Guten Tag,
ich hatte Probleme bei der Installation von Updates. Als ich sudo apt-get update eingegeben habe, erhielt ich folgende Fehlermeldung:
sudo apt-get update
Err:1 http://archive.raspberrypi.org/debian buster InRelease
Temporary failure resolving 'archive.raspberrypi.org'
Err:2 http://raspbian.raspberrypi.org/raspbian buster InRelease
Temporary failure resolving 'raspbian.raspberrypi.org'
Reading package lists... Done
W: Failed to fetch http://raspbian.raspberrypi.org/raspbian/dists/buster/InRelease Temporary failure resolving 'raspbian.raspberrypi.org'
W: Failed to fetch http://archive.raspberrypi.org/debian/dists/buster/InRelease Temporary failure resolving 'archive.raspberrypi.org'
W: Some index files failed to download. They have been ignored, or old ones used instead.
Ich hatte auch Probleme mit Pihole und wollte diesen updaten, aber auch hier kam eine Fehlermeldung
pihole -up
[✗] Retrieval of supported OS list failed. dig failed with return code 10.
Unable to determine if the detected OS (Raspbian 10) is supported
Possible causes for this include:
- Firewall blocking certain DNS lookups from Pi-hole device
- ns1.pi-hole.net being blocked (required to obtain TXT record from versions.pi-hole.net containing supported operating systems)
- Other internet connectivity issues
https://docs.pi-hole.net/main/prerequesites/#supported-operating-systems
If you wish to attempt to continue anyway, you can try one of the following commands to skip this check:
e.g: If you are seeing this message on a fresh install, you can run:
curl -sSL https://install.pi-hole.net | PIHOLE_SKIP_OS_CHECK=true sudo -E bash
If you are seeing this message after having run pihole -up:
PIHOLE_SKIP_OS_CHECK=true sudo -E pihole -r
(In this case, your previous run of pihole -up will have already updated the local repository)
It is possible that the installation will still fail at this stage due to an unsupported configuration.
If that is the case, you can feel free to ask the community on Discourse with the Community Help category:
https://discourse.pi-hole.net/c/bugs-problems-issues/community-help/
Unable to complete update, please contact Pi-hole Support
Alles anzeigen
Ich denke Pihole lässt sich nicht updaten, weil vielleicht das Rasbian nicht up to date. Aber ich weiß es nicht. Vielleicht kann mir jemand helfen.
Vielen Dank im Voraus
Liebe Grüße
