Hallöchen,
ich bin gerade über folgenden logeintrag gestoßen:
pi@raspberrypi ~ $ tail -f /var/log/messages
Feb 15 16:39:23 raspberrypi kernel: [ 20.362676] FAT-fs (mmcblk0p1): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
Feb 15 16:39:23 raspberrypi kernel: [ 23.103203] smsc95xx 1-1.1:1.0 eth0: hardware isn't capable of remote wakeup
Feb 15 16:39:23 raspberrypi kernel: [ 24.661766] smsc95xx 1-1.1:1.0 eth0: link up, 100Mbps, full-duplex, lpa 0x4DE1
Feb 15 16:39:23 raspberrypi kernel: [ 24.987930] bcm2835-cpufreq: switching to governor ondemand
Feb 15 16:39:23 raspberrypi kernel: [ 24.987962] bcm2835-cpufreq: switching to governor ondemand
Feb 15 16:39:24 raspberrypi kernel: [ 27.038434] Adding 102396k swap on /var/swap. Priority:-1 extents:1 across:102396k SSFS
Feb 15 16:40:16 raspberrypi kernel: [ 46.302638] fuse init (API version 7.22)
Feb 15 16:40:19 raspberrypi kernel: [ 49.710210] EXT4-fs (sdd1): warning: maximal mount count reached, running e2fsck is recommended
Feb 15 16:40:19 raspberrypi kernel: [ 49.716505] EXT4-fs (sdd1): mounted filesystem with ordered data mode. Opts: (null)
Feb 15 16:40:25 raspberrypi kernel: [ 55.786199] EXT4-fs (sdc1): mounted filesystem with ordered data mode. Opts: (null)
Alles anzeigen
muss ich mir gedanken machen über die EXT4-fs Meldung?
