updateFrequency" : 20.0000,
    "updateDelay" : 0
    // V4L2 GRABBER CONFIG
    "grabber-v4l2" :
    "device" : "/dev/video0",
    "input" : 0,
    "standard" : "PAL",
    "width" : -1,
    "height" : -1,
    "frameDecimation" : 2,
    "sizeDecimation" : 0,
    "priority" : 900,
    "mode" : "2D",
    "cropLeft" : 0,
    "cropRight" : 0,
    "cropTop" : 0,
    "cropBottom" : 0,
    "redSignalThreshold" : 0.16,
    "greenSignalThreshold" : 0.16,
    "blueSignalThreshold" : 0.16
    // BLACKBORDER CONFIG
    "blackborderdetector" :
    "enable" : true,
    "threshold" : 0.065,
    "unknownFrameCnt" : 600,
    "borderFrameCnt" : 50,
    "maxInconsistentCnt" : 10,
    "blurRemoveCnt" : 1,
    "mode" : "default"
    // BOOTEFFECT CONFIG
    "bootsequence" :
    "color" : [0,0,0],
    "effect" : "Rainbow swirl fast",
    "duration_ms" : 3000,
    "priority" : 700
    // JSON SERVER CONFIG
    "jsonServer" :
    "port" : 19444
    // PROTO SERVER CONFIG
    "protoServer" :
    "port" : 19445
    // EFFECT PATH
    "effects" :
    "paths" :
    "/storage/hyperion/effects",
    "/usr/share/hyperion/effects"
    // NO FRAME GRABBER CONFIG
    // NO KODI CHECK CONFIG
    // NO BOBLIGHT SERVER CONFIG
    // NO JSON/PROTO FORWARD CONFIG
    // LED CONFIGURATION
    "leds" :
    "index" : 0,
    "hscan" : { "minimum" : 0.9826, "maximum" : 1.0000 },
    "vscan" : { "minimum" : 0.9200, "maximum" : 1.0000 }
    "index" : 1,
    "hscan" : { "minimum" : 0.9688, "maximum" : 0.9896 },
    "index" : 2,
    "hscan" : { "minimum" : 0.9549, "maximum" : 0.9757 },
    "index" : 3,
    "hscan" : { "minimum" : 0.9410, "maximum" : 0.9618 },
    "index" : 4,
    "hscan" : { "minimum" : 0.9271, "maximum" : 0.9479 },
    "index" : 5,
    "hscan" : { "minimum" : 0.9132, "maximum" : 0.9340 },
    "index" : 6,
    "hscan" : { "minimum" : 0.8993, "maximum" : 0.9201 },
    "index" : 7,
    "hscan" : { "minimum" : 0.8854, "maximum" : 0.9062 },
    "index" : 8,
    "hscan" : { "minimum" : 0.8715, "maximum" : 0.8924 },
    "index" : 9,
    "hscan" : { "minimum" : 0.8576, "maximum" : 0.8785 },
    "index" : 10,
    "hscan" : { "minimum" : 0.8438, "maximum" : 0.8646 },
    "index" : 11,
    "hscan" : { "minimum" : 0.8299, "maximum" : 0.8507 },
    "index" : 12,
    "hscan" : { "minimum" : 0.8160, "maximum" : 0.8368 },
    "index" : 13,
    "hscan" : { "minimum" : 0.8021, "maximum" : 0.8229 },
    "index" : 14,
    "hscan" : { "minimum" : 0.7882, "maximum" : 0.8090 },
    "index" : 15,
    "hscan" : { "minimum" : 0.7743, "maximum" : 0.7951 },
    "index" : 16,
    "hscan" : { "minimum" : 0.7604, "maximum" : 0.7812 },
    "index" : 17,
    "hscan" : { "minimum" : 0.7465, "maximum" : 0.7674 },
    "index" : 18,
    "hscan" : { "minimum" : 0.7326, "maximum" : 0.7535 },
    "index" : 19,
    "hscan" : { "minimum" : 0.7188, "maximum" : 0.7396 },
    "index" : 20,
    "hscan" : { "minimum" : 0.7049, "maximum" : 0.7257 },
    "index" : 21,
    "hscan" : { "minimum" : 0.6910, "maximum" : 0.7118 },
    "index" : 22,
    "hscan" : { "minimum" : 0.6771, "maximum" : 0.6979 },
    "index" : 23,
    "hscan" : { "minimum" : 0.6632, "maximum" : 0.6840 },
    "index" : 24,
    "hscan" : { "minimum" : 0.6493, "maximum" : 0.6701 },
    "index" : 25,
    "hscan" : { "minimum" : 0.6354, "maximum" : 0.6562 },
    "index" : 26,
    "hscan" : { "minimum" : 0.6215, "maximum" : 0.6424 },
    "index" : 27,
    "hscan" : { "minimum" : 0.6076, "maximum" : 0.6285 },
    "index" : 28,
    "hscan" : { "minimum" : 0.5938, "maximum" : 0.6146 },
    "index" : 29,
    "hscan" : { "minimum" : 0.5799, "maximum" : 0.6007 },
    "index" : 30,
    "hscan" : { "minimum" : 0.5660, "maximum" : 0.5868 },
    "index" : 31,
    "hscan" : { "minimum" : 0.5521, "maximum" : 0.5729 },
    "index" : 32,
    "hscan" : { "minimum" : 0.5382, "maximum" : 0.5590 },
    "index" : 33,
    "hscan" : { "minimum" : 0.5243, "maximum" : 0.5451 },
    "index" : 34,
    "hscan" : { "minimum" : 0.5104, "maximum" : 0.5312 },
    "index" : 35,
    "hscan" : { "minimum" : 0.4965, "maximum" : 0.5174 },
    "index" : 36,
    "hscan" : { "minimum" : 0.4826, "maximum" : 0.5035 },
    "index" : 37,
    "hscan" : { "minimum" : 0.4687, "maximum" : 0.4896 },
    "index" : 38,
    "hscan" : { "minimum" : 0.4549, "maximum" : 0.4757 },
    "index" : 39,
    "hscan" : { "minimum" : 0.4410, "maximum" : 0.4618 },
    "index" : 40,
    "hscan" : { "minimum" : 0.4271, "maximum" : 0.4479 },
    "index" : 41,
    "hscan" : { "minimum" : 0.4132, "maximum" : 0.4340 },
    "index" : 42,
    "hscan" : { "minimum" : 0.3993, "maximum" : 0.4201 },
    "index" : 43,
    "hscan" : { "minimum" : 0.3854, "maximum" : 0.4062 },
    "index" : 44,
    "hscan" : { "minimum" : 0.3715, "maximum" : 0.3924 },
    "index" : 45,
    "hscan" : { "minimum" : 0.3576, "maximum" : 0.3785 },
    "index" : 46,
    "hscan" : { "minimum" : 0.3437, "maximum" : 0.3646 },
    "index" : 47,
    "hscan" : { "minimum" : 0.3299, "maximum" : 0.3507 },
    "index" : 48,
    "hscan" : { "minimum" : 0.3160, "maximum" : 0.3368 },
    "index" : 49,
    "hscan" : { "minimum" : 0.3021, "maximum" : 0.3229 },
    "index" : 50,
    "hscan" : { "minimum" : 0.2882, "maximum" : 0.3090 },
    "index" : 51,
    "hscan" : { "minimum" : 0.2743, "maximum" : 0.2951 },
    "index" : 52,
    "hscan" : { "minimum" : 0.2604, "maximum" : 0.2813 },
    "index" : 53,
    "hscan" : { "minimum" : 0.2465, "maximum" : 0.2674 },
    "index" : 54,
    "hscan" : { "minimum" : 0.2326, "maximum" : 0.2535 },
    "index" : 55,
    "hscan" : { "minimum" : 0.2188, "maximum" : 0.2396 },
    "index" : 56,
    "hscan" : { "minimum" : 0.2049, "maximum" : 0.2257 },
    "index" : 57,
    "hscan" : { "minimum" : 0.1910, "maximum" : 0.2118 },
    "index" : 58,
    "hscan" : { "minimum" : 0.1771, "maximum" : 0.1979 },
    "index" : 59,
    "hscan" : { "minimum" : 0.1632, "maximum" : 0.1840 },
    "index" : 60,
    "hscan" : { "minimum" : 0.1493, "maximum" : 0.1701 },
    "index" : 61,
    "hscan" : { "minimum" : 0.1354, "maximum" : 0.1563 },
    "index" : 62,
    "hscan" : { "minimum" : 0.1215, "maximum" : 0.1424 },
    "index" : 63,
    "hscan" : { "minimum" : 0.1076, "maximum" : 0.1285 },
    "index" : 64,
    "hscan" : { "minimum" : 0.0937, "maximum" : 0.1146 },
    "index" : 65,
    "hscan" : { "minimum" : 0.0799, "maximum" : 0.1007 },
    "index" : 66,
    "hscan" : { "minimum" : 0.0660, "maximum" : 0.0868 },
    "index" : 67,
    "hscan" : { "minimum" : 0.0521, "maximum" : 0.0729 },
    "index" : 68,
    "hscan" : { "minimum" : 0.0382, "maximum" : 0.0590 },
    "index" : 69,
    "hscan" : { "minimum" : 0.0243, "maximum" : 0.0451 },
    "index" : 70,
    "hscan" : { "minimum" : 0.0104, "maximum" : 0.0313 },
    "index" : 71,
    "hscan" : { "minimum" : 0.0000, "maximum" : 0.0174 },
    "index" : 72,
    "hscan" : { "minimum" : 0.0000, "maximum" : 0.0500 },
    "vscan" : { "minimum" : 0.9653, "maximum" : 1.0000 }
    "index" : 73,
    "vscan" : { "minimum" : 0.9375, "maximum" : 0.9792 }
    "index" : 74,
    "vscan" : { "minimum" : 0.9097, "maximum" : 0.9514 }
    "index" : 75,
    "vscan" : { "minimum" : 0.8819, "maximum" : 0.9236 }
    "index" : 76,
    "vscan" : { "minimum" : 0.8542, "maximum" : 0.8958 }
    "index" : 77,
    "vscan" : { "minimum" : 0.8264, "maximum" : 0.8681 }
    "index" : 78,
    "vscan" : { "minimum" : 0.7986, "maximum" : 0.8403 }
    "index" : 79,
    "vscan" : { "minimum" : 0.7708, "maximum" : 0.8125 }
    "index" : 80,
    "vscan" : { "minimum" : 0.7431, "maximum" : 0.7847 }
    "index" : 81,
    "vscan" : { "minimum" : 0.7153, "maximum" : 0.7569 }
    "index" : 82,
    "vscan" : { "minimum" : 0.6875, "maximum" : 0.7292 }
    "index" : 83,
    "vscan" : { "minimum" : 0.6597, "maximum" : 0.7014 }
    "index" : 84,
    "vscan" : { "minimum" : 0.6319, "maximum" : 0.6736 }
    "index" : 85,
    "vscan" : { "minimum" : 0.6042, "maximum" : 0.6458 }
    "index" : 86,
    "vscan" : { "minimum" : 0.5764, "maximum" : 0.6181 }
    "index" : 87,
    "vscan" : { "minimum" : 0.5486, "maximum" : 0.5903 }
    "index" : 88,
    "vscan" : { "minimum" : 0.5208, "maximum" : 0.5625 }
    "index" : 89,
    "vscan" : { "minimum" : 0.4931, "maximum" : 0.5347 }
    "index" : 90,
    "vscan" : { "minimum" : 0.4653, "maximum" : 0.5069 }
    "index" : 91,
    "vscan" : { "minimum" : 0.4375, "maximum" : 0.4792 }
    "index" : 92,
    "vscan" : { "minimum" : 0.4097, "maximum" : 0.4514 }
    "index" : 93,
    "vscan" : { "minimum" : 0.3819, "maximum" : 0.4236 }
    "index" : 94,
    "vscan" : { "minimum" : 0.3542, "maximum" : 0.3958 }
    "index" : 95,
    "vscan" : { "minimum" : 0.3264, "maximum" : 0.3681 }
    "index" : 96,
    "vscan" : { "minimum" : 0.2986, "maximum" : 0.3403 }
    "index" : 97,
    "vscan" : { "minimum" : 0.2708, "maximum" : 0.3125 }
    "index" : 98,
    "vscan" : { "minimum" : 0.2431, "maximum" : 0.2847 }
    "index" : 99,
    "vscan" : { "minimum" : 0.2153, "maximum" : 0.2569 }
    "index" : 100,
    "vscan" : { "minimum" : 0.1875, "maximum" : 0.2292 }
    "index" : 101,
    "vscan" : { "minimum" : 0.1597, "maximum" : 0.2014 }
    "index" : 102,
    "vscan" : { "minimum" : 0.1319, "maximum" : 0.1736 }
    "index" : 103,
    "vscan" : { "minimum" : 0.1042, "maximum" : 0.1458 }
    "index" : 104,
    "vscan" : { "minimum" : 0.0764, "maximum" : 0.1181 }
    "index" : 105,
    "vscan" : { "minimum" : 0.0486, "maximum" : 0.0903 }
    "index" : 106,
    "vscan" : { "minimum" : 0.0208, "maximum" : 0.0625 }
    "index" : 107,
    "vscan" : { "minimum" : 0.0000, "maximum" : 0.0347 }
    "index" : 108,
    "vscan" : { "minimum" : 0.0000, "maximum" : 0.0800 }
    "index" : 109,
    "index" : 110,
    "index" : 111,
    "index" : 112,
    "index" : 113,
    "index" : 114,
    "index" : 115,
    "index" : 116,
    "index" : 117,
    "index" : 118,
    "index" : 119,
    "index" : 120,
    "index" : 121,
    "index" : 122,
    "index" : 123,
    "index" : 124,
    "index" : 125,
    "index" : 126,
    "index" : 127,
    "index" : 128,
    "index" : 129,
    "index" : 130,
    "index" : 131,
    "index" : 132,
    "index" : 133,
    "index" : 134,
    "index" : 135,
    "index" : 136,
    "index" : 137,
    "index" : 138,
    "index" : 139,
    "index" : 140,
    "index" : 141,
    "index" : 142,
    "index" : 143,
    "index" : 144,
    "index" : 145,
    "index" : 146,
    "index" : 147,
    "index" : 148,
    "index" : 149,
    "index" : 150,
    "index" : 151,
    "index" : 152,
    "index" : 153,
    "index" : 154,
    "index" : 155,
    "index" : 156,
    "index" : 157,
    "index" : 158,
    "index" : 159,
    "index" : 160,
    "index" : 161,
    "index" : 162,
    "index" : 163,
    "index" : 164,
    "index" : 165,
    "index" : 166,
    "index" : 167,
    "index" : 168,
    "index" : 169,
    "index" : 170,
    "index" : 171,
    "index" : 172,
    "index" : 173,
    "index" : 174,
    "index" : 175,
    "index" : 176,
    "index" : 177,
    "index" : 178,
    "index" : 179,
    "index" : 180,
    "hscan" : { "minimum" : 0.9500, "maximum" : 1.0000 },
    "index" : 181,
    "index" : 182,
    "index" : 183,
    "index" : 184,
    "index" : 185,
    "index" : 186,
    "index" : 187,
    "index" : 188,
    "index" : 189,
    "index" : 190,
    "index" : 191,
    "index" : 192,
    "index" : 193,
    "index" : 194,
    "index" : 195,
    "index" : 196,
    "index" : 197,
    "index" : 198,
    "index" : 199,
    "index" : 200,
    "index" : 201,
    "index" : 202,
    "index" : 203,
    "index" : 204,
    "index" : 205,
    "index" : 206,
    "index" : 207,
    "index" : 208,
    "index" : 209,
    "index" : 210,
    "index" : 211,
    "index" : 212,
    "index" : 213,
    "index" : 214,
    "index" : 215,
    "endOfJson" : "endOfJson"
    Video:
    Externer Inhalt youtu.be
    Inhalte von externen Seiten werden ohne deine Zustimmung nicht automatisch geladen und angezeigt.
    Durch die Aktivierung der externen Inhalte erklärst du dich damit einverstanden, dass personenbezogene Daten an Drittplattformen übermittelt werden. Mehr Informationen dazu haben wir in unserer Datenschutzerklärung zur Verfügung gestellt.
    Einmal editiert, zuletzt von Snakzoo (6. Mai 2020 um 14:29)
  • Zur hilfreichsten Antwort springen
  • Es ist schon sehr verwunderlich was Technik alles anstellen kann.
    Ich habe das Licht jetzt einfach mal angelassen und weiter gespielt und von jetzt auf gleich ist das Problem gelöst.
    Habe dafür keine Erklärung, aber erfreulich dass es wieder funktioniert.
    • Hilfreichste Antwort
    Problem gelöst:
    Da die Kabel am Pegelwandler nur draufgesteckt sind, hat sich wohl eins gelöst, als ich letztens ausversehen dran gekommen bin. Alle Stecker richtig reingesteckt, Problem gelöst. Also fällt es in die Kategorie Wackelkontakt der Datenkabel.
