#dmesg
[ 133.352901] usb 1-1.1: new high-speed USB device number 5 using xhci_hcd
[ 133.453622] usb 1-1.1: New USB device found, idVendor=1d6c, idProduct=1278, bcdDevice= 0.10
[ 133.453637] usb 1-1.1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 133.453642] usb 1-1.1: Product: Web Camera
[ 133.453647] usb 1-1.1: Manufacturer: HD WEBCAM
[ 133.453652] usb 1-1.1: SerialNumber: xxxxxx
[ 133.500805] usb 1-1.1: Found UVC 1.00 device Web Camera (1d6c:1278)
[ 133.507668] input: Web Camera: Web Camera as /devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.1/1-1.1:1.0/input/input8
[ 133.510410] usbcore: registered new interface driver uvcvideo
[ 133.557523] usbcore: registered new interface driver snd-usb-audio
[ 136.198130] v3d fec00000.v3d: MMU error from client CLE (4) at 0x7e21000, pte invalid
Alles anzeigen
Starte ich guvcview, sehe ich ein grünliches Bild also keine reine grüne Fläche.
$ guvcview
V4L2_CORE: Unable to find parent usb device.V4L2_CORE: Unable to find parent usb device.V4L2_CORE: Unable to find parent usb device.V4L2_CORE: Unable to find parent usb device.V4L2_CORE: Unable to find parent usb device.V4L2_CORE: Unable to find parent usb device.V4L2_CORE: Unable to find parent usb device.GUVCVIEW: version 2.0.6
V4L2_CORE: (UVCIOC_CTRL_MAP) Error: No such file or directory
ALSA lib pcm_asym.c:105:(_snd_pcm_asym_open) capture slave is not defined
ALSA lib pcm_dmix.c:1075:(snd_pcm_dmix_open) unable to open slave
ALSA lib pcm.c:2660:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.rear
ALSA lib pcm.c:2660:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.center_lfe
ALSA lib pcm.c:2660:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.side
ALSA lib confmisc.c:1281:(snd_func_refer) Unable to find definition 'cards.vc4-hdmi.pcm.surround51.0:CARD=0'
ALSA lib conf.c:4745:(_snd_config_evaluate) function snd_func_refer returned error: No such file or directory
ALSA lib conf.c:5233:(snd_config_expand) Evaluate error: No such file or directory
ALSA lib pcm.c:2660:(snd_pcm_open_noupdate) Unknown PCM surround21
ALSA lib confmisc.c:1281:(snd_func_refer) Unable to find definition 'cards.vc4-hdmi.pcm.surround40.0:CARD=0'
ALSA lib pcm.c:2660:(snd_pcm_open_noupdate) Unknown PCM surround40
ALSA lib pcm.c:2660:(snd_pcm_open_noupdate) Unknown PCM surround41
ALSA lib pcm.c:2660:(snd_pcm_open_noupdate) Unknown PCM surround50
ALSA lib pcm.c:2660:(snd_pcm_open_noupdate) Unknown PCM surround51
ALSA lib confmisc.c:1281:(snd_func_refer) Unable to find definition 'cards.vc4-hdmi.pcm.surround71.0:CARD=0'
ALSA lib pcm.c:2660:(snd_pcm_open_noupdate) Unknown PCM surround71
ALSA lib pcm.c:2660:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.hdmi
ALSA lib pcm.c:2660:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.modem
ALSA lib pcm.c:2660:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.phoneline
Cannot connect to server socket err = No such file or directory
Cannot connect to server request channel
jack server is not running or cannot be started
JackShmReadWritePtr::~JackShmReadWritePtr - Init not done for -1, skipping unlock
ALSA lib pcm_oss.c:377:(_snd_pcm_oss_open) Unknown field port
ALSA lib pcm_usb_stream.c:486:(_snd_pcm_usb_stream_open) Invalid type for card
Alles anzeigen
Mit dino sieht das Bild normal aus, dh Farben sind ok.
Vielleicht ist es nur eine Einstellungssache, finde aber nichts, auch nicht mit qv4l2.
