keine Verbindung über Openvpn möglich (Raspberry Pi 4B <-> Netcup Server
  • Hello, Hallo (hab es mal auf englisch übersetzt für die internationalen)
    I have a tricky but actually simple problem.
    I would like to run traffic from and to a Raspberry Pi through my Netcup server. So network traffic as well as web traffic. My Netcup server has an identifiable address and can be pinged everywhere. I want to have this on my Raspi too. For this I want to configure OpenVPN so that the connection is up (Pi <-> server). So my Pi is the cient and my server (Netcup) is my server (or host).
    So here is some code for you guys:
    For meaning: tobipiserver = Netcupserver and RaspiMum = Raspbery Pi.
    server.config:
    # OpenVPN Port, Protocol, and the Tun
    port 16661
    proto udp
    dev tun
    # OpenVPN Server Certificate - CA, server key and certificate
    ca /etc/openvpn/server/ca.crt
    cert /etc/openvpn/server/tobipiserver.crt
    key /etc/openvpn/server/tobipiserver.key
    #DH and CRL key
    dh /etc/openvpn/server/dh.pem
    #crl-verify /etc/openvpn/server/crl.pem
    # Network Configuration - Internal network
    # Redirect all Connection through OpenVPN Server
    server 172.16.31.0 255.255.255.0
    #push "redirect-gateway def1"
    route 192.168.178.geschwärtzt 255.255.255.0
    route 192.168.178.39 255.255.255.0
    push "route 192.168.178.39 (thats the ip adress of my pi)) 255.255.255.0"
    # Using the DNS from https://dns.watch
    # push "dhcp-option DNS 84.200.69.80"
    push "push 192.168.178.geschwärzt 255.255.255.0"
    #Enable multiple clients to connect with the same certificate key !! Hinweis nu$
    #duplicate-cn
    # TLS Security
    cipher AES-256-CBC
    tls-version-min 1.2
    tls-cipher (blacked out)
    auth SHA512
    auth-nocache
    # Other Configuration
    keepalive 20 60
    persist-key
    persist-tun
    compress lz4
    #daemon
    user nobody
    group nogroup
    # OpenVPN Log
    log-append /var/log/openvpn.log
    verb 3
    hier meine client.conf:
    client
    dev tun
    proto udp
    remote geschwärzte IP Netcup Server 1194
    resolv-retry infinite
    nobind
    user nobody
    group nogroup
    persist-key
    persist-tun
    ca /etc/openvpn/client/ca.crt
    cert /etc/openvpn/client/RaspiMum.crt
    key /etc/openvpn/client/RaspiMum.key
    remote-cert-tls server
    tls-auth ta.key 1
    cipher AES-256-C0
    Data of my devices:
    Linux RaspiMum 5.4.79-v7l+
    Server:
    OS: Debian GNU/Linux 10 (buster) x86_64
    Host: KVM Server VPS 200 G8
    Kernel: 4.19.0-11-amd64
    CPU: QEMU Virtual version 2.5+ (1) @ 2.294GHz
    Memory: 209MiB / 1995MiB
    So but now does not work, the connection can not be established, I can only reach the Netcup server (logical, pay for it 3€ / month with access data). So what to do?
    Und nun nochmal ein paar Infos: Ich habe das ganze (wirklich das gesamtheitliche) World Wide Web durchsucht, Foren (Igors Lab, Computerwelt, Linux org Forum) angeguckt und nochmal das ganze World Wide Web durchsucht und das dann nochmal. Ich habe KEINE einzige Lösung gefunden, wie man mit Openvpn eine Verbindung zum Heimnetz schafft... Ich bin mittlerweile so frustriert. Ich will seit geschlagenen 4 Monaten meinen Netcup-Server in mein Home-Netzwerk einbinden und über Openvpn ein virtuelles Netzwerk schaffen.
    Aber Raspberry Pi ist anscheinend so beschränkt und so speziell, dass man im gesamten und ich meine im gesamten Internet keine Lösung für dieses Problem findet.
    Das Raspberry Pi Forum ist nun die letzte Möglichkeit, die ich habe, bevor ich meinen Server abbestelle und die ganze Sache ganz abblase.
    Was ich noch probiert habe:
    Ports sind alle offen bei folgenden Geräten (TCP+UDP):
    Router offen
    Raspberry Pi offen (UFW allow)
    Netcup Server offen (UFW allow)
    VPNVerbindung an der Fritz.Box ist auch offen.
    Vielleicht liegts ganz einfach auch an meinem DS-Lite Vertrag...;(
    Naja man kann nichts machen, außer um Hilfe bitten. Unter meinen Kollegen bin ich jetzt schon der Openvpn und Raspberry Pi Experte und kriege so ziemlich alles hin aber der Fall hier is tricky.
    Ich hab das ganze System auch schon mehrere Male neu aufgesetzt also komplett die SD Karte gelöscht vom Pi und von vorne begonnen (6x soweit...). Bei jedem mal habe ich etwas anderes probiert.
    Naja ich hoffe irgendjemand hier, der noch aktiv ist, kann mir helfen...
  • Ich habe KEINE einzige Lösung gefunden, wie man mit Openvpn eine Verbindung zum Heimnetz schafft...
    Wie muss man das verstehen? Willst Du mit OpenVPN, alle Geräte im LAN/Heimnetz des PI (als VPN-Client und gateway zum Heimnetz) erreichen können? Kannst Du den PI via OpenVPN erreichen?
    Wie sind auf dem Server und auf dem PI, die Ausgaben von:
    ip a
    route -n
    sysctl net.ipv4.ip_forward
    sudo iptables -nvx -L POSTROUTING -t nat
    ? BTW: UFW kannst Du auf dem Server und auf dem PI deinstallieren.
    Wäre es möglich, dass Du auf deinem Server WireGuard installierst?
    erstmal vielen lieben Dank für die Antwort :)
    Erstmal soll nur eine Verbindung von meinem Server zu einem Pi hergestellt werde, nicht alle Geräte im Heim-Netz. Den Pi kann ich momentan nur via SSH erreichen oder direkt (mit Bildschirm-Ausgabe). Den Server erreiche ich über den SSH port 10022.
    Also die Ausgaben am Server sind:
    ip a
    1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group defaul t qlen 1000
    link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
    inet 127.0.0.1/8 scope host lo
    valid_lft forever preferred_lft forever
    inet6 ::1/128 scope host
    2: eth0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc pfifo_fast state UP gr oup default qlen 1000
    link/ether 36:6c:be:00:a3:5f brd ff:ff:ff:ff:ff:ff
    inet 152.89.104.68/22 brd 152.89.107.255 scope global eth0
    inet6 2a03:4000:39:75c:346c:beff:fe00:a35f/64 scope global
    inet6 fe80::346c:beff:fe00:a35f/64 scope link
    3: tun0: <POINTOPOINT,MULTICAST,NOARP,UP,LOWER_UP> mtu 1500 qdisc pfifo_fast sta te UNKNOWN group default qlen 100
    link/none
    inet 172.16.31.1 peer 172.16.31.2/32 scope global tun0
    inet6 fe80::c8e9:3d92:f0eb:8513/64 scope link stable-privacy
    route -n
    Kernel IP routing table
    Destination Gateway Genmask Flags Metric Ref Use Iface
    0.0.0.0 152.89.104.1 0.0.0.0 UG 0 0 0 eth0
    152.89.104.0 0.0.0.0 255.255.252.0 U 0 0 0 eth0
    172.16.31.0 172.16.31.2 255.255.255.0 UG 0 0 0 tun0
    172.16.31.2 0.0.0.0 255.255.255.255 UH 0 0 0 tun0
    sysctl net-ipv4.ip_forward
    sysctl: cannot stat /proc/sys/net-ipv4/ip_forward: No such file or directory
    hier brauche ich ja die datei dafür, ist aber standardmäßig gar nicht installiert worden. Wie mache ich denn das?
    Chain POSTROUTING (policy ACCEPT 0 packets, 0 bytes)
    pkts bytes target prot opt in out source destination
    Am Raspberry Pi:
    ip a
    2: eth0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc mq state UP group defa ult qlen 1000
    link/ether dc:a6:32:5d:a9:cd brd ff:ff:ff:ff:ff:ff
    inet 192.168.178.37/24 brd 192.168.178.255 scope global dynamic noprefixrout e eth0
    valid_lft 863855sec preferred_lft 755855sec
    inet6 2a02:8070:c38a:2d00:c483:35d7:cf61:e2e7/64 scope global dynamic mngtmp addr noprefixroute
    valid_lft 7152sec preferred_lft 3552sec
    inet6 fe80::29f9:a45b:f99b:50d5/64 scope link
    3: wlan0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc pfifo_fast state UP g roup default qlen 1000
    link/ether dc:a6:32:5d:a9:ce brd ff:ff:ff:ff:ff:ff
    inet 192.168.178.39/24 brd 192.168.178.255 scope global dynamic noprefixrout e wlan0
    inet6 2a02:8070:c38a:2d00:e96d:e96d:2f05:c669/64 scope global dynamic mngtmp addr noprefixroute
    inet6 fe80::259b:4e43:32eb:f92/64 scope link
    route -n
    Kernel-IP-Routentabelle
    Ziel Router Genmask Flags Metric Ref Use Iface
    0.0.0.0 192.168.178.1 0.0.0.0 UG 202 0 0 eth0
    0.0.0.0 192.168.178.1 0.0.0.0 UG 303 0 0 wlan0
    192.168.178.0 0.0.0.0 255.255.255.0 U 202 0 0 eth0
    192.168.178.0 0.0.0.0 255.255.255.0 U 303 0 0 wlan0
    net.ipv4.ip_forward = 1 also das scheint zu funktionieren und an zu sein.
    Ich hoffe das hilft dir irgendwie weiter, bei mir läuft halt alles über meinen Router, kann das zum Problem werden oder muss ich den Router in die ganze Config hauen?
  • tobipicomputers wegen der besseren Lesbarkeit, und damit man nicht über Kilometer scollen muß, solltest Du
    • Terminal-Ausgaben oder
    • Skripte wie z.B bash oder python
    in Codeblöcken (das ist das </>-Symbol im schwarzen Balken) posten.
    Schönen Gruß, kle
  • . statt -
    Auf deinem PI ist kein tun-Interface ersichtlich. Hast Du OpenVPN auf deinem PI?
    Kannst Du auf deinem Server evtl. auch WireGuard installieren?
    BTW: Anonymisiere die externe/öffentliche IPv4-Adresse von deinem Server.
    Warum hast Du mit deinem PI, eine Kabel- und eine Wlan-Verbindung aktiv?
  • Dein Server sollte, wenn der Tunnel aufgebaut ist vom Pi aus per 172.16.31.1 erreichbar sein.
    Wenn das ganze Heim-Netzwerk den Server erreichen soll muss auf deinem Router eine Route zu dem 172.16.31.0/24 angelegt werden welche auf die IP des PI zeigt.
    Was nicht geht ist den Server via der Public IP anzusprechen.
    Kein Support per PN !
