Hey,
mittlerweile ist es nicht mehr schön. Auf meinen 3er und 2er läuft alles ohne Probleme, aber auf dem 4er ist es zum würgen.
Ich möchte Octodash installieren und bekomme folgenden Fehler. Google habe ich mich schon tot gesucht, aber finde keine Lösung.
pi@octopi:~ $ bash <(wget -qO- https://github.com/UnchartedBull/OctoDash/raw/main/scripts/install.sh)
Installing OctoDash v2.2.0, armv7l
Installing Dependencies ...
13 packages can be upgraded. Run 'apt list --upgradable' to see them.
libavahi-compat-libdnssd1 is already the newest version (0.7-4+deb10u1).
libuuid1 is already the newest version (2.33.1-0.1).
libx11-dev is already the newest version (2:1.6.7-1+deb10u2).
libpam0g-dev is already the newest version (1.4.0-7+rpt1).
Some packages could not be installed. This may mean that you have
requested an impossible situation or if you are using the unstable
distribution that some required packages have not yet been created
or been moved out of Incoming.
The following information may help to resolve the situation:
The following packages have unmet dependencies:
libappindicator3-1 : Depends: libcairo-gobject2 (>= 1.10.0) but it is not going to be installed
Depends: libcairo2 (>= 1.2.4) but it is not going to be installed
Depends: libdbusmenu-gtk3-4 (>= 0.4.2) but it is not going to be installed
Depends: libindicator3-7 but it is not going to be installed
Depends: libpangocairo-1.0-0 (>= 1.14.0) but it is not going to be installed
libgtk-3-0 : Depends: adwaita-icon-theme but it is not going to be installed
Depends: libatk1.0-0 (>= 2.35.1) but 2.30.0-2 is to be installed
Depends: libc6 (>= 2.29) but 2.28-10+rpi1 is to be installed
Depends: libcairo-gobject2 (>= 1.14.0) but it is not going to be installed
Depends: libcairo2 (>= 1.14.0) but it is not going to be installed
Depends: libgdk-pixbuf-2.0-0 (>= 2.40.0) but it is not installable
Depends: libglib2.0-0 (>= 2.59.0) but 2.58.3-2+deb10u2 is to be installed
Depends: libjson-glib-1.0-0 (>= 1.5.2) but it is not going to be installed
Depends: libpango-1.0-0 (>= 1.45.5) but 1.42.4-8~deb10u1 is to be installed
Depends: libpangocairo-1.0-0 (>= 1.41.0) but it is not going to be installed
Depends: libxcomposite1 (>= 1:0.4.5) but 1:0.4.4-2 is to be installed
Recommends: libgtk-3-bin but it is not going to be installed
Recommends: librsvg2-common but it is not going to be installed
xserver-xorg : Depends: xserver-xorg-core (>= 2:1.17.2-2) but it is not going to be installed
Depends: xserver-xorg-video-all but it is not going to be installed or
xorg-driver-video
Depends: xserver-xorg-input-all but it is not going to be installed or
xorg-driver-input
Recommends: libgl1-mesa-dri but it is not going to be installed
E: Unable to correct problems, you have held broken packages.
Couldn't install dependenices!
Seems like there is something wrong with the package manager 'apt'
If the error is similar to: 'E: Repository 'http://raspbian.raspberrypi.org/raspbian buster InRelease' changed its 'Suite' value from 'stable' to 'oldstable''
you can run 'sudo apt update --allow-releaseinfo-change' and then execute the OctoDash installation command again
pi@octopi:~ $
Alles anzeigen
Meine Source List wie folgt:
#deb http://archive.raspberrypi.org/debian/ buster main
# Uncomment line below then 'apt-get update' to enable 'apt-get source'
#deb-src http://archive.raspberrypi.org/debian/ buster main
deb https://archive.raspberrypi.org/debian/ buster main
deb https://archive.raspberrypi.org/debian/ bullseye main
Upgraden kann ich folgendes, aber nur wie?
pi@octopi:~ $ apt list --upgradable
Listing... Done
alsa-utils/unstable 1.2.4-1+rpt1 armhf [upgradable from: 1.1.8-2]
bluez/unstable 5.55-3.1+rpt1 armhf [upgradable from: 5.50-1.2~deb10u1+rpt2]
libasound2-data/unstable 1.2.4-1.1+rpt1 all [upgradable from: 1.1.8-1+rpt1]
libasound2/unstable 1.2.4-1.1+rpt1 armhf [upgradable from: 1.1.8-1+rpt1]
libc-bin/unstable 2.31-13+rpt2+rpi1 armhf [upgradable from: 2.28-10+rpi1]
libc-dev-bin/unstable 2.31-13+rpt2+rpi1 armhf [upgradable from: 2.28-10+rpi1]
libc6-dbg/unstable 2.31-13+rpt2+rpi1 armhf [upgradable from: 2.28-10+rpi1]
libc6-dev/unstable 2.31-13+rpt2+rpi1 armhf [upgradable from: 2.28-10+rpi1]
libc6/unstable 2.31-13+rpt2+rpi1 armhf [upgradable from: 2.28-10+rpi1]
libpam-chksshpwd/unstable 1.4.0-7+rpt1 armhf [upgradable from: 1.3.1-5+rpt2]
libpam-modules-bin/unstable 1.4.0-7+rpt1 armhf [upgradable from: 1.3.1-5+rpt2]
libpam-modules/unstable 1.4.0-7+rpt1 armhf [upgradable from: 1.3.1-5+rpt2]
locales/unstable 2.31-13+rpt2+rpi1 all [upgradable from: 2.28-10+rpi1]
pi@octopi:~ $
Alles anzeigen
