Ich habe das aktuelle Bullseye Image installiert auf dem Raspi2.
Da geht ja nur libcamera. Dazu habe ich auch die Apps installiert.
Leider wird die Kamera nicht erkannt, auch eine NOIR Kameramodul wird nicht erkannt.
Hier die Fehlermeldung:
$ libcamera-hello
Preview window unavailable
[0:02:12.373276654] [653] INFO Camera camera_manager.cpp:293 libcamera v0.0.0+3384-44d59841
[0:02:12.414182518] [654] ERROR CameraSensor camera_sensor.cpp:535 'ov5647 10-0036': Camera sensor does not support test pattern modes.
[0:02:12.495617326] [654] INFO RPI raspberrypi.cpp:1313 Registered camera /base/soc/i2c0mux/i2c@1/ov5647@36 to Unicam device /dev/media3 and ISP device /dev/media0
[0:02:12.497552864] [653] INFO Camera camera.cpp:1028 configuring streams: (0) 1296x972-YUV420
[0:02:12.498525554] [654] INFO RPI raspberrypi.cpp:738 Sensor: /base/soc/i2c0mux/i2c@1/ov5647@36 - Selected sensor format: 1296x972-SGBRG10_1X10 - Selected unicam format: 1296x972-pGAA
[0:02:12.542374854] [659] INFO IPARPI raspberrypi.cpp:626 Request ctrl: Saturation = 1.000000
[0:02:12.542748181] [659] INFO IPARPI raspberrypi.cpp:626 Request ctrl: Contrast = 1.000000
[0:02:12.542963385] [659] INFO IPARPI raspberrypi.cpp:626 Request ctrl: Brightness = 0.000000
[0:02:12.543176662] [659] INFO IPARPI raspberrypi.cpp:626 Request ctrl: AwbMode = 0
[0:02:12.543359315] [659] INFO IPARPI raspberrypi.cpp:626 Request ctrl: Sharpness = 1.000000
[0:02:12.543570353] [659] INFO IPARPI raspberrypi.cpp:626 Request ctrl: ExposureValue = 0.000000
[0:02:12.543772120] [659] INFO IPARPI raspberrypi.cpp:626 Request ctrl: AeExposureMode = 0
[0:02:12.543956336] [659] INFO IPARPI raspberrypi.cpp:626 Request ctrl: FrameDurationLimits = [ 33333, 33333 ]
[0:02:12.544145343] [659] INFO IPARPI raspberrypi.cpp:626 Request ctrl: AeMeteringMode = 0
[0:02:12.544321798] [659] INFO IPARPI raspberrypi.cpp:626 Request ctrl: NoiseReductionMode = 3
[0:02:12.547240755] [654] INFO RPISTREAM rpi_stream.cpp:133 No buffers available for ISP Output0
[0:02:12.547362679] [654] INFO RPISTREAM rpi_stream.cpp:133 No buffers available for ISP Output0
Alles anzeigen
Meine config.txt sieht so aus:
cat /boot/config.txt
dtparam=audio=on
camera_auto_detect=1
display_auto_detect=1
dtoverlay=vc4-kms-v3d
max_framebuffers=2
disable_overscan=1
[cm4]
otg_mode=1
[all]
[pi4]
arm_boost=1
[all]
Alles anzeigen
Hat jemand eine Idee an was das liegt?
