GpioPinInput
    kann mir wer sagen wie ich an die Info komme wann ein InputPin ein Signal bekommt??
    Zum beispiel wenn ich vor dem Input nen Taster packe etc....
    mfg
  • Hallo Zebax,
    eine Möglichkeit habe ich hier beschrieben:
    http://www.forum-raspberrypi.d…nd-programmierung-in-icon (EDIT: 08-OKT-2017 Link im alten Forum)
    Der betreffende GPIO-Pin muss auf Eingang gesetzt werden. Dein Programm reagiert auf einen Zustand (0 oder 1) oder Zustandswechsel (0 ==> 1: steigende Flanke oder fallende Flanke 1 ==> 0).
    [hr]
    Hallo Zebax,
    Auszug aus Kapitel 12 meines Icon-Kurses:
    12.3.2 Traditional approach
    At first we want to learn, how GPIO can be
    addressed by shell commands using the terminal.
    For example, if you want to "read" the status of
    the GPIO pin #9, you have to enter:
    echo "9" > /sys/class/gpio/export
    echo "in" > /sys/class/gpio/gpio9/direction
    The first command causes the creation of a new
    directory gpio9 within /sys/class/gpio,
    containing a file named direction. This file
    direction can be written with either "in" or
    "out", which we perform with the second
    command.
    Another file within the new produced directory
    gpio9 is value. This file contains information
    about the status, e.g. 0 or 1. You can read the
    content by
    cat /sys/class/gpio/gpio9/value
    The content is displayed, either 0 or 1. Finally,
    you have to "close" what was produced so far, by
    echo "9" > /sys/class/gpio/unexport
    If you want to "write" (e.g. to turn on/off a LED) to
    that GPIO pin you have to do something like:
    echo "out" > /sys/class/gpio/gpio9/direction
    If you want to "write" (for example to turn on/off a
    LED) to that GPIO pin, you have enter:
    echo "1" > /sys/class/gpio/gpio9/value
    turning on the LED, and
    respectively, to turn the LED off, again. And,
    finally, to "close" everything
    If you have some problems because of denied permissions
    and so on, you should try to repeat it within the root
    terminal, or as substitute user, put a "sudo" in front of those
    commands. If it doesn't work, you should try it with
    chown pi /sys/class/gpio...
    and
    chmod 777 /sys/class/gpio/...
    And again, if it doesn't work, try
    this as substitute user do:
    sudo ...
    OK. That's how it works with shell commands.
    Edited 2 times, last by Andreas ().
  • Hallo Zebax,
    von Java (oder was auch imer) musst Du obige Linux-Kommandos aufrufen - oder entsprechende Befehle von GPIO-Libraries aufrufen.
  • Du brauchst natürlich nicht unbedingt aus Java heraus die Shell-Commandos aufrufen, genau so wenig wie du GPIO - Libraries brauchst.
    Sicherlich wird es auch für Java Bibliotheken für Dateisystem-Zugriffe geben (z.b. java.io.* ). Mit denen kannst du genau so auf die o.g. "Dateien" zugreifen. Entsprechende Berechtigungen natürlilch vorrausgesetzt.
