Hallo Zusammen
ich bekomme bei sudo apt upgrade folgende dpg Fehler
Kann mir da jemand weiterhelfen ?
Viele Grüße Sascha
pi@schopf:~ $ sudo apt upgrade
Reading package lists... Done
Building dependency tree... Done
Reading state information... Done
Calculating upgrade... Done
The following packages were automatically installed and are no longer required:
avahi-utils gir1.2-handy-1 gir1.2-polkit-1.0 libc++1-16 libc++abi1-16 libcamera0.3 libcamera0.4 libunwind-16
linux-headers-6.6.74+rpt-common-rpi linux-kbuild-6.6.74+rpt lxplug-network
Use 'sudo apt autoremove' to remove them.
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
13 not fully installed or removed.
Need to get 0 B/59.7 MB of archives.
After this operation, 0 B of additional disk space will be used.
Do you want to continue? [Y/n] y
Setting up initramfs-tools (0.142+rpt3+deb12u3) ...
update-initramfs: deferring update (trigger activated)
Setting up linux-image-6.12.25+rpt-rpi-2712 (1:6.12.25-1+rpt1) ...
/etc/kernel/postinst.d/initramfs-tools:
update-initramfs: Generating /boot/initrd.img-6.12.25+rpt-rpi-2712
raspi-firmware: missing /boot/firmware, did you forget to mount it?
run-parts: /etc/initramfs/post-update.d//z50-raspi-firmware exited with return code 1
run-parts: /etc/kernel/postinst.d/initramfs-tools exited with return code 1
dpkg: error processing package linux-image-6.12.25+rpt-rpi-2712 (--configure):
installed linux-image-6.12.25+rpt-rpi-2712 package post-installation script subprocess returned error exit status 1
dpkg: dependency problems prevent configuration of linux-image-rpi-2712:
linux-image-rpi-2712 depends on linux-image-6.12.25+rpt-rpi-2712 (= 1:6.12.25-1+rpt1); however:
Package linux-image-6.12.25+rpt-rpi-2712 is not configured yet.
dpkg: error processing package linux-image-rpi-2712 (--configure):
dependency problems - leaving unconfigured
Setting up linux-image-6.6.74+rpt-rpi-v8 (1:6.6.74-1+rpt1) ...
update-initramfs: Generating /boot/initrd.img-6.6.74+rpt-rpi-v8
dpkg: error processing package linux-image-6.6.74+rpt-rpi-v8 (--configure):
installed linux-image-6.6.74+rpt-rpi-v8 package post-installation script subprocess returned error exit status 1
Setting up raspi-firmware (1:1.20250430-1) ...
Error: missing /boot/firmware, did you forget to mount it?
dpkg: error processing package raspi-firmware (--configure):
installed raspi-firmware package post-installation script subprocess returned error exit status 1
Setting up linux-image-6.12.25+rpt-rpi-v8 (1:6.12.25-1+rpt1) ...
update-initramfs: Generating /boot/initrd.img-6.12.25+rpt-rpi-v8
dpkg: error processing package linux-image-6.12.25+rpt-rpi-v8 (--configure):
installed linux-image-6.12.25+rpt-rpi-v8 package post-installation script subprocess returned error exit status 1
dpkg: dependency problems prevent configuration of linux-headers-6.12.25+rpt-rpi-2712:
linux-headers-6.12.25+rpt-rpi-2712 depends on linux-image-6.12.25+rpt-rpi-2712 (= 1:6.12.25-1+rpt1) | linux-image-6.12.25+rpt-rpi-2712-unsigned (= 1:6.12.25-1+rpt1); however:
Package linux-image-6.12.25+rpt-rpi-2712-unsigned is not installed.
dpkg: error processing package linux-headers-6.12.25+rpt-rpi-2712 (--configure):
dpkg: dependency problems prevent configuration of linux-headers-6.12.25+rpt-rpi-v8:
linux-headers-6.12.25+rpt-rpi-v8 depends on linux-image-6.12.25+rpt-rpi-v8 (= 1:6.12.25-1+rpt1) | linux-image-6.12.25+rpt-rpi-v8-unsigned (= 1:6.12.25-1+rpt1); however:
Package linux-image-6.12.25+rpt-rpi-v8 is not configured yet.
Package linux-image-6.12.25+rpt-rpi-v8-unsigned is not installed.
dpkg: error processing package linux-headers-6.12.25+rpt-rpi-v8 (--configure):
dpkg: dependency problems prevent configuration of linux-headers-rpi-2712:
linux-headers-rpi-2712 depends on linux-headers-6.12.25+rpt-rpi-2712 (= 1:6.12.25-1+rpt1); however:
Package linux-headers-6.12.25+rpt-rpi-2712 is not configured yet.
dpkg: error processing package linux-headers-rpi-2712 (--configure):
dpkg: dependency problems prevent configuration of linux-image-rpi-v8:
linux-image-rpi-v8 depends on linux-image-6.12.25+rpt-rpi-v8 (= 1:6.12.25-1+rpt1); however:
dpkg: error processing package linux-image-rpi-v8 (--configure):
dpkg: dependency problems prevent configuration of linux-headers-rpi-v8:
linux-headers-rpi-v8 depends on linux-headers-6.12.25+rpt-rpi-v8 (= 1:6.12.25-1+rpt1); however:
Package linux-headers-6.12.25+rpt-rpi-v8 is not configured yet.
dpkg: error processing package linux-headers-rpi-v8 (--configure):
Processing triggers for initramfs-tools (0.142+rpt3+deb12u3) ...
dpkg: error processing package initramfs-tools (--configure):
installed initramfs-tools package post-installation script subprocess returned error exit status 1
Errors were encountered while processing:
raspi-firmware
linux-image-rpi-v8
initramfs-tools
E: Sub-process /usr/bin/dpkg returned an error code (1)
Display More
