Bei Hyperion Installation immer der gleiche Fehler
  • Wenn ich Hyperion ohne Externen Grabber starte kommen die Regenbogenfarben.
    Wenn ich einen Haken setze bei Externen Grabber und den Pi reboote kommt
    Failed to start Hyperion Systemd service.
    See systemctl status hyperion.service for details
    Hole Log schreibt:
    ssh in: Jul 18 07:43:20 raspberrypi systemd[1]: Started Hyperion Systemd service.
    ssh in: Jul 18 07:43:20 raspberrypi hyperiond[493]: Hyperion Ambilight Deamon (493)
    ssh in: Jul 18 07:43:20 raspberrypi hyperiond[493]: Version : V1.03.5 (GitHub-66bef6b/fb413cd-1566231780
    ssh in: Jul 18 07:43:20 raspberrypi hyperiond[493]: Build Time: Aug 25 2019 10:39:29
    ssh in: Jul 18 07:43:20 raspberrypi hyperiond[493]: INFO: Selected configuration file: /etc/hyperion/hyperion.config.json
    ssh in: Jul 18 07:43:20 raspberrypi hyperiond[493]: HYPERION INFO: ColorTransform 'default' => [0; 195]
    ssh in: Jul 18 07:43:20 raspberrypi hyperiond[493]: HYPERION INFO: ColorCorrection 'default' => [0; 195]
    ssh in: Jul 18 07:43:20 raspberrypi hyperiond[493]: HYPERION INFO: ColorAdjustment 'default' => [0; 195]
    ssh in: Jul 18 07:43:20 raspberrypi hyperiond[493]: LEDDEVICE INFO: configuration:
    ssh in: Jul 18 07:43:20 raspberrypi hyperiond[493]: {
    ssh in: Jul 18 07:43:20 raspberrypi hyperiond[493]: "colorOrder" : "bgr",
    ssh in: Jul 18 07:43:20 raspberrypi hyperiond[493]: "name" : "MyHyperionConfig",
    ssh in: Jul 18 07:43:20 raspberrypi hyperiond[493]: "output" : "/dev/spidev0.0",
    ssh in: Jul 18 07:43:20 raspberrypi hyperiond[493]: "rate" : 1000000,
    ssh in: Jul 18 07:43:20 raspberrypi hyperiond[493]: "type" : "apa102"
    ssh in: Jul 18 07:43:20 raspberrypi hyperiond[493]: }
    ssh in: Jul 18 07:43:20 raspberrypi hyperiond[493]: INFO: Creating linear smoothing
    ssh in: Jul 18 07:43:20 raspberrypi hyperiond[493]: HYPERION (CS) INFO: Created linear-smoothing(interval_ms=50;settlingTime_ms=200;updateDelay=0
    ssh in: Jul 18 07:43:20 raspberrypi hyperiond[493]: EFFECTENGINE INFO: 27 effects loaded from directory /usr/share/hyperion/effects
    ssh in: Jul 18 07:43:20 raspberrypi hyperiond[493]: EFFECTENGINE INFO: Initializing Python interpreter
    ssh in: Jul 18 07:43:20 raspberrypi hyperiond[493]: INFO: Hyperion started and initialised
    ssh in: Jul 18 07:43:20 raspberrypi hyperiond[493]: INFO: Boot sequence 'Rainbow swirl fast' EFFECTENGINE INFO: run effect Rainbow swirl fast on channel 0
    ssh in: Jul 18 07:43:20 raspberrypi hyperiond[493]: BLACKBORDER INFO: threshold set to 0 (0)
    ssh in: Jul 18 07:43:20 raspberrypi hyperiond[493]: BLACKBORDER INFO: mode:default
    ssh in: Jul 18 07:43:20 raspberrypi hyperiond[493]: started
    ssh in: Jul 18 07:43:20 raspberrypi hyperiond[493]: INFO: Json server created and started on port 19444
    ssh in: Jul 18 07:43:20 raspberrypi hyperiond[493]: INFO: Proto server created and started on port 19445
    ssh in: Jul 18 07:43:20 raspberrypi hyperiond[493]: terminate called after throwing an instance of 'std::runtime_error'
    ssh in: Jul 18 07:43:20 raspberrypi hyperiond[493]: what(): VIDIOC_S_STD ERROR 25, Inappropriate ioctl for device
    ssh in: Jul 18 07:43:20 raspberrypi systemd[1]: hyperion.service: Main process exited, code=killed, status=6/ABRT
    ssh in: Jul 18 07:43:20 raspberrypi systemd[1]: hyperion.service: Failed with result 'signal'.
    ssh in: Jul 18 07:43:20 raspberrypi systemd[1]: hyperion.service: Service RestartSec=100ms expired, scheduling restart.
    ssh in: Jul 18 07:43:20 raspberrypi systemd[1]: hyperion.service: Scheduled restart job, restart counter is at 5.
    ssh in: Jul 18 07:43:20 raspberrypi systemd[1]: Stopped Hyperion Systemd service.
    ssh in: Jul 18 07:43:20 raspberrypi systemd[1]: hyperion.service: Start request repeated too quickly.
    ssh in: Jul 18 07:43:20 raspberrypi systemd[1]: Failed to start Hyperion Systemd service.
    Meine Programmierkenntnisse und mein Englisch sind nicht die Besten.
    Ich versuch seit Februar mit Google und Suchfunktionen das Problem alleine zu lösen, aber ich komme nicht weiter.
    Kann jemand der viel Geduld hat helfen?
    Einmal editiert, zuletzt von blackvento (18. Juli 2020 um 08:27)
  • Bei Hyperion Installation immer der gleiche Fehler? Schau mal ob du hier fündig wirst!
  • Danke erst einmal für deine Antwort.
    Google translate ist schon fast meine Startseite.
    Grabber habe ich keinen angeschlossen weil in jeder Anleitung steht erst anschließen wenn alles mit Haken Externer Grabber funktioniert.
    no-change wo setze ich das ? In HyperCon nicht gefunden.
    Schönes Wochenende.
  • Du enablest aber den grabber und dann kommt die Fehlermeldung. Deswegen -> Falscher grabber
    Also, welchen grabber hast Du?
    Edit: ach ja, grabber enable und dann nicht anschliessen ist doof kontraproduktiv. Kann zu Fehlermeldungen führen?
    Optimismus ist nur ein Mangel an Informationen?
  • nicht anschliessen ist doof kontraproduktiv höre ich zum ersten mal.
    Also werde ich mir jetzt einen Grabber UTV007 besorgen und dann noch mal probieren.
    Danke für deine Geduld. Ich melde mich noch mal wenn der Grabber da ist. Positiv wie auch negativ.
    Rückmeldung kommt.
    Wie setze ich
    "standard" : "no-change",
    die hyperion.config.json wird doch von Hypercon erzeugt. Bei Videoformat kann ich nur zwischen PAL und NTSC schalten. no-change steht da nicht.
    Danke
    Einmal editiert, zuletzt von blackvento (19. Juli 2020 um 14:31)
  • Danke danke danke an Leroy Cemoi,
    Das war der entscheidende Tipp und Standart no-change.
    Nach 7 Monaten langer Arbeit funktioniert mein Ambilight endlich. Der Grabber muss kein UTV007 sein. Ich habe einen 524d:0021Chip von
    BerryBase - zur Startseite wechseln mit HDMI Eingang. Dadurch spart man sich den HDMI Konverter. Eine Fehlerquelle weniger.
    Einmal editiert, zuletzt von blackvento (28. Juli 2020 um 08:42)
