Infos zur SSD frisch vom laufenden System (Raspberry Pi 5, 8 GB im ARGON One V3 NVME)
SSD: TWSC TE3420F1T0 1TB M.2 Gen 3x4 (kein DRAM Cash) MAXIO MAP1202 Rev 1 Controler
M.2 2280 PCle 3.0x4 NVMe SSD-Shenzhen Techwinsemi Technology Co., Ltd.
sudo dmesg -ex | grep pcie
kern :notice: [ +0,000000] Kernel command line: reboot=w coherent_pool=1M 8250.nr_uarts=1 pci=pcie_bus_safe cgroup_disable=memory numa_policy=interleave smsc95xx.macaddr=2C:CF:67:5D:93:37 vc_mem.mem_base=0x3fc00000 vc_mem.mem_size=0x40000000 console=ttyAMA10,115200 console=tty1 root=PARTUUID=5deaa881-02 rootfstype=btrfs rootflags=subvol=@root fsck.repair=yes rootwait quiet cfg80211.ieee80211_regdom=DE zswap.enabled=1 zswap.compressor=lzo
kern :info : [ +0,004846] /axi/pcie@120000/rp1: Fixed dependency cycle(s) with /axi/pcie@120000/rp1
kern :info : [ +0,000183] /axi/pcie@120000/rp1: Fixed dependency cycle(s) with /axi/pcie@120000/rp1
kern :info : [ +0,000485] brcm-pcie 1000110000.pcie: host bridge /axi/pcie@110000 ranges:
kern :info : [ +0,000005] brcm-pcie 1000110000.pcie: No bus range found for /axi/pcie@110000, using [bus 00-ff]
kern :info : [ +0,000008] brcm-pcie 1000110000.pcie: MEM 0x1b80000000..0x1bffffffff -> 0x0080000000
kern :info : [ +0,000004] brcm-pcie 1000110000.pcie: MEM 0x1800000000..0x1b7fffffff -> 0x0400000000
kern :info : [ +0,000004] brcm-pcie 1000110000.pcie: IB MEM 0x0000000000..0x0fffffffff -> 0x1000000000
kern :info : [ +0,001292] brcm-pcie 1000110000.pcie: Forcing gen 3
kern :info : [ +0,000181] brcm-pcie 1000110000.pcie: PCI host bridge to bus 0000:00
kern :info : [ +0,106977] brcm-pcie 1000110000.pcie: link up, 8.0 GT/s PCIe x1 (!SSC)
kern :info : [ +0,000050] pcieport 0000:00:00.0: enabling device (0000 -> 0002)
kern :info : [ +0,000026] pcieport 0000:00:00.0: PME: Signaling with IRQ 38
kern :info : [ +0,000065] pcieport 0000:00:00.0: AER: enabled with IRQ 38
kern :info : [ +0,000105] brcm-pcie 1000110000.pcie: clkreq control enabled
kern :info : [ +0,000042] brcm-pcie 1000120000.pcie: host bridge /axi/pcie@120000 ranges:
kern :info : [ +0,000003] brcm-pcie 1000120000.pcie: No bus range found for /axi/pcie@120000, using [bus 00-ff]
kern :info : [ +0,000006] brcm-pcie 1000120000.pcie: MEM 0x1f00000000..0x1ffffffffb -> 0x0000000000
kern :info : [ +0,000004] brcm-pcie 1000120000.pcie: MEM 0x1c00000000..0x1effffffff -> 0x0400000000
kern :info : [ +0,000005] brcm-pcie 1000120000.pcie: IB MEM 0x1f00000000..0x1f003fffff -> 0x0000000000
kern :info : [ +0,000003] brcm-pcie 1000120000.pcie: IB MEM 0x0000000000..0x0fffffffff -> 0x1000000000
kern :info : [ +0,001057] brcm-pcie 1000120000.pcie: Forcing gen 2
kern :info : [ +0,000025] brcm-pcie 1000120000.pcie: PCI host bridge to bus 0001:00
kern :info : [ +0,106577] brcm-pcie 1000120000.pcie: link up, 5.0 GT/s PCIe x4 (!SSC)
kern :info : [ +0,000039] pcieport 0001:00:00.0: enabling device (0000 -> 0002)
kern :info : [ +0,000022] pcieport 0001:00:00.0: PME: Signaling with IRQ 44
kern :info : [ +0,000053] pcieport 0001:00:00.0: AER: enabled with IRQ 44
Display More
Das Ganze im lspci
sudo lspci -vvv -s 0000:01:00.0
0000:01:00.0 Non-Volatile memory controller: MAXIO Technology (Hangzhou) Ltd. NVMe SSD Controller MAP1202 (rev 01) (prog-if 02 [NVM Express])
Subsystem: MAXIO Technology (Hangzhou) Ltd. NVMe SSD Controller MAP1202 (DRAM-less)
Control: I/O- Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx+
Status: Cap+ 66MHz- UDF- FastB2B- ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx-
Latency: 0
Interrupt: pin A routed to IRQ 38
Region 0: Memory at 1b80000000 (64-bit, non-prefetchable) [size=16K]
Capabilities: [40] Power Management version 3
Flags: PMEClk- DSI- D1- D2- AuxCurrent=0mA PME(D0+,D1-,D2-,D3hot+,D3cold+)
Status: D0 NoSoftRst+ PME-Enable- DSel=0 DScale=0 PME-
Capabilities: [50] MSI: Enable- Count=1/32 Maskable+ 64bit+
Address: 0000000000000000 Data: 0000
Masking: 00000000 Pending: 00000000
Capabilities: [70] Express (v2) Endpoint, MSI 1f
DevCap: MaxPayload 512 bytes, PhantFunc 0, Latency L0s unlimited, L1 unlimited
ExtTag- AttnBtn- AttnInd- PwrInd- RBE+ FLReset+ SlotPowerLimit 0W
DevCtl: CorrErr+ NonFatalErr+ FatalErr+ UnsupReq+
RlxdOrd+ ExtTag- PhantFunc- AuxPwr- NoSnoop+ FLReset-
MaxPayload 512 bytes, MaxReadReq 512 bytes
DevSta: CorrErr- NonFatalErr- FatalErr- UnsupReq- AuxPwr+ TransPend-
LnkCap: Port #0, Speed 8GT/s, Width x4, ASPM not supported
ClockPM+ Surprise- LLActRep- BwNot- ASPMOptComp+
LnkCtl: ASPM Disabled; RCB 64 bytes, Disabled- CommClk-
ExtSynch- ClockPM+ AutWidDis- BWInt- AutBWInt-
LnkSta: Speed 8GT/s, Width x1 (downgraded)
TrErr- Train- SlotClk+ DLActive- BWMgmt- ABWMgmt-
DevCap2: Completion Timeout: Range ABCD, TimeoutDis+ NROPrPrP- LTR+
10BitTagComp- 10BitTagReq- OBFF Via message, ExtFmt- EETLPPrefix-
EmergencyPowerReduction Not Supported, EmergencyPowerReductionInit-
FRS- TPHComp- ExtTPHComp-
AtomicOpsCap: 32bit- 64bit- 128bitCAS-
DevCtl2: Completion Timeout: 16ms to 55ms, TimeoutDis- LTR+ 10BitTagReq- OBFF Disabled,
AtomicOpsCtl: ReqEn-
LnkCap2: Supported Link Speeds: 2.5-8GT/s, Crosslink- Retimer- 2Retimers- DRS-
LnkCtl2: Target Link Speed: 8GT/s, EnterCompliance- SpeedDis-
Transmit Margin: Normal Operating Range, EnterModifiedCompliance- ComplianceSOS-
Compliance Preset/De-emphasis: -6dB de-emphasis, 0dB preshoot
LnkSta2: Current De-emphasis Level: -6dB, EqualizationComplete+ EqualizationPhase1+
EqualizationPhase2+ EqualizationPhase3+ LinkEqualizationRequest-
Retimer- 2Retimers- CrosslinkRes: unsupported
Capabilities: [b0] MSI-X: Enable+ Count=9 Masked-
Vector table: BAR=0 offset=00003000
PBA: BAR=0 offset=00002000
Capabilities: [100 v2] Advanced Error Reporting
UESta: DLP- SDES- TLP- FCP- CmpltTO- CmpltAbrt- UnxCmplt- RxOF- MalfTLP- ECRC- UnsupReq- ACSViol-
UEMsk: DLP- SDES- TLP- FCP- CmpltTO- CmpltAbrt- UnxCmplt- RxOF- MalfTLP- ECRC- UnsupReq- ACSViol-
UESvrt: DLP+ SDES+ TLP- FCP+ CmpltTO- CmpltAbrt- UnxCmplt- RxOF+ MalfTLP+ ECRC- UnsupReq- ACSViol-
CESta: RxErr- BadTLP- BadDLLP- Rollover- Timeout- AdvNonFatalErr-
CEMsk: RxErr- BadTLP- BadDLLP- Rollover- Timeout- AdvNonFatalErr+
AERCap: First Error Pointer: 00, ECRCGenCap+ ECRCGenEn- ECRCChkCap+ ECRCChkEn-
MultHdrRecCap- MultHdrRecEn- TLPPfxPres- HdrLogCap-
HeaderLog: 00000000 00000000 00000000 00000000
Capabilities: [148 v1] Device Serial Number 00-00-00-00-00-00-00-00
Capabilities: [158 v1] Alternative Routing-ID Interpretation (ARI)
ARICap: MFVC- ACS+, Next Function: 0
ARICtl: MFVC- ACS-, Function Group: 0
Capabilities: [168 v1] Secondary PCI Express
LnkCtl3: LnkEquIntrruptEn- PerformEqu-
LaneErrStat: 0
Capabilities: [1d4 v1] Latency Tolerance Reporting
Max snoop latency: 0ns
Max no snoop latency: 0ns
Capabilities: [1dc v1] L1 PM Substates
L1SubCap: PCI-PM_L1.2+ PCI-PM_L1.1+ ASPM_L1.2- ASPM_L1.1- L1_PM_Substates+
PortCommonModeRestoreTime=10us PortTPowerOnTime=14us
L1SubCtl1: PCI-PM_L1.2- PCI-PM_L1.1- ASPM_L1.2- ASPM_L1.1-
T_CommonMode=0us
L1SubCtl2: T_PwrOn=0us
Capabilities: [1ec v1] Vendor Specific Information: ID=0002 Rev=4 Len=100 <?>
Capabilities: [2ec v1] Vendor Specific Information: ID=0001 Rev=1 Len=038 <?>
Kernel driver in use: nvme
Display More
nvme
sudo nvme list
Node Generic SN Model Namespace Usage Format FW Rev
/dev/nvme0n1 /dev/ng0n1 TTSQA24CUX04001 TWSC TSC3AN1T0-F6Q10S 1 1,02 TB / 1,02 TB 512 B + 0 B SN14243
sudo nvme list
S.M.A.R.T.
sudo nvme smart-log /dev/nvme0
Smart Log for NVME device:nvme0 namespace-id:ffffffff
critical_warning : 0
temperature : 42°C (315 Kelvin)
available_spare : 100%
available_spare_threshold : 1%
percentage_used : 0%
endurance group critical warning summary: 0
Data Units Read : 2.803.453 (1,44 TB)
Data Units Written : 4.752.531 (2,43 TB)
host_read_commands : 45.615.589
host_write_commands : 39.702.333
controller_busy_time : 308
power_cycles : 78
power_on_hours : 54
unsafe_shutdowns : 16
media_errors : 0
num_err_log_entries : 0
Warning Temperature Time : 5
Critical Composite Temperature Time : 0
Temperature Sensor 1 : 42°C (315 Kelvin)
Temperature Sensor 2 : 45°C (318 Kelvin)
Thermal Management T1 Trans Count : 3649
Thermal Management T2 Trans Count : 0
Thermal Management T1 Total Time : 9805
Thermal Management T2 Total Time : 0
Display More
hdparm
sudo hdparm -Tt /dev/nvme0n1
/dev/nvme0n1:
Timing cached reads: 9818 MB in 2.00 seconds = 4914.22 MB/sec
Timing buffered disk reads: 2206 MB in 3.00 seconds = 735.04 MB/sec
sudo hdparm -Tt --direct /dev/nvme0n1
/dev/nvme0n1:
Timing O_DIRECT cached reads: 1042 MB in 2.00 seconds = 521.05 MB/sec
Timing O_DIRECT disk reads: 2174 MB in 3.00 seconds = 724.57 MB/sec
Display More
