Hallo!
Ich habe ein Problem mit Displayrotation...
Habe 2 Raspi`s 4b mit 8GB. Beide sind sehr ähnlich konfigiriert. Vor allem in der boot/config.txt! Da sind sie gleich!
Das Problem ist das sich mein neuer Raspberry den ich vor 2 Tagen komplett neu aufgesetzt habe nicht drehen lässt was ich wirklich benötige..
So sieht meine config.txt aus, bei beiden:...
# For more options and information see
# http://rpf.io/configtxt
# Some settings may impact device functionality. See link above for details
# uncomment if you get no picture on HDMI for a default "safe" mode
#hdmi_safe=1
# uncomment this if your display has a black border of unused pixels visible
# and your display can output without overscan
disable_overscan=1
# uncomment the following to adjust overscan. Use positive numbers if console
# goes off screen, and negative if there is too much border
#overscan_left=16
#overscan_right=16
#overscan_top=16
#overscan_bottom=16
# uncomment to force a console size. By default it will be display's size minus
# overscan.
#framebuffer_width=1280
#framebuffer_height=720
# uncomment if hdmi display is not detected and composite is being output
hdmi_force_hotplug=1
# uncomment to force a specific HDMI mode (this will force VGA)
#hdmi_group=1
#hdmi_mode=1
# uncomment to force a HDMI mode rather than DVI. This can make audio work in
# DMT (computer monitor) modes
#hdmi_drive=2
# uncomment to increase signal to HDMI, if you have interference, blanking, or
# no display
#config_hdmi_boost=4
# uncomment for composite PAL
#sdtv_mode=2
#uncomment to overclock the arm. 700 MHz is the default.
#arm_freq=800
# Uncomment some or all of these to enable the optional hardware interfaces
#dtparam=i2c_arm=on
#dtparam=i2s=on
#dtparam=spi=on
# Uncomment this to enable infrared communication.
#dtoverlay=gpio-ir,gpio_pin=17
#dtoverlay=gpio-ir-tx,gpio_pin=18
# Additional overlays and parameters are documented /boot/overlays/README
# Enable audio (loads snd_bcm2835)
#dtparam=audio=on
[all]
dtoverlay=vc4-fkms-v3d
gpu_mem=512
display_rotate=3 270 degrees
# Auflösung mit wenigen Parametern vorgeben:
hdmi_cvt=1920 1080 60
# ausgelesene EDID nicht berücksichtigen:
hdmi_ignore_edid=0xa5000080
Alles anzeigen
Hat vielleicht jemand eine Idee warum es bei dem einem geht und beim anderen nicht? Bin hier am verzweifeln....
Vielen Dank!
