beim installieren von Motioneye kommt beim Pi 3 A+ folgender Fehler:
pi@raspberrypi:~ $ sudo pip install motioneye
Looking in indexes: https://pypi.org/simple, https://www.piwheels.org/simple
Collecting motioneye
Using cached https://files.pythonhosted.org/packages/c5/ff…e-0.42.1.tar.gz
Collecting jinja2 (from motioneye)
Using cached https://files.pythonhosted.org/packages/30/9e…y3-none-any.whl
Collecting pillow (from motioneye)
Downloading https://files.pythonhosted.org/packages/b3/d0…ow-6.2.2.tar.gz (37.8MB)
99% |████████████████████████████████| 37.8MB 8.9MB/s eta 0:00:01Exception:
File "/usr/lib/python2.7/dist-packages/pip/_internal/cli/base_command.py", line 143, in main
status = self.run(options, args)
File "/usr/lib/python2.7/dist-packages/pip/_internal/commands/install.py", line 338, in run
resolver.resolve(requirement_set)
File "/usr/lib/python2.7/dist-packages/pip/_internal/resolve.py", line 102, in resolve
self._resolve_one(requirement_set, req)
File "/usr/lib/python2.7/dist-packages/pip/_internal/resolve.py", line 256, in _resolve_one
abstract_dist = self._get_abstract_dist_for(req_to_install)
File "/usr/lib/python2.7/dist-packages/pip/_internal/resolve.py", line 209, in _get_abstract_dist_for
self.require_hashes
File "/usr/lib/python2.7/dist-packages/pip/_internal/operations/prepare.py", line 283, in prepare_linked_requirement
progress_bar=self.progress_bar
File "/usr/lib/python2.7/dist-packages/pip/_internal/download.py", line 836, in unpack_url
progress_bar=progress_bar
File "/usr/lib/python2.7/dist-packages/pip/_internal/download.py", line 673, in unpack_http_url
progress_bar)
File "/usr/lib/python2.7/dist-packages/pip/_internal/download.py", line 897, in _download_http_url
_download_url(resp, link, content_file, hashes, progress_bar)
File "/usr/lib/python2.7/dist-packages/pip/_internal/download.py", line 617, in _download_url
hashes.check_against_chunks(downloaded_chunks)
File "/usr/lib/python2.7/dist-packages/pip/_internal/utils/hashes.py", line 48, in check_against_chunks
for chunk in chunks:
File "/usr/lib/python2.7/dist-packages/pip/_internal/download.py", line 585, in written_chunks
File "/usr/lib/python2.7/dist-packages/pip/_internal/utils/ui.py", line 159, in iter
for x in it:
File "/usr/lib/python2.7/dist-packages/pip/_internal/download.py", line 574, in resp_read
decode_content=False):
File "/usr/share/python-wheels/http://urllib3-1.24.1-py2.py3-none-any.whl/urllib3/response.py", line 494, in stream
data = self.read(amt=amt, decode_content=decode_content)
File "/usr/share/python-wheels/http://urllib3-1.24.1-py2.py3-none-any.whl/urllib3/response.py", line 442, in read
data = self._fp.read(amt)
File "/usr/share/python-wheels/http://CacheControl-0.11.7-py2.py3-none-any.whl/cachecontrol/filewrapper.py", line 63, in read
self._close()
File "/usr/share/python-wheels/http://CacheControl-0.11.7-py2.py3-none-any.whl/cachecontrol/filewrapper.py", line 50, in _close
self.__callback(self.__buf.getvalue())
File "/usr/share/python-wheels/http://CacheControl-0.11.7-py2.py3-none-any.whl/cachecontrol/controller.py", line 275, in cache_response
self.serializer.dumps(request, response, body=body),
File "/usr/share/python-wheels/http://CacheControl-0.11.7-py2.py3-none-any.whl/cachecontrol/serialize.py", line 87, in dumps
).encode("utf8"),
MemoryError
Weiß da jemand weiter?
