Hier die gewünschte Ausgabe:
pi@Pi:~ $ systemd-analyze time
Startup finished in 1.813s (kernel) + 7.489s (userspace) = 9.302s
graphical.target reached after 7.367s in userspace
pi@Pi:~ $ systemd-analyze blame | head -n 10
2.359s dev-mmcblk0p2.device
1.713s udisks2.service
1.606s raspi-config.service
842ms systemd-fsck@dev-disk-by\x2dpartuuid-38df017e\x2d01.service
837ms dphys-swapfile.service
751ms avahi-daemon.service
732ms wpa_supplicant.service
714ms ofono.service
713ms keyboard-setup.service
661ms dhcpcd.service
pi@Pi:~ $ dmesg | tail -n 15
[ 8.312208] Adding 102396k swap on /var/swap. Priority:-2 extents:1 across:102396k SSFS
[ 8.319297] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[ 8.319317] brcmfmac: power management disabled
[ 8.795456] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 8.795474] 8021q: adding VLAN 0 to HW filter on device eth0
[ 8.796782] lan78xx 1-1.1.1:1.0 eth0: kevent 4 may have been dropped
[ 8.825350] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[ 10.734492] ICMPv6: process `dhcpcd' is using deprecated sysctl (syscall) net.ipv6.neigh.eth0.retrans_time - use net.ipv6.neigh.eth0.retrans_time_ms instead
[ 14.475770] fuse init (API version 7.27)
[ 20.926434] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 20.926444] Bluetooth: BNEP filters: protocol multicast
[ 20.926462] Bluetooth: BNEP socket layer initialized
[ 34.407250] Voltage normalised (0x00000000)
[ 82.256511] Under-voltage detected! (0x00050005)
[ 86.406320] Voltage normalised (0x00000000)
Alles anzeigen
