Neue Raspberry Pi OS-Veröffentlichung
  • Raspberry Pi OS: Kleine Verbesserungen in letzter Version vor "Trixie"
    Die Entwickler haben das Raspberry Pi OS noch mal verbessert, das letzte Mal vor dem Wechsel auf Debian-Trixie-Basis.
    www.heise.de
    Jürgen
  • Großes Update bringt Bildschirmsperre und verbesserte Touchscreen-Funktionen
    So groß ist das Update gar nicht, das sind halt die vielen Updates die es in den letzten Monaten gab zusammengefasst in der Version zum Download / Installation mit dem Imager. Man muss jetzt nach einer Neuinstallation nicht gleich ganz so viele Updates ziehen.
    $ aptitude -v moo
    There really are no Easter Eggs in this program.
    $ aptitude -vv moo
    tbc...
    Didn't I already tell you that there are no Easter Eggs in this program?
    $ aptitude -vvv moo
    Stop it!
    $ aptitude -vvvv moo
    Okay, okay, if I give you an Easter Egg, will you go away?
  • In Linux desktops, it is usually possible to access a command-line console (known as a TTY) by pressing Ctrl-Alt and one of the function keys from 1 to 7. We have always set up Raspberry Pi Desktop so that if you boot to the desktop and enable auto login, then the TTY on Ctrl-Alt-F1 is also automatically logged in. If you use the screen lock described above, this gives a potential security hole, as the TTY switches are not disabled when the screen is locked.
    What this means is that if you lock the screen, you should need to enter a password to be able to access the Raspberry Pi desktop again. But if a TTY is also logged in, someone can just hit Ctrl-Alt-F1, switch to the logged-in TTY, and gain access to the computer.
    In order to prevent this, we have now separated console and desktop auto login options. On a new image, both console and desktop are automatically logged in, but if you want to prevent someone using this to get around the screen lock, we recommend turning off console auto login. There are now controls for this both in Raspberry Pi Configuration and in raspi-config.
    An einem RPi 5 drücke ich dann einfach den am RPi befindlichen Taster 10 Sekunden lang und der RPi schaltet sich ab und dann drücke ich den Taster nochmals und bin auf dem Desktop. Ist das nicht auch eine Sicherheitslücke? :conf: Ich frage für einen Freund. :green_wink:
  • Die gleiche "Sicherheitslücke" wie autologin beim Boot ;)
    Es ist immer die Frage, was ist am System gespeichert.
    Meine Antwort ist 21 und nicht 42.
    Also die Hälfte der Antwort
    auf die Frage aller Fragen: "Wo ist das Bier hin?"
