Kismet Installation
  • Hallo versuche seit Tagen Kismet zu installieren leider bekomme ich immer den selben Fehler.
    Kann mir da jemand weiter Helfen ??
    pi@raspberrypi ~ $ sudo apt-get install kismet
    Reading package lists... Done
    Building dependency tree
    Reading state information... Done
    The following extra packages will be installed:
    geoip-database imagemagick-common libc-ares2 libcap2-bin libgeoip1
    liblqr-1-0 liblua5.1-0 libmagickcore5 libpam-cap libpcap0.8 libportaudio2
    libsmi2ldbl libwireshark-data libwireshark2 libwiretap2 libwsutil2 wireshark
    wireshark-common
    Suggested packages:
    sox festival libwww-perl libcap-dev geoip-bin libmagickcore5-extra
    snmp-mibs-downloader wireshark-doc
    The following NEW packages will be installed:
    geoip-database imagemagick-common kismet libc-ares2 libcap2-bin libgeoip1
    wireshark-common
    0 upgraded, 19 newly installed, 0 to remove and 0 not upgraded.
    Need to get 1,530 kB/18.9 MB of archives.
    After this operation, 62.2 MB of additional disk space will be used.
    Do you want to continue [Y/n]? y
    Err http://mirrordirector.raspbian.org/raspbian/ wheezy/main geoip-database all 20121111-1
    404 Not Found
    Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/…21111-1_all.deb 404 Not Found
    E: Unable to fetch some archives, maybe run apt-get update or try with --fix-missing?
