Hallo zusammen,
Dies ist mein erster Post daher verzeiht es bitte falls ich irgendwelche Angaben vergesse.
Ich versuche an meinen RPi5 ein kamera modul V2.1 anzubinden. Leider gibt er mir die folgende Fehlermeldung:
admin@raspberrypi:~ $ libcamera-still -o test.jpg
[0:04:22.524280127] [2946] INFO Camera camera_manager.cpp:325 libcamera v0.3.2+99-1230f78d
[0:04:22.531626466] [2949] INFO RPI pisp.cpp:695 libpisp version v1.0.7 28196ed6edcf 29-08-2024 (16:33:32)
[0:04:22.549163102] [2949] INFO RPI pisp.cpp:1154 Registered camera /base/axi/pcie@120000/rp1/i2c@88000/imx219@10 to CFE device /dev/media2 and ISP device /dev/media0 using PiSP variant BCM2712_C0
Made X/EGL preview window
Mode selection for 1640:1232:12:P
SRGGB10_CSI2P,640x480/0 - Score: 4504.81
SRGGB10_CSI2P,1640x1232/0 - Score: 1000
SRGGB10_CSI2P,1920x1080/0 - Score: 1541.48
SRGGB10_CSI2P,3280x2464/0 - Score: 1718
SRGGB8,640x480/0 - Score: 5504.81
SRGGB8,1640x1232/0 - Score: 2000
SRGGB8,1920x1080/0 - Score: 2541.48
SRGGB8,3280x2464/0 - Score: 2718
Stream configuration adjusted
[0:04:23.612859582] [2946] INFO Camera camera.cpp:1197 configuring streams: (0) 1640x1232-YUV420 (1) 1640x1232-BGGR_PISP_COMP1
[0:04:23.612957842] [2949] INFO RPI pisp.cpp:1450 Sensor: /base/axi/pcie@120000/rp1/i2c@88000/imx219@10 - Selected sensor format: 1640x1232-SBGGR10_1X10 - Selected CFE format: 1640x1232-PC1B
[0:04:24.660059988] [2949] WARN V4L2 v4l2_videodevice.cpp:2127 /dev/video4[16:cap]: Dequeue timer of 1000000.00us has expired!
[0:04:24.660099562] [2949] ERROR RPI pipeline_base.cpp:1366 Camera frontend has timed out!
[0:04:24.660104710] [2949] ERROR RPI pipeline_base.cpp:1367 Please check that your camera sensor connector is attached securely.
[0:04:24.660110284] [2949] ERROR RPI pipeline_base.cpp:1368 Alternatively, try another cable and/or sensor.
ERROR: Device timeout detected, attempting a restart!!!
Ich habe versucht im Interner ähnliche Probleme und Lösungen zu finden dies war aber leider nicht erfolgreich.
Ich habe auch versucht die packages die genutzt werden neu zu installieren.
Hat jemand eine Idee was ich noch machen kann?
