raspi3 start nach upgrade nur im CLI-mode
  • unser heizpi (raspi3B+) startet nach einem upgrade nur im CLI-mode.
    startx ergibt folgenden Fehlersermon:
    lothar@heizpi02:~/wpibex $ startx
    X.Org X Server 1.21.1.7
    X Protocol Version 11, Revision 0
    Current Operating System: Linux heizpi02 6.1.21-v7+ #1642 SMP Mon Apr 3 17:20:52 BST 2023 armv7l
    Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0 video=HDMI-A-1:1366x768M@60 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000 console=tty1 root=PARTUUID=e046bd0f-02 rootfstype=ext4 fsck.repair=yes rootwait
    xorg-server 2:21.1.7-3+rpt2+deb12u7 (https://www.debian.org/support)
    Current version of pixman: 0.42.2
    Before reporting problems, check http://wiki.x.org
    to make sure that you have the latest version.
    Markers: (--) probed, (**) from config file, (==) default setting,
    (++) from command line, (!!) notice, (II) informational,
    (WW) warning, (EE) error, (NI) not implemented, (??) unknown.
    (==) Log file: "/home/lothar/.local/share/xorg/Xorg.1.log", Time: Fri May 10 10:19:00 2024
    (==) Using config directory: "/etc/X11/xorg.conf.d"
    (==) Using system config directory "/usr/share/X11/xorg.conf.d"
    (EE)
    Fatal server error:
    (EE) parse_vt_settings: Cannot open /dev/tty0 (Permission denied)
    (EE)
    (EE)
    Please consult the The X.Org Foundation support
    at http://wiki.x.org
    for help.
    (EE) Please also check the log file at "/home/lothar/.local/share/xorg/Xorg.1.log" for additional information.
    (EE)
    (EE) Server terminated with error (1). Closing log file.
    xinit: giving up
    xinit: unable to connect to X server: Connection refused
    xinit: server error
    Couldn't get a file descriptor referring to the console.
  • ibex44Noch mal die Frage warum Du startx als normaler Benutzer versuchst‽ Denn das ist ja ein Rechteproblem das der Benutzer keinen Zugriff auf /dev/tty0 hat.
    Per SSH ist das auch ein bisschen problematisch X zu starten, denn Programme laufen dann ja nur solange die SSH-Verbindung da ist.
    Interessanter wäre warum X nicht mehr normal beim Rechnerstart mitstartet. Die Logeinträge die dabei entstehen wären interessant.
    "He who laughs last thinks slowest"
  • das normale sudo apt upgrade.
    Bei mir ist das nicht normal, ich muss vorher mit sudo apt update erstmals die Paketquellem aktualisieren.
    Ausserdem werden im Verzeichnis /var/log/apt in history.log und term.log die Ergebnisse des upgrade gespeichert, falls Du die Terminalausgeben übersehen hast.
