Nachdem ich Nextcloud auf Version 20 aktualisiert habe, erhalte ich folgende Nachricht:
Dazu heißt es in den Docs:
Output Buffering must be turned off in .htaccess or .user.ini or php.ini, or PHP will return memory-related errors:
output_buffering = 0
Meine .user.ini, welche schon so standardmäßig aussah
Code: /var/www/html/nextcloud/.user.ini
mbstring.func_overload=0
always_populate_raw_post_data=-1
default_charset='UTF-8'
output_buffering=0
Auch ein Eintrag in der .htaccess half nicht.
Apache Configuration: /var/www/html/nextcloud/.htaccess
<IfModule mod_headers.c>
<IfModule mod_setenvif.c>
<IfModule mod_fcgid.c>
SetEnvIfNoCase ^Authorization$ "(.+)" XAUTHORIZATION=$1
RequestHeader set XAuthorization %{XAUTHORIZATION}e env=XAUTHORIZATION
</IfModule>
<IfModule mod_proxy_fcgi.c>
SetEnvIfNoCase Authorization "(.+)" HTTP_AUTHORIZATION=$1
</IfModule>
</IfModule>
<IfModule mod_env.c>
# Add security and privacy related headers
# Avoid doubled headers by unsetting headers in "onsuccess" table,
# then add headers to "always" table: https://github.com/nextcloud/server/pull/19002
Header onsuccess unset Referrer-Policy
Header always set Referrer-Policy "no-referrer"
Header onsuccess unset X-Content-Type-Options
Header always set X-Content-Type-Options "nosniff"
Header onsuccess unset X-Download-Options
Header always set X-Download-Options "noopen"
Header onsuccess unset X-Frame-Options
Header always set X-Frame-Options "SAMEORIGIN"
Header onsuccess unset X-Permitted-Cross-Domain-Policies
Header always set X-Permitted-Cross-Domain-Policies "none"
Header onsuccess unset X-Robots-Tag
Header always set X-Robots-Tag "none"
Header onsuccess unset X-XSS-Protection
Header always set X-XSS-Protection "1; mode=block"
SetEnv modHeadersAvailable true
</IfModule>
# Add cache control for static resources
<FilesMatch "\.(css|js|svg|gif)$">
Header set Cache-Control "max-age=15778463"
</FilesMatch>
# Let browsers cache WOFF files for a week
<FilesMatch "\.woff2?$">
Header set Cache-Control "max-age=604800"
</FilesMatch>
</IfModule>
<IfModule mod_php7.c>
php_value mbstring.func_overload 0
php_value default_charset 'UTF-8'
php_value output_buffering 0
SetEnv htaccessWorking true
</IfModule>
</IfModule>
<IfModule mod_rewrite.c>
RewriteEngine on
RewriteCond %{HTTP_USER_AGENT} DavClnt
RewriteRule ^$ /remote.php/webdav/ [L,R=302]
RewriteRule .* - [env=HTTP_AUTHORIZATION:%{HTTP:Authorization}]
RewriteRule ^\.well-known/host-meta /public.php?service=host-meta [QSA,L]
RewriteRule ^\.well-known/host-meta\.json /public.php?service=host-meta-json [QSA,L]
RewriteRule ^\.well-known/webfinger /public.php?service=webfinger [QSA,L]
RewriteRule ^\.well-known/nodeinfo /public.php?service=nodeinfo [QSA,L]
RewriteRule ^\.well-known/carddav /remote.php/dav/ [R=301,L]
RewriteRule ^\.well-known/caldav /remote.php/dav/ [R=301,L]
RewriteRule ^remote/(.*) remote.php [QSA,L]
RewriteRule ^(?:build|tests|config|lib|3rdparty|templates)/.* - [R=404,L]
RewriteCond %{REQUEST_URI} !^/\.well-known/(acme-challenge|pki-validation)/.*
RewriteRule ^(?:\.|autotest|occ|issue|indie|db_|console).* - [R=404,L]
</IfModule>
<IfModule mod_mime.c>
AddType image/svg+xml svg svgz
AddEncoding gzip svgz
</IfModule>
<IfModule mod_dir.c>
DirectoryIndex index.php index.html
</IfModule>
AddDefaultCharset utf-8
Options -Indexes
<IfModule pagespeed_module>
ModPagespeed Off
</IfModule>
#### DO NOT CHANGE ANYTHING ABOVE THIS LINE ####
ErrorDocument 403 /nextcloud/
ErrorDocument 404 /nextcloud/
root@werkstattserver:/var/www/html/nextcloud# nano .htaccess
root@werkstattserver:/var/www/html/nextcloud# systemctl restart apache2
root@werkstattserver:/var/www/html/nextcloud# cat .htaccess
</IfModule>
</IfModule>
</IfModule>
</IfModule>
</FilesMatch>
</FilesMatch>
</IfModule>
</IfModule>
</IfModule>
RewriteEngine on
</IfModule>
</IfModule>
</IfModule>
Options -Indexes
ModPagespeed Off
</IfModule>
output_buffering=0
Display More
Die php.ini möchte ich ungern ändern, die zählt ja global wenn ich das richtig verstehe? Hier würde jedoch der Eintrag zum Erfolg führen. Kann man das getrost global einstellen? Gibt es eine Chance es so anzupassen, dass es nur für Nextcloud zählt?
Nach den Änderungen wurde apache2 jedes mal neu gestartet, auch ein kompletter Reboot wurde versucht.
