Irgendwie wollte der Raspi Firefox keine Eingaben mehr, naja, jetzt weiter.
Das Script läuft bei mir auch ohne Zeilenumbruch nach der cat Zeile.
#! /bin/bash
exec > out.txt
echo
date
echo Raspberry hardware version:
cat /sys/firmware/devicetree/base/model
echo
echo
echo Raspberry Firmware version:
vcgencmd version
echo
echo Raspberry Bootloader version:
vcgencmd bootloader_version
echo
echo Raspberry Bootloader config:
sudo rpi-eeprom-update
echo
echo Reading the current EEPROM configuration rpi-eeprom-config:
sudo rpi-eeprom-config
echo
echo Reading the current EEPROM configuration vcgencmd bootloader_config:
sudo vcgencmd bootloader_config
echo
echo Linux Distribution:
cat /etc/os-release
echo
echo Kernel version:
uname -a
echo
echo "SHELL:" $SHELL
echo
echo hostname:
hostnamectl
echo
Alles anzeigen
Ausgabe:
pi@raspberrypi:~ $ cat out.txt
Fri 29 Jan 19:06:25 CET 2021
Raspberry Pi 4 Model B Rev 1.2
Nov 30 2020 22:13:08
Copyright (c) 2012 Broadcom
version ab1181cc0cb6df52bfae3b1d3fef0ce7c325166c (clean) (release) (start_x)
Sep 3 2020 13:11:43
version c305221a6d7e532693cc7ff57fddfc8649def167 (release)
timestamp 1599135103
update-time 0
capabilities 0x00000000
BCM2711 detected
Dedicated VL805 EEPROM detected
BOOTLOADER: up-to-date
CURRENT: Thu 3 Sep 12:11:43 UTC 2020 (1599135103)
LATEST: Thu 3 Sep 12:11:43 UTC 2020 (1599135103)
FW DIR: /lib/firmware/raspberrypi/bootloader/critical
VL805: up-to-date
CURRENT: 000138a1
LATEST: 000138a1
BOOT_UART=0
WAKE_ON_GPIO=1
POWER_OFF_ON_HALT=0
BOOT_UART=0
WAKE_ON_GPIO=1
POWER_OFF_ON_HALT=0
Linux Distribution:
PRETTY_NAME="Raspbian GNU/Linux 10 (buster)"
NAME="Raspbian GNU/Linux"
VERSION_ID="10"
VERSION="10 (buster)"
VERSION_CODENAME=buster
ID=raspbian
ID_LIKE=debian
Kernel version:
Linux raspberrypi 5.4.79-v7l+ #1373 SMP Mon Nov 23 13:27:40 GMT 2020 armv7l GNU/Linux
SHELL: /bin/bash
hostname:
Static hostname: raspberrypi
Icon name: computer
Machine ID: f4fc0bf1d1b74c80a68e9fbe3d2ad18a
Boot ID: 84e5fabe9eea4c1a849636dc4d32bf2c
Operating System: Raspbian GNU/Linux 10 (buster)
Kernel: Linux 5.4.79-v7l+
Architecture: arm
pi@raspberrypi:~ $
Alles anzeigen
Vielen Dank für Eure Unterstützung...bei meiner Meinung über die Raspi Umgebung bleibe ich aber.
