hi,
mein piVPN installation liefert wenn ich mit dem client (Android) drauf gehe
May 30 08:12:50 raspiInsel ovpn-server[915]: tls-crypt unwrap error: packet authentication failed
May 30 08:12:50 raspiInsel ovpn-server[915]: TLS Error: tls-crypt unwrapping failed from [AF_INET]xxxxx:46843
server.conf:
cat server.conf
dev tun
proto udp
port 1194
ca /etc/openvpn/easy-rsa/pki/ca.crt
cert /etc/openvpn/easy-rsa/pki/issued/raspiInsel_8e6e22e4-bae2-4db0-96e9-41f8137a53d9.crt
key /etc/openvpn/easy-rsa/pki/private/raspiInsel_8e6e22e4-bae2-4db0-96e9-41f8137a53d9.key
dh none
ecdh-curve prime256v1
topology subnet
server 10.226.253.0 255.255.255.0
# Set your primary domain name server address for clients
push "dhcp-option DNS 10.226.253.1"
push "block-outside-dns"
# Override the Client default gateway by using 0.0.0.0/1 and
# 128.0.0.0/1 rather than 0.0.0.0/0. This has the benefit of
# overriding but not wiping out the original default gateway.
push "redirect-gateway def1"
client-to-client
client-config-dir /etc/openvpn/ccd
keepalive 15 120
remote-cert-tls client
tls-version-min 1.2
tls-crypt /etc/openvpn/easy-rsa/pki/ta.key
cipher AES-256-CBC
auth SHA256
user openvpn
group openvpn
persist-key
persist-tun
crl-verify /etc/openvpn/crl.pem
status /var/log/openvpn-status.log 20
status-version 3
syslog
verb 3
#DuplicateCNs allow access control on a less-granular, per user basis.
#Remove # if you will manage access by user instead of device.
#duplicate-cn
# Generated for use by PiVPN.io
Display More
