Moin!
Der owserver scheint bei mir nicht zu laufen. Ich bekomme folgende Fehlermeldung(en):
pi@pi4:/dev $ sudo service owserver restart
Job for owserver.service failed because the control process exited with error code.
See "systemctl status owserver.service" and "journalctl -xe" for details.
pi@pi4:/dev $ systemctl status owserver.service
● owserver.service - Backend server for 1-wire control
Loaded: loaded (/lib/systemd/system/owserver.service; enabled; vendor preset: enabled)
Active: failed (Result: exit-code) since Mon 2022-01-10 23:07:37 CET; 7min ago
TriggeredBy: ● owserver.socket
Docs: man:owserver(1)
Process: 9786 ExecStart=/usr/bin/owserver --foreground -c /etc/owfs.conf (code=exited, status=1/FAILURE)
Main PID: 9786 (code=exited, status=1/FAILURE)
CPU: 76ms
Jan 10 23:07:37 pi4 systemd[1]: owserver.service: Scheduled restart job, restart counter is at 5.
Jan 10 23:07:37 pi4 systemd[1]: Stopped Backend server for 1-wire control.
Jan 10 23:07:37 pi4 systemd[1]: owserver.service: Start request repeated too quickly.
Jan 10 23:07:37 pi4 systemd[1]: owserver.service: Failed with result 'exit-code'.
Jan 10 23:07:37 pi4 systemd[1]: Failed to start Backend server for 1-wire control.
pi@pi4:/dev $ journalctl -xe
░░ A start job for unit phpsessionclean.service has begun execution.
░░ The job identifier is 7022.
Jan 10 23:09:01 pi4 systemd[1]: phpsessionclean.service: Succeeded.
░░ Subject: Unit succeeded
░░ Defined-By: systemd
░░ Support: https://www.debian.org/support
░░ The unit phpsessionclean.service has successfully entered the 'dead' state.
Jan 10 23:09:01 pi4 systemd[1]: Finished Clean php session files.
░░ Subject: A start job for unit phpsessionclean.service has finished successfully
░░ A start job for unit phpsessionclean.service has finished successfully.
Jan 10 23:09:02 pi4 CRON[9824]: pam_unix(cron:session): session opened for user root(uid=0) by (uid=0)
Jan 10 23:09:02 pi4 CRON[9825]: (root) CMD ( [ -x /usr/lib/php/sessionclean ] && if [ ! -d /run/systemd/system ]; then />
Jan 10 23:09:02 pi4 CRON[9824]: pam_unix(cron:session): session closed for user root
Jan 10 23:09:24 pi4 kernel: w1_master_driver w1_bus_master1: Attaching one wire slave 00.866000000000 crc 0b
Jan 10 23:09:24 pi4 kernel: w1_master_driver w1_bus_master1: Family 0 for 00.866000000000.0b is not registered.
Jan 10 23:10:02 pi4 kernel: w1_master_driver w1_bus_master1: Attaching one wire slave 00.466000000000 crc c1
Jan 10 23:10:02 pi4 kernel: w1_master_driver w1_bus_master1: Family 0 for 00.466000000000.c1 is not registered.
Jan 10 23:11:06 pi4 kernel: w1_master_driver w1_bus_master1: Attaching one wire slave 00.c66000000000 crc 4d
Jan 10 23:11:06 pi4 kernel: w1_master_driver w1_bus_master1: Family 0 for 00.c66000000000.4d is not registered.
Jan 10 23:11:31 pi4 kernel: w1_master_driver w1_bus_master1: Attaching one wire slave 00.266000000000 crc a4
Jan 10 23:11:31 pi4 kernel: w1_master_driver w1_bus_master1: Family 0 for 00.266000000000.a4 is not registered.
Jan 10 23:12:22 pi4 kernel: w1_master_driver w1_bus_master1: Attaching one wire slave 00.a66000000000 crc 28
Jan 10 23:12:22 pi4 kernel: w1_master_driver w1_bus_master1: Family 0 for 00.a66000000000.28 is not registered.
Jan 10 23:13:25 pi4 kernel: w1_master_driver w1_bus_master1: Attaching one wire slave 00.666000000000 crc e2
Jan 10 23:13:25 pi4 kernel: w1_master_driver w1_bus_master1: Family 0 for 00.666000000000.e2 is not registered.
Jan 10 23:14:19 pi4 kernel: w1_master_driver w1_bus_master1: Attaching one wire slave 00.e66000000000 crc 6e
Jan 10 23:14:19 pi4 kernel: w1_master_driver w1_bus_master1: Family 0 for 00.e66000000000.6e is not registered.
Jan 10 23:15:09 pi4 kernel: w1_master_driver w1_bus_master1: Attaching one wire slave 00.166000000000 crc 1a
Jan 10 23:15:09 pi4 kernel: w1_master_driver w1_bus_master1: Family 0 for 00.166000000000.1a is not registered.
Jan 10 23:16:01 pi4 kernel: w1_master_driver w1_bus_master1: Attaching one wire slave 00.966000000000 crc 96
Jan 10 23:16:01 pi4 kernel: w1_master_driver w1_bus_master1: Family 0 for 00.966000000000.96 is not registered.
lines 1611-1648/1648 (END)
Alles anzeigen
Ich erkenne, das was nicht läuft, aber nichts "was" oder "Warum". Wer kann mir Tips geben?
Thomas
