kann mir jemand mit diesem Problem helfen:
Nach apt-get update kommt diese Meldung
Err http://mirrordirector.raspbian.org wheezy Release
rename failed, No such file or directory (/var/lib/apt/lists/partial/mirrordirector.raspbian.org_raspbian_dists_wheezy_Release.gpg.reverify -> /var/lib/apt/lists/mirrordirector.raspbian.org_raspbian_dists_wheezy_Release.gpg).
Ign http://raspberrypi.collabora.com wheezy/rpi Translation-en
W: A error occurred during the signature verification. The repository is not updated and the previous index files will be used. GPG error: http://mirrordirector.raspbian.org wheezy Release: The following signatures were invalid: NODATA 1 NODATA 2
W: GPG error: mirror://apt.xbian.org wheezy Release: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 5D3294C2529968ED
W: Failed to fetch http://mirrordirector.raspbian.org/raspbian/dists/wheezy/Release rename failed, No such file or directory (/var/lib/apt/lists/partial/mirrordirector.raspbian.org_raspbian_dists_wheezy_Release.gpg.reverify -> /var/lib/apt/lists/mirrordirector.raspbian.org_raspbian_dists_wheezy_Release.gpg).
W: Some index files failed to download. They have been ignored, or old ones used instead.
Alles anzeigen
Das ist meine sources.list:
deb mirror://apt.xbian.org/mirror.txt wheezy main
deb http://mirrordirector.raspbian.org/raspbian/ wheezy main contrib non-free rpi
Danke
Mebus
