Bern93 : getestet. Funktioniert eigentlich alles wie in der Doku beschrieben.
nginx Konfiguration: /etc/nginx/sites-available:
# You should look at the following URL's in order to grasp a solid understanding
# of Nginx configuration files in order to fully unleash the power of Nginx.
# https://www.nginx.com/resources/wiki/start/
# https://www.nginx.com/resources/wiki/start/topics/tutorials/config_pitfalls/
# https://wiki.debian.org/Nginx/DirectoryStructure
# In most cases, administrators will remove this file from sites-enabled/ and
# leave it as reference inside of sites-available where it will continue to be
# updated by the nginx packaging team.
# This file will automatically load configuration files provided by other
# applications, such as Drupal or Wordpress. These applications will be made
# available underneath a path with that package name, such as /drupal8.
# Please see /usr/share/doc/nginx-doc/examples/ for more detailed examples.
# Default server configuration
server {
listen 80 default_server;
listen [::]:80 default_server;
# SSL configuration
# listen 443 ssl default_server;
# listen [::]:443 ssl default_server;
# Note: You should disable gzip for SSL traffic.
# See: https://bugs.debian.org/773332
# Read up on ssl_ciphers to ensure a secure configuration.
# See: https://bugs.debian.org/765782
# Self signed certs generated by the ssl-cert package
# Don't use them in a production server!
# include snippets/snakeoil.conf;
root /var/www/html;
# Add index.php to the list if you are using PHP
index index.html index.htm index.nginx-debian.html;
server_name _;
location /app {
proxy_pass http://127.0.0.1:8502/;
proxy_http_version 1.1;
proxy_set_header Upgrade $http_upgrade;
proxy_set_header Connection keep-alive;
proxy_set_header Host $host;
proxy_cache_bypass $http_upgrade;
proxy_set_header X-Forwarded-For $proxy_add_x_forwarded_for;
proxy_set_header X-Forwarded-Proto $scheme;
location /ws {
proxy_pass http://127.0.0.1:8502/ws;
proxy_set_header Connection "upgrade";
location / {
# First attempt to serve request as file, then
# as directory, then fall back to displaying a 404.
try_files $uri $uri/ =404;
# pass PHP scripts to FastCGI server
#location ~ \.php$ {
# include snippets/fastcgi-php.conf;
# # With php-fpm (or other unix sockets):
# fastcgi_pass unix:/run/php/php7.4-fpm.sock;
# # With php-cgi (or other tcp sockets):
# fastcgi_pass 127.0.0.1:9000;
# deny access to .htaccess files, if Apache's document root
# concurs with nginx's one
#location ~ /\.ht {
# deny all;
# Virtual Host configuration for example.com
# You can move that to a different file under sites-available/ and symlink that
# to sites-enabled/ to enable it.
#server {
# listen 80;
# listen [::]:80;
# server_name example.com;
# root /var/www/example.com;
# index index.html;
# location / {
# try_files $uri $uri/ =404;
Alles anzeigen
Das ist die OOTB Konfiguration (unter Ubuntu), erweitert um zwei `location` Direktiven.
Die App namens `counter.py':
import os
import flet as ft
DEFAULT_FLET_PATH = '' # or 'ui/path'
DEFAULT_FLET_PORT = 8502
def main(page: ft.Page):
page.title = "Flet counter example"
page.vertical_alignment = ft.MainAxisAlignment.CENTER
txt_number = ft.TextField(value="0", text_align=ft.TextAlign.RIGHT, width=100)
def minus_click(e):
txt_number.value = str(int(txt_number.value) - 1)
page.update()
def plus_click(e):
txt_number.value = str(int(txt_number.value) + 1)
page.update()
page.add(
ft.Row(
ft.IconButton(ft.icons.REMOVE, on_click=minus_click),
txt_number,
ft.IconButton(ft.icons.ADD, on_click=plus_click),
alignment=ft.MainAxisAlignment.CENTER,
if __name__ == "__main__":
flet_path = os.getenv("FLET_PATH", DEFAULT_FLET_PATH)
flet_port = int(os.getenv("FLET_PORT", DEFAULT_FLET_PORT))
ft.app(name=flet_path, target=main, view=None, port=flet_port)
Alles anzeigen
Python-App starten via python3 counter.py
Fertig. Der Aufruf von `http://localhost` liefert die Defaultseite von nginx, der Aufruf von `http://localhost/app` auf dem Rechner, wo das läuft. Von einem anderen Rechner im gleichen Netz funktioniert das auch über die IP-Adresse des Host-Rechners. ABER: wenn ich diese Seite über Safari (iOS oder iPadOS) aufrufe, kommt die Seite zwar, aber ich sehe nur einen Platzhalter für das Flet Logo im Ladebildschirm, mehr passiert nicht.
Ob das irgendwie an Sicherheitseinstellungen von iOS oder den Websockets oder was auch immer liegt - keine Ahnung.
Gruß, noisefloor
