Moin allerseits. Ich habe mir über "Add / Remove Software" Telegram Desktop installiert. Wenn ich Telegram über das Programmmenü öffne, dann kommt die Sanduhr und dann nichts mehr. Über die Kommandozeile schmeißt er mir kryptische Fehlermeldungen raus. Kann mir jemand helfen?
pi@raspberrypi:~ $ telegram-desktop
(telegram-desktop:5852): GLib-GObject-WARNING **: 09:12:30.124: cannot register existing type 'GdkDisplayManager'
(telegram-desktop:5852): GLib-CRITICAL **: 09:12:30.124: g_once_init_leave: assertion 'result != 0' failed
(telegram-desktop:5852): GLib-GObject-CRITICAL **: 09:12:30.125: g_object_new_with_properties: assertion 'G_TYPE_IS_OBJECT (object_type)' failed
(telegram-desktop:5852): GLib-GObject-WARNING **: 09:12:30.125: invalid (NULL) pointer instance
(telegram-desktop:5852): GLib-GObject-CRITICAL **: 09:12:30.125: g_signal_connect_data: assertion 'G_TYPE_CHECK_INSTANCE (instance)' failed
(telegram-desktop:5852): GLib-GObject-WARNING **: 09:12:30.126: cannot register existing type 'GdkDisplay'
(telegram-desktop:5852): GLib-CRITICAL **: 09:12:30.126: g_once_init_leave: assertion 'result != 0' failed
(telegram-desktop:5852): GLib-GObject-CRITICAL **: 09:12:30.126: g_type_register_static: assertion 'parent_type > 0' failed
(telegram-desktop:5852): GLib-GObject-CRITICAL **: 09:12:30.126: g_object_new_with_properties: assertion 'G_TYPE_IS_OBJECT (object_type)' failed
Speicherzugriffsfehler
pi@raspberrypi:~ $
Display More
