Hier ein mal die Ausgabe von dmesg:
dmesg:
[ 0.000000] Booting Linux on physical CPU 0x0
[ 0.000000] Linux version 5.10.17+ (dom@buildbot) (arm-linux-gnueabihf-gcc-8 (Ubuntu/Linaro 8.4.0-3ubuntu1) 8.4.0, GNU ld (GNU Binutils for Ubuntu) 2.34) #1414 Fri Apr 30 13:16:27 BST 2021
[ 0.000000] CPU: ARMv6-compatible processor [410fb767] revision 7 (ARMv7), cr=00c5387d
[ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT nonaliasing instruction cache
[ 0.000000] OF: fdt: Machine model: Raspberry Pi Zero W Rev 1.1
[ 0.000000] Memory policy: Data cache writeback
[ 0.000000] Reserved memory: created CMA memory pool at 0x17c00000, size 64 MiB
[ 0.000000] OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool
[ 0.000000] Zone ranges:
[ 0.000000] Normal [mem 0x0000000000000000-0x000000001bffffff]
[ 0.000000] Movable zone start for each node
[ 0.000000] Early memory node ranges
[ 0.000000] node 0: [mem 0x0000000000000000-0x000000001bffffff]
[ 0.000000] Initmem setup node 0 [mem 0x0000000000000000-0x000000001bffffff]
[ 0.000000] On node 0 totalpages: 114688
[ 0.000000] Normal zone: 1008 pages used for memmap
[ 0.000000] Normal zone: 0 pages reserved
[ 0.000000] Normal zone: 114688 pages, LIFO batch:31
[ 0.000000] pcpu-alloc: s0 r0 d32768 u32768 alloc=1*32768
[ 0.000000] pcpu-alloc: [0] 0
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 113680
[ 0.000000] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1 bcm2708_fb.fbwidth=1360 bcm2708_fb.fbheight=768 bcm2708_fb.fbswap=1 smsc95xx.macaddr=B8:27:EB:8A:C1:C5 vc_mem.mem_base=0x1ec00000 vc_mem.mem_size=0x20000000 console=ttyS0,115200 console=tty1 root=PARTUUID=c72a59e3-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait
[ 0.000000] Kernel parameter elevator= does not have any effect anymore.
Please use sysfs to set IO scheduler for individual devices.
[ 0.000000] Dentry cache hash table entries: 65536 (order: 6, 262144 bytes, linear)
[ 0.000000] Inode-cache hash table entries: 32768 (order: 5, 131072 bytes, linear)
[ 0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
[ 0.000000] Memory: 374456K/458752K available (8638K kernel code, 1324K rwdata, 2816K rodata, 420K init, 837K bss, 18760K reserved, 65536K cma-reserved)
[ 0.000000] SLUB: HWalign=32, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
[ 0.000000] ftrace: allocating 30576 entries in 60 pages
[ 0.000000] ftrace: allocated 60 pages with 4 groups
[ 0.000000] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16
[ 0.000000] random: get_random_bytes called from start_kernel+0x324/0x564 with crng_init=0
[ 0.000029] sched_clock: 32 bits at 1000kHz, resolution 1000ns, wraps every 2147483647500ns
[ 0.000111] clocksource: timer: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 1911260446275 ns
[ 0.000210] bcm2835: system timer (irq = 27)
[ 0.000908] Console: colour dummy device 80x30
[ 0.001593] printk: console [tty1] enabled
[ 0.001694] Calibrating delay loop... 697.95 BogoMIPS (lpj=3489792)
[ 0.060390] pid_max: default: 32768 minimum: 301
[ 0.060721] LSM: Security Framework initializing
[ 0.061080] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes, linear)
[ 0.061158] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes, linear)
[ 0.063628] Disabling memory control group subsystem
[ 0.063976] CPU: Testing write buffer coherency: ok
[ 0.066062] Setting up static identity map for 0x8200 - 0x8238
[ 0.067509] devtmpfs: initialized
[ 0.080945] VFP support v0.3: implementor 41 architecture 1 part 20 variant b rev 5
[ 0.081415] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[ 0.081507] futex hash table entries: 256 (order: -1, 3072 bytes, linear)
[ 0.090420] pinctrl core: initialized pinctrl subsystem
[ 0.092709] NET: Registered protocol family 16
[ 0.097469] DMA: preallocated 1024 KiB pool for atomic coherent allocations
[ 0.104484] audit: initializing netlink subsys (disabled)
[ 0.106195] thermal_sys: Registered thermal governor 'step_wise'
[ 0.107248] hw-breakpoint: found 6 breakpoint and 1 watchpoint registers.
[ 0.107350] hw-breakpoint: maximum watchpoint size is 4 bytes.
[ 0.107647] Serial: AMBA PL011 UART driver
[ 0.110868] audit: type=2000 audit(0.100:1): state=initialized audit_enabled=0 res=1
[ 0.131487] bcm2835-mbox 2000b880.mailbox: mailbox enabled
[ 0.150952] raspberrypi-firmware soc:firmware: Attached to firmware from 2021-04-30T13:47:07, variant start
[ 0.160973] raspberrypi-firmware soc:firmware: Firmware hash is d7f29d96450abfc77cd6cf011af1faf1e03e5e56
[ 0.224068] bcm2835-dma 20007000.dma: DMA legacy API manager, dmachans=0x1
[ 0.227449] SCSI subsystem initialized
[ 0.228027] usbcore: registered new interface driver usbfs
[ 0.228202] usbcore: registered new interface driver hub
[ 0.228358] usbcore: registered new device driver usb
[ 0.231439] clocksource: Switched to clocksource timer
[ 2.242448] VFS: Disk quotas dquot_6.6.0
[ 2.242658] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[ 2.242984] FS-Cache: Loaded
[ 2.243468] CacheFiles: Loaded
[ 2.264901] NET: Registered protocol family 2
[ 2.266406] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 4096 bytes, linear)
[ 2.266581] TCP established hash table entries: 4096 (order: 2, 16384 bytes, linear)
[ 2.266704] TCP bind hash table entries: 4096 (order: 2, 16384 bytes, linear)
[ 2.266810] TCP: Hash tables configured (established 4096 bind 4096)
[ 2.267048] UDP hash table entries: 256 (order: 0, 4096 bytes, linear)
[ 2.267134] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes, linear)
[ 2.267671] NET: Registered protocol family 1
[ 2.269119] RPC: Registered named UNIX socket transport module.
[ 2.269203] RPC: Registered udp transport module.
[ 2.269244] RPC: Registered tcp transport module.
[ 2.269279] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 2.270892] hw perfevents: no irqs for PMU, sampling events not supported
[ 2.271034] hw perfevents: enabled with armv6_1176 PMU driver, 3 counters available
[ 2.276391] Initialise system trusted keyrings
[ 2.277079] workingset: timestamp_bits=14 max_order=17 bucket_order=3
[ 2.289979] zbud: loaded
[ 2.293540] FS-Cache: Netfs 'nfs' registered for caching
[ 2.295179] NFS: Registering the id_resolver key type
[ 2.295307] Key type id_resolver registered
[ 2.295354] Key type id_legacy registered
[ 2.295630] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[ 2.297768] Key type asymmetric registered
[ 2.297856] Asymmetric key parser 'x509' registered
[ 2.297994] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 249)
[ 2.298052] io scheduler mq-deadline registered
[ 2.298094] io scheduler kyber registered
[ 2.301713] bcm2708_fb soc:fb: FB found 1 display(s)
[ 2.339472] Console: switching to colour frame buffer device 170x48
[ 2.339746] random: fast init done
[ 2.358596] bcm2708_fb soc:fb: Registered framebuffer for display 0, size 1360x768
[ 2.367915] bcm2835-rng 20104000.rng: hwrng registered
[ 2.368797] vc-mem: phys_addr:0x00000000 mem_base=0x1ec00000 mem_size:0x20000000(512 MiB)
[ 2.370949] gpiomem-bcm2835 20200000.gpiomem: Initialised: Registers at 0x20200000
[ 2.397251] brd: module loaded
[ 2.415481] loop: module loaded
[ 2.418318] Loading iSCSI transport class v2.0-870.
[ 2.421395] libphy: Fixed MDIO Bus: probed
[ 2.422232] usbcore: registered new interface driver smsc95xx
[ 2.422501] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
[ 3.151164] Core Release: 2.80a
[ 3.151369] Setting default values for core params
[ 3.158192] Finished setting default values for core params
[ 3.365362] Using Buffer DMA mode
[ 3.371873] Periodic Transfer Interrupt Enhancement - disabled
[ 3.378310] Multiprocessor Interrupt Enhancement - disabled
[ 3.384729] OTG VER PARAM: 0, OTG VER FLAG: 0
[ 3.391214] Dedicated Tx FIFOs mode
[ 3.398643] WARN::dwc_otg_hcd_init:1074: FIQ DMA bounce buffers: virt = d7d14000 dma = 0x97d14000 len=9024
[ 3.411561] FIQ FSM acceleration enabled for :
Non-periodic Split Transactions
Periodic Split Transactions
High-Speed Isochronous Endpoints
Interrupt/Control Split Transaction hack enabled
[ 3.443767] dwc_otg: Microframe scheduler enabled
[ 3.444082] WARN::hcd_init_fiq:457: FIQ on core 0
[ 3.456718] WARN::hcd_init_fiq:458: FIQ ASM at c0652330 length 36
[ 3.469182] WARN::hcd_init_fiq:497: MPHI regs_base at dc810000
[ 3.481871] dwc_otg 20980000.usb: DWC OTG Controller
[ 3.488390] dwc_otg 20980000.usb: new USB bus registered, assigned bus number 1
[ 3.495048] dwc_otg 20980000.usb: irq 56, io mem 0x00000000
[ 3.501544] Init: Port Power? op_state=1
[ 3.507935] Init: Power Port (0)
[ 3.514909] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.10
[ 3.521364] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 3.527840] usb usb1: Product: DWC OTG Controller
[ 3.534303] usb usb1: Manufacturer: Linux 5.10.17+ dwc_otg_hcd
[ 3.540779] usb usb1: SerialNumber: 20980000.usb
[ 3.548690] hub 1-0:1.0: USB hub found
[ 3.555348] hub 1-0:1.0: 1 port detected
[ 3.563696] dwc_otg: FIQ enabled
[ 3.563726] dwc_otg: NAK holdoff enabled
[ 3.563743] dwc_otg: FIQ split-transaction FSM enabled
[ 3.563773] Module dwc_common_port init
[ 3.564436] usbcore: registered new interface driver usb-storage
[ 3.571367] mousedev: PS/2 mouse device common for all mice
[ 3.579808] bcm2835-wdt bcm2835-wdt: Broadcom BCM2835 watchdog timer
[ 3.590123] sdhci: Secure Digital Host Controller Interface driver
[ 3.596481] sdhci: Copyright(c) Pierre Ossman
[ 3.603794] mmc-bcm2835 20300000.mmcnr: could not get clk, deferring probe
[ 3.611349] sdhost-bcm2835 20202000.mmc: could not get clk, deferring probe
[ 3.618395] sdhci-pltfm: SDHCI platform and OF driver helper
[ 3.625842] ledtrig-cpu: registered to indicate activity on CPUs
[ 3.632941] hid: raw HID events driver (C) Jiri Kosina
[ 3.639665] usbcore: registered new interface driver usbhid
[ 3.646131] usbhid: USB HID core driver
[ 3.660384] Initializing XFRM netlink socket
[ 3.667593] NET: Registered protocol family 17
[ 3.674610] Key type dns_resolver registered
[ 3.681958] registered taskstats version 1
[ 3.688164] Loading compiled-in X.509 certificates
[ 3.713293] uart-pl011 20201000.serial: cts_event_workaround enabled
[ 3.719901] 20201000.serial: ttyAMA0 at MMIO 0x20201000 (irq = 81, base_baud = 0) is a PL011 rev2
[ 3.730388] bcm2835-power bcm2835-power: Broadcom BCM2835 power domains driver
[ 3.739727] mmc-bcm2835 20300000.mmcnr: mmc_debug:0 mmc_debug2:0
[ 3.746313] mmc-bcm2835 20300000.mmcnr: DMA channel allocated
[ 3.781549] sdhost: log_buf @ (ptrval) (97d13000)
[ 3.788936] Indeed it is in host mode hprt0 = 00021501
[ 3.904911] mmc0: sdhost-bcm2835 loaded - DMA enabled (>1)
[ 3.916372] of_cfs_init
[ 3.948696] of_cfs_init: OK
[ 3.957812] Waiting for root device PARTUUID=c72a59e3-02...
[ 4.022855] usb 1-1: new full-speed USB device number 2 using dwc_otg
[ 4.030815] Indeed it is in host mode hprt0 = 00021501
[ 4.113559] mmc0: host does not support reading read-only switch, assuming write-enable
[ 4.132089] mmc0: new high speed SDXC card at address aaaa
[ 4.144863] mmcblk0: mmc0:aaaa SC64G 59.5 GiB
[ 4.157725] mmcblk0: p1 p2
[ 4.224744] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
[ 4.231895] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
[ 4.250079] devtmpfs: mounted
[ 4.264126] Freeing unused kernel memory: 420K
[ 4.270736] Kernel memory protection not selected by kernel config.
[ 4.278711] Run /sbin/init as init process
[ 4.285407] with arguments:
[ 4.285429] /sbin/init
[ 4.285443] with environment:
[ 4.285457] HOME=/
[ 4.285492] TERM=linux
[ 4.286703] usb 1-1: New USB device found, idVendor=05e3, idProduct=0606, bcdDevice= 7.02
[ 4.293685] usb 1-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 4.300528] usb 1-1: Product: USB Hub 2.0
[ 4.307422] usb 1-1: Manufacturer: ALCOR
[ 4.317722] hub 1-1:1.0: USB hub found
[ 4.326385] hub 1-1:1.0: 4 ports detected
[ 4.651627] usb 1-1.1: new full-speed USB device number 3 using dwc_otg
[ 4.784353] usb 1-1.1: New USB device found, idVendor=1997, idProduct=2433, bcdDevice=20.12
[ 4.791193] usb 1-1.1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 4.797885] usb 1-1.1: Product: Mini Keyboard
[ 4.804473] usb 1-1.1: Manufacturer:
[ 4.848407] input: Mini Keyboard as /devices/platform/soc/20980000.usb/usb1/1-1/1-1.1/1-1.1:1.0/0003:1997:2433.0001/input/input0
[ 4.933435] hid-generic 0003:1997:2433.0001: input,hidraw0: USB HID v1.01 Keyboard [ Mini Keyboard] on usb-20980000.usb-1.1/input0
[ 4.956760] input: Mini Keyboard Mouse as /devices/platform/soc/20980000.usb/usb1/1-1/1-1.1/1-1.1:1.1/0003:1997:2433.0002/input/input1
[ 4.966447] input: Mini Keyboard System Control as /devices/platform/soc/20980000.usb/usb1/1-1/1-1.1/1-1.1:1.1/0003:1997:2433.0002/input/input2
[ 5.052563] input: Mini Keyboard Consumer Control as /devices/platform/soc/20980000.usb/usb1/1-1/1-1.1/1-1.1:1.1/0003:1997:2433.0002/input/input3
[ 5.062875] hid-generic 0003:1997:2433.0002: input,hidraw1: USB HID v1.01 Mouse [ Mini Keyboard] on usb-20980000.usb-1.1/input1
[ 5.150160] systemd[1]: System time before build time, advancing clock.
[ 5.334260] NET: Registered protocol family 10
[ 5.344945] Segment Routing with IPv6
[ 5.482969] systemd[1]: systemd 241 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybrid)
[ 5.502275] systemd[1]: Detected architecture arm.
[ 5.557101] systemd[1]: Set hostname to <raspberrypi>.
[ 8.565693] random: systemd: uninitialized urandom read (16 bytes read)
[ 8.603989] random: systemd: uninitialized urandom read (16 bytes read)
[ 8.618538] systemd[1]: Created slice User and Session Slice.
[ 8.637752] random: systemd: uninitialized urandom read (16 bytes read)
[ 8.646618] systemd[1]: Reached target Slices.
[ 8.667737] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[ 8.688533] systemd[1]: Listening on udev Kernel Socket.
[ 8.714099] systemd[1]: Created slice system-systemd\x2dfsck.slice.
[ 8.733363] systemd[1]: Reached target Swap.
[ 8.753043] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[ 10.532083] systemd[1]: Started Restore / save the current clock.
[ 10.687627] systemd[1]: Starting File System Check on Root Device...
[ 10.857977] systemd[1]: Starting Apply Kernel Variables...
[ 10.971897] systemd[1]: Condition check resulted in FUSE Control File System being skipped.
[ 11.123028] systemd[1]: Mounting Kernel Configuration File System...
[ 11.515618] systemd[1]: Mounted Kernel Configuration File System.
[ 11.725630] systemd[1]: Started File System Check Daemon to report status.
[ 11.842323] systemd[1]: Started Apply Kernel Variables.
[ 11.981858] systemd[1]: Started Journal Service.
[ 13.692991] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
[ 14.485588] systemd-journald[87]: Received request to flush runtime journal from PID 1
[ 17.114465] vc_sm_cma: module is from the staging directory, the quality is unknown, you have been warned.
[ 17.117561] bcm2835_vc_sm_cma_probe: Videocore shared memory driver
[ 17.117605] [vc_sm_connected_init]: start
[ 17.138493] mc: Linux media interface: v0.10
[ 17.182236] [vc_sm_connected_init]: installed successfully
[ 17.428065] videodev: Linux video capture interface: v2.00
[ 17.520104] bcm2835_mmal_vchiq: module is from the staging directory, the quality is unknown, you have been warned.
[ 17.542596] bcm2835_mmal_vchiq: module is from the staging directory, the quality is unknown, you have been warned.
[ 17.544832] bcm2835_mmal_vchiq: module is from the staging directory, the quality is unknown, you have been warned.
[ 17.577990] snd_bcm2835: module is from the staging directory, the quality is unknown, you have been warned.
[ 17.579311] bcm2835_isp: module is from the staging directory, the quality is unknown, you have been warned.
[ 17.581315] bcm2835_v4l2: module is from the staging directory, the quality is unknown, you have been warned.
[ 17.622727] bcm2835_audio bcm2835_audio: there is not valid maps for state default
[ 17.667821] bcm2835-isp bcm2835-isp: Device node output[0] registered as /dev/video13
[ 17.673558] bcm2835-isp bcm2835-isp: Device node capture[0] registered as /dev/video14
[ 17.695628] bcm2835_codec: module is from the staging directory, the quality is unknown, you have been warned.
[ 17.703053] bcm2835_audio bcm2835_audio: card created with 8 channels
[ 17.704373] bcm2835-isp bcm2835-isp: Device node capture[1] registered as /dev/video15
[ 17.737922] bcm2835-isp bcm2835-isp: Device node stats[2] registered as /dev/video16
[ 17.737998] bcm2835-isp bcm2835-isp: Register output node 0 with media controller
[ 17.738074] bcm2835-isp bcm2835-isp: Register capture node 1 with media controller
[ 17.738113] bcm2835-isp bcm2835-isp: Register capture node 2 with media controller
[ 17.738146] bcm2835-isp bcm2835-isp: Register capture node 3 with media controller
[ 17.761957] bcm2835-isp bcm2835-isp: Loaded V4L2 bcm2835-isp
[ 17.790391] bcm2835-codec bcm2835-codec: Device registered as /dev/video10
[ 17.790491] bcm2835-codec bcm2835-codec: Loaded V4L2 decode
[ 17.872374] bcm2835-codec bcm2835-codec: Device registered as /dev/video11
[ 17.872471] bcm2835-codec bcm2835-codec: Loaded V4L2 encode
[ 17.902580] bcm2835-codec bcm2835-codec: Device registered as /dev/video12
[ 17.902678] bcm2835-codec bcm2835-codec: Loaded V4L2 isp
[ 27.900641] random: crng init done
[ 27.900680] random: 7 urandom warning(s) missed due to ratelimiting
[ 30.761364] 8021q: 802.1Q VLAN Support v1.8
[ 31.010995] uart-pl011 20201000.serial: no DMA platform data
[ 31.215745] Adding 102396k swap on /var/swap. Priority:-2 extents:1 across:102396k SSFS
[ 31.573505] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[ 32.074718] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[ 35.655885] Bluetooth: Core ver 2.22
[ 35.656091] NET: Registered protocol family 31
[ 35.656108] Bluetooth: HCI device and connection manager initialized
[ 35.661325] Bluetooth: HCI socket layer initialized
[ 35.661365] Bluetooth: L2CAP socket layer initialized
[ 35.666212] Bluetooth: SCO socket layer initialized
[ 35.682106] Bluetooth: HCI UART driver ver 2.3
[ 35.682139] Bluetooth: HCI UART protocol H4 registered
[ 35.682320] Bluetooth: HCI UART protocol Three-wire (H5) registered
[ 35.682702] Bluetooth: HCI UART protocol Broadcom registered
[ 36.510505] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 36.510532] Bluetooth: BNEP filters: protocol multicast
[ 36.510571] Bluetooth: BNEP socket layer initialized
Alles anzeigen
