Hi Leute,
ich hab momentan Probleme mit dem Pi ins internet zu kommen, da er Ip Adressen nicht mehr auflösen kann. Ping liefert nur temporäre Probleme bei der Namensauflösung. Eigentlich hatte ich nichts verändert, außer den Pi in meiner Fritzbox aus dem DNS Rebind ausgetragen. Das hatte ich mal für Pihole dort eingetragen, was ich nicht mehr nutze.
/etc/dhcpcd.conf
ZitatAlles anzeigen# A sample configuration for dhcpcd.
# See dhcpcd.conf(5) for details.
# Allow users of this group to interact with dhcpcd via the control socket.
#controlgroup wheel
# Inform the DHCP server of our hostname for DDNS.
hostname
# Use the hardware address of the interface for the Client ID.
clientid
# or
# Use the same DUID + IAID as set in DHCPv6 for DHCPv4 ClientID as per RFC4361.
# Some non-RFC compliant DHCP servers do not reply with this set.
# In this case, comment out duid and enable clientid above.
#duid
# Persist interface configuration when dhcpcd exits.
persistent
# Rapid commit support.
# Safe to enable by default because it requires the equivalent option set
# on the server to actually work.
option rapid_commit
# A list of options to request from the DHCP server.
option domain_name_servers, domain_name, domain_search, host_name
option classless_static_routes
# Respect the network MTU. This is applied to DHCP routes.
option interface_mtu
# Most distributions have NTP support.
#option ntp_servers
# A ServerID is required by RFC2131.
require dhcp_server_identifier
# Generate SLAAC address using the Hardware Address of the interface
#slaac hwaddr
# OR generate Stable Private IPv6 Addresses based from the DUID
slaac private
# Example static IP configuration:
#interface eth0
#static ip_address=192.168.0.10/24
#static ip6_address=fd51:42f8:caae:d92e::ff/64
#static routers=192.168.0.1
#static domain_name_servers=192.168.0.1 8.8.8.8 fd51:42f8:caae:d92e::1
# It is possible to fall back to a static IP if DHCP fails:
# define static profile
#profile static_eth0
#static ip_address=192.168.1.23/24
#static routers=192.168.1.1
#static domain_name_servers=192.168.1.1
# fallback to static profile on eth0
#interface eth0
#fallback static_eth0
# Local loopback
auto lo
iface lo inet loopback
# NextCloudPi autogenerated
# don't modify! better use ncp-config
interface eth0
static ip_address=192.168.178.66/24
static routers=192.168.178.1
#static domain_name_servers=127.0.0.1 //Heinweis: wenn ich hier 1.1.1.1 eintrage funktioniert alles
# Local loopback
auto lo
/etc/resolvconf.conf
ZitatAlles anzeigen# Configuration for resolvconf(8)
# See resolvconf.conf(5) for details
resolv_conf=/etc/resolv.conf
# If you run a local name server, you should uncomment the below line and
# configure your subscribers configuration files below.
#name_servers=127.0.0.1
name_servers=192.168.178.0 //Hinweis: ändert leider auch nichts
# Mirror the Debian package defaults for the below resolvers
# so that resolvconf integrates seemlessly.
dnsmasq_resolv=/var/run/dnsmasq/resolv.conf
pdnsd_conf=/etc/pdnsd.conf
unbound_conf=/var/cache/unbound/resolvconf_resolvers.conf
/etc/resolv.conf
Zitat# Dynamic resolv.conf(5) file for glibc resolver(3) generated by resolvconf(8)
# DO NOT EDIT THIS FILE BY HAND -- YOUR CHANGES WILL BE OVERWRITTEN
Für mich sieht es so aus, als wenn der Pi die Ip Adressen nicht mehr auflösen kann, da er keinen DNS Server erkennt bzw von Fritzbox mitgeteilt bekommt.
