Bei meinem Post habe ich mich verschrieben aber das ändert nichts.
root@362fd30:~# python
Python 2.7.11 (default, Mar 5 2016, 00:18:37)
[GCC 4.9.2] on linux2
Type "help", "copyright", "credits" or "license" for more information.
>>> import picamera
File "<stdin>", line 1, in <module>
ImportError: No module named picamera
Warum Chaos? Habe nichts verändert...
Hier mal die Ausgabe vom Wheezy
pi@raspcam1 ~ $ dpkg -L python-picamera
/usr
/usr/lib
/usr/lib/python2.7
/usr/lib/python2.7/dist-packages
/usr/lib/python2.7/dist-packages/picamera-1.10.egg-info
/usr/share
/usr/share/doc
/usr/share/doc/python-picamera
/usr/share/doc/python-picamera/README.rst
/usr/share/doc/python-picamera/copyright
/usr/share/doc/python-picamera/changelog.Debian.gz
/usr/share/pyshared
/usr/share/pyshared/picamera-1.10.egg-info
/usr/share/pyshared/picamera-1.10.egg-info/dependency_links.txt
/usr/share/pyshared/picamera-1.10.egg-info/SOURCES.txt
/usr/share/pyshared/picamera-1.10.egg-info/top_level.txt
/usr/share/pyshared/picamera-1.10.egg-info/requires.txt
/usr/share/pyshared/picamera-1.10.egg-info/PKG-INFO
/usr/share/pyshared/picamera/camera.py
/usr/share/pyshared/picamera/array.py
/usr/share/pyshared/picamera/renderers.py
/usr/share/pyshared/picamera/color.py
/usr/share/pyshared/picamera/streams.py
/usr/share/pyshared/picamera/__init__.py
/usr/share/pyshared/picamera/bcm_host.py
/usr/share/pyshared/picamera/exc.py
/usr/share/pyshared/picamera/mmal.py
/usr/share/pyshared/picamera/encoders.py
/usr/lib/python2.7/dist-packages/picamera-1.10.egg-info/dependency_links.txt
/usr/lib/python2.7/dist-packages/picamera-1.10.egg-info/SOURCES.txt
/usr/lib/python2.7/dist-packages/picamera-1.10.egg-info/top_level.txt
/usr/lib/python2.7/dist-packages/picamera-1.10.egg-info/requires.txt
/usr/lib/python2.7/dist-packages/picamera-1.10.egg-info/PKG-INFO
/usr/lib/python2.7/dist-packages/picamera/camera.py
/usr/lib/python2.7/dist-packages/picamera/array.py
/usr/lib/python2.7/dist-packages/picamera/renderers.py
/usr/lib/python2.7/dist-packages/picamera/color.py
/usr/lib/python2.7/dist-packages/picamera/streams.py
/usr/lib/python2.7/dist-packages/picamera/__init__.py
/usr/lib/python2.7/dist-packages/picamera/bcm_host.py
/usr/lib/python2.7/dist-packages/picamera/exc.py
/usr/lib/python2.7/dist-packages/picamera/mmal.py
/usr/lib/python2.7/dist-packages/picamera/encoders.py
Automatisch zusammengefügt:
PS: Nebenbei erwähnt: es gibt aktuell kein python-picamera über apt-get, deshalb verwundert mich deine obige Aussage
root@raspberrypi:~# apt-cache search picamera
root@raspberrypi:~#
Also: keine Ahnung was du da verzapft hast :s
[/quote]
root@raspberrypi:~#
python-picamera - Pure Python interface to the Raspberry Pi's camera module.
python-picamera-docs - Documentation for the Python interface to the RPi's camera module.
python3-picamera - Pure Python interface to the Raspberry Pi's camera module.
root@362fd30:~#
So ich lade mir gerade eine neue Jessie von der Seite:
https://www.raspberrypi.org/downloads/raspbian/
RASPBIAN JESSIE
Full desktop image based on Debian Jessie
Version:March 2016
Release date:2016-03-18
Kernel version:
Werde die auf meine SD Karte schreiben und GANZ neu anfangen.
